Question about Toshiba 42HP83 42 in. HD-Ready Plasma Television
Toshiba 42hp82 plasma picture problem
My plasma screen has a snowy black screen and no sound. None of the controls seem to work other than the on/off switch. I've replaced the power supply so that good. I can get the sound to work if i remove the g-hyper board which also turns the screen green with a flicker. The volume works and tv/video button will change the inputs with the g-hyper board removed. Should i replace the g-hyper board, the main signal board, or should i be looking at something else?
brad
  • 6 more comments
  • bardx86 Sep 11, 2008
    The g-hyper board is 100 bucks I would like to have a more solid answer than buy and try.
    Could you please explain a bit more.?
    thanks.
    brad
    Ya but what board? I would like some trouble shooting steps.
    Getting it serviced is not why I'm posting here lol. What board is the conveyance board?
  • bardx86 Sep 12, 2008
    Well i think the key here that will the g-hyper board connected to the signal board I lose sound and volume channel and tv/video buttons. So something in that relationship is causing it to sorta lock up.
    Your kidding me right, this is your solution? Does any one on this site have any plasma tv tech knowledge?
    I have the tv completely apart I have not trouble replacing the caps but they don't appear to be bad. what are your thoughts on why the sound fails when the g-hyper is connected to the signal board.
  • bardx86 Sep 13, 2008
    I have a service manual but it don't trouble shooting for this issue.
    bard
    Genius:
  • 2,035 Answers
Well this could the problem with g board because the sound is working and tv button is working when it is removed ,however if you want a solid answer for your question then you need a service manual to guide you to trouble shoot the problem ,I would recommend going to the following link and getting the service manual so testing procedures. Its only 10.99 and they email it to you shortly after purchase. The manual is a valuable resource as it will have part numbers in case you do need a new board. heres the link.
http://servicemanuals.vstore.ca/
Good luck....
Posted on Sep 13, 2008
  • 2,071 Answers
Resetting the TV
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can saved time.
1. Unplug the TV power cord from the power outlet for 3 - 4 hours.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
  • 1,512 Answers
Sounds like your video signal is getting canned somewhere, without anosciloscope to do some test, hard to diagnose exactly what is going on. This is from esteemed FixYa colleaugue premtech on the g Hyper board This is a somewhat common problem having to do with the hyper module, Toshiba p/n#23148024
There are a gouping of 16v/10uf caps in the hyper board that fail causing the distoritions you're describing here. At first, as the module begins to go bad the distoritions are present and usuallly go away or fade significantly as the set warms up - - this gets worse until the distoritions don't go away at all... From what you're saying you're at stage three already. :)
You have a few of options: (1) local repair shop pull the board and replace the caps or module; (2) Pull the module yourself and repair or send it in for board level repair; or (3) pull the hyper baord, order a new one and put it in yourself.
For 2 or 3 you'll be better off having the service manual and if you need it just email me privately and I'll send it. Make sure in your request to tell me the model number and reference something of this repair so I have a clue of what you need.
BTW the hyper board is on the left side of the unit mounted vertical on the signal board inside a metal can.
Good Luck
Bill
Comment by premtech, posted on Jun 10, 2007 Sent link to service manual and schematics to your chrisparadis@gmail.com address via Pando.. You will need to download Pando to retrieve them - Pando is free and most techs use it for sending large multiple files, up to 1 gig free...
Good Luck
Bill
Posted on Sep 12, 2008
  • 1 more comment
  • Graeme Ross
    Graeme Ross Sep 12, 2008
    sorry about the poor formatting, it got lost in the transfer. hope it helps anyway
  • Graeme Ross
    sorry mate, don't have alot more on the fault you have, except to say that the hyper board seems to pop come up alot with faults,and recapping seems to sort most problems with it. Somewhere to start, short of replacing the board, which is why I posted the info to you in the first place. Good luck
    robotek
  • Graeme Ross
    Graeme Ross Sep 13, 2008
    It is possible that the g hyper board has a fault that is shutting down a power supply rail. Using your manual, have you been able to sniff about for any DC voltages that are disappear when you plug in the board. This would explain why the sound disappears also. Capacitors may be faulty even though they physically look ok. Have you done any checks with a capacitance meter to see if they are all good on that board. As they cost virtually nothing, I would just blanket replace them to the g hyper board and see what happens anyway. Is a way to move forward with your repair.
    President:
  • 1,952 Answers
It is possible to set brightness up to 550 cd/m 2. Users can useoptional side mounted speaker panel with this unit which can be removedeasily. It uses High Definition component video to show high qualitypictures on your screen. The unit is designed with distinct dimensionsas 41.5 x 25.5 x 3.5. With the help of On Screen Display menu, you canview various languages on the screen. It has totally 4 pictureexpansion modes which enables the user to view images in the fullscreen. If in need it is possible to view in distinct wide screen movieformats.
Users can adjust the colour settings by using colour temperaturecontrol option. To get optimum white balance, you can use 3 userselectable colour settings so that you can enjoy high quality displaywhile you watching programs. Toshiba Plasma Televisionhas embedded with 2 audio amplifiers. The amplifiers are used toamplify the sound effects. Each amplifier has the potential to offer 7watts audio output. It also featured with optional 3 way speakers.
http://tacpservice.toshiba.com/ConsumerProductSupport/Manuals/TV/2002/42hp82_ownman.pdf
    Habit-Forming:
  • 111 Answers
Check all the connections before you purchase anything.
    Sergeant:
  • 300 Answers
ConVERGENCE board. not conveyance board , and no it's not nessessarily the convergence board.
snowy picture is most offten caused by poor signal input.
convergence is refference to the colorguns and how they converge on the grid pattern test.
and what does he mean by snowy , that doesn't tell me alot but it does suggest poor signal input.
