Rear projection sony 51", comes
Rear projection sony 51", comes and goes red color, sometimes green...
    Novelist:
    Champion:
  • 203 Answers
Sounds like bad picture tubes. please post a model number, also are you seeing arched lines going through the picture? these can useually be seen best on a blank input wiht a black background.
Thank You
Tim
Posted on Sep 11, 2008
TV will come on sometimes and sometimes not. When is does it is all red. When it does not is makes a wising sound and automatically goes off, display is still dark.
According to the symptom the problem is relate to the CRT. One of three guns (Red,Blue,Green) causing problem. When it becomes short set goes on standby and when the carbon removes after some times of rest it becomes on, So you need to find which color is missing except red because it is present as you said in your question, now check which color is missing Blue or Green in picture. The one which misses, is faulty gun and needs replacement.
Please let me know for further help by reply in comments column.
Thanks
Nov 24, 2010 | Apex Digital GB51HD09 51" Rear Projection...
Turns on for 30 sec then goes bright blue and goes back into standby. turn back on it does it agian
This is blue CRT problem in tv as it is rear projection tv that has three CRTs red-green-blue inside to project color picture on front screen.
Blue CRT (tube) will be replaced to fix the issue and it is job of Pro because lots of adjustments are required after replacement of tube.
Local tv repair shop will help you for that.
Thanks
Oct 02, 2010 | Sony KP-51WS500 51" Rear Projection...
My red and blue crt go out and the green stays on
One or more of the CRT colors guns it dead,must be replaced.
Nov 03, 2009 | Sony KP-51WS500 51" Rear Projection...
Sony 51'' projection Tv after one hour color chngs to Green
I've come into this problem before, it sounds like the lamp is dieing .. It could also be that a wire connected to the lamp is attached to the wrong post or isn't connected at all.
Depends on how long you've had that lamp installed and use time. If you've been using it for quite some time, 2.5/4 years and never replaced the lamp then it's most likely the lamp that needs to be changed, otherwise if you've had the lamp changed recently, i'd be leaning towards, a wire in the wrong place or not attached at all. Best of luck :)
Oct 20, 2009 | Sony KP-51WS500 51" Rear Projection...
Have a green screen on sony kp-51-hw40 projection tv
i got the same problem you have to buy a mirror tube it goes inside the cl,projection you can buy it at radio shak
Feb 01, 2009 | Sony KP-51WS500 51" Rear Projection...
Green screen and shut down
TV screen flashes with Red lights for few times. sometime it shut down TV or red color is lost showing pictures without Red looks terrible. Any solution
Sep 17, 2008 | Sony KP-51HW40 51" Rear Projection...
Picture color
more then likely it could be your blue tube is bad.
Apr 27, 2008 | Sony KP-51HW40 51" Rear Projection...
Red and green colors not coming through in picture
Bad crt
Sony Picture tube recall
http://esupport.sony.com/perl/news-item.pl?news_id=24
Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700
Feb 04, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony rear projection
My dad has a sony rear projection tv and had this same problem. A shop had to replace one of the color tubes(?) (green, red, or blue) had to be replaced. The shop said this was common with Sony rear projection TV's.
Dec 11, 2007 | Sony KP-51HW40 51" Rear Projection...
Sony kp51hw40
did you adjust the green screen control .
Oct 01, 2007 | Sony KP-51HW40 51" Rear Projection...
Televison & Video Logo
79 people viewed this question
Top Televison & Video Experts
Electro Med Services...