  • Steven Brown Sep 12, 2008
    You have no signal , and thats why you got nothing but black and snowy , I can't be any more direct than that.
  • Steven Brown Sep 17, 2008
    Comment by bardx86, posted on Sep 12, 2008
    Bingo there is your problem ( when I connect g-hyperboard I lose sound and volume channel and tv/video buttons. )
    And a solution is get your schmatic and start tracing the circuits like a good tek
    If I could reach through the internet with my magic o-scope and do it for you , I sure would !
    I think we ALL deserve a FixYa for ending the stupidity.
    Az.
    Master:
  • 726 Answers
I bet you defiantly its the conveyance board it controls all that and has the resistors on it and capacitors if there blown the tv will play up like this no matter what you will have to get it serviced have a real professional look at it
Posted on Sep 11, 2008
  • 10,594 Answers
Try this Part Store having low prices boards for your Toshiba TV with return policy.
  • Shahid Electronics
    Shahid Electronics Sep 11, 2008
    In my opinion, tv tech person can do this job better as rectify the defective board. Plasma tv is high tech product and requires qualified technical person. I cant figure out what board is defective in your tv while sitting miles away. Try to understand website help limitations.
    Genius:
  • 1,239 Answers
Hi
How do I adjust the color decoder?
There are several issues here. Generally speaking, the Panasonic decoder seems to push blue a bit. The R-Y Axis Angle and B-Y Axis Gain in the service menu are used to correct this behavior.
There used to be a problem on some Panasonics with the Y/C delay on the S-video input. See the Quality Control section for more information.
How do I set the black level on a plasma?
You set the black level by adjusting the "Brightness" setting. You can use the same test pattern you would use for any other display.
What is the buzzing problem? How do I know if I have it?
You'll know. It's loud. In one instance, it was reported as loud as 72dB just above the display. There will always be some audible hum (60 Hz) if you listen right next to the display. If it's irritating from 10' away, you probably have the problem.
The problem was with two capacitors used in the power supply. The power supply board can be swapped out by a service technician and should be covered under warranty.
thanku sir,,,,,,,,,,,,,,,,dont forget to rate me
    Brigadier General:
  • 3,614 Answers
Just check the 120k resistor on the video output module.. about the switch check the contact if it still functioning...
let me know
  • 185 Answers
Hai,
Replace the g-hyper board and check the status it may works.
Thank You
2 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: Snowy black picture
I would think that the signal board would be more suspect than the hyper board for the symptoms you're describing. However I would recommend getting the service manual and doing some troubleshooting rather than just replacing circuit boards.
Panasonic Plasma - turns on, but stays blank.
Your TV probably has power supply trouble.
Jan 16, 2014 | Panasonic Televison & Video
Intermittent black or snowy horizontal bar across the top
You're somewhat sound in electronics I assumes. If you wish to get more details, surf this link. http://electronicshelponline.blogspot.com/ There are more than two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help.
May 17, 2013 | JVC PD-42WV74 42 in. Plasma EDTV
Hp pl5060 Plasma TV has no sound or pix. Screen flashing white
I have a seven year Plasma TV HP PL5060. When I turn on the TV, I have sound but no picture, the screen display (power on) is a snowy blue screen and vertical pink stripe. What is causing this problem and how can I fix it cheap. I can afford a TV repair man at this time, because I am laid off from work. Thanks.
Dec 15, 2012 | HP PL5060N 50 in. Plasma HDTV
LG flatron plasma rz42px10 snow screen with sound
Check and replace its tuner. If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Apr 11, 2017 | Televison & Video
I was just given a 6842PE sylvania tv. when i plugged it in and connected the satellite the screen is very fuzzy and has a black 1 in line straight down the middle of the screen. i can see the outline of...
the 1inch black line is either a buffer board gone bad or the ribbon cable from the plasma screen to the buffer board, the snowy picture could be many things, including y-sus, xsus or tuner boards
Mar 27, 2011 | Sylvania 6842PE 42 in. HD-Ready Plasma...
HP-R5072 50 in. HDTV Plasma Television Samsung Plasma TV is snowy/dotted. When I turn it
Most likely it sounds like a Logic Board problem. The Logic Board is what controls images on the screen. It's a somewhat expensive part to replace. Maybe in the $200 range. Being that the part isn't cheap, best to have a TV tech come to your house to take a look at the TV to confirm the diagnoses before buying the replacement part.
Oct 24, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
Toshiba 42HP66 No Picture, Only Power Works
try replaced z board Manufacturer Toshiba Part Number 75003032 Description ZSUS PCB ASSY
Oct 02, 2009 | Toshiba 42HP66 42 in. LCD Television
I have a 3 year old Maxent MX-42VM11 plasma tv with no pic/sound
swollen capasitors, replaceing will cost $500, so best to get another one, 42'' samsung will sell for about $800. the pn42a450
once a plasma has a problem, fixing it or not, more problems will occure, trust me, i am the flat pannel guru.
May 02, 2009 | Maxent MX-42HPM20 42 in. Plasma HDTV
Snowy black picture
Sep 11, 2008 | Toshiba 42HP83 42 in. HD-Ready Plasma...
Snowy Picture, Toshiba 42HP84 plasma tv
Similar problem with my Toshiba. I was told it was the power supply and that it would cost about $900 to replace parts and labor
Nov 21, 2007 | Toshiba 42HP84 42 in. Plasma HDTV
Toshiba 42HP83 42 in. HD-Ready Plasma Television Logo
377 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
