Question about Dell 828FI 15" CRT Monitor
SHAKING IMAGE, STRETCHED IMAGE
THERE IS NO VERTICAL PRESET POT TO ADJUST THE VERTICAL HEIGHT ON THIS MONITOR. MY IMAGE IS BIG AT THE TOP (STRETCHED) AND SQUASHED TOWARDS THE BOTTOM. IT SHAKES SLIGHTING BUT CONTINUOSLY. HELP ME TECHMAN OR ANYBODY. DONT SEEM TO FIND A FAULTY COMPONENT.
This is a very common problem with this Dell model that's actually made by Samsung. Cause is bad deflection processor IC TDA9302. As the problem ususlly gets worse as the monitor warms up, you can try to verify by chilling the IC with freeze spray.
Posted on Sep 07, 2007
    President:
  • 3,130 Answers
Like I said last night cobra there is a vert shaper cap off the jungle/drive ic usually a smaller value and will check good but its bad. Or the b+ filter cap off the fly has caused sysmtoms like this as well. Good Luck
Posted on Apr 14, 2006
Our Panasonic model PTH 3778R has elongated its vertical size about 2 inches outside the screen limit. Is there a way of adjusting the vertical size?
Usually this means that a cap in the vertical circuit is starting to fail. Are there any other symptoms at all? Does the height seem stretched more at the top?
Dan
May 09, 2008 | Televison & Video
Top of screen disappeared...cant see score of game
The Height adjustment is off... look in the back of the TV set, it has some knobs in the back, one should be vert.lin for Vertical Linearity adjustment, and there is another call Vert.Hgt. for Vertical Height adjustment. try adjusting the Vertical Height first with someone watching in the front of the big TV to see if the top comes back into view, you might have to adjust the knob very slowly one way then the other way, to make this adjustment. If it doesnot adjust take it to a TV shop to get it repaired.
Good Luck.
Nov 11, 2010 | Hitachi 57F500 57" Rear Projection...
Unable to adjust the settings for brightness and contrast .
To adjust the display settings:
1. Press the flywheel control. The main menu appears.
The current display settings appear across the top of the main menu.
2. Rotate the flywheel to highlight an option. The name of the
highlighted option appears in the center of the menu.
3. Press the flywheel control to select the highlighted option, then
rotate the flywheel to adjust it.
Some options can only be enabled or disabled. There are also some
options that contain additional menus.
4. Repeat Steps 2 and 3 until you have made all your changes.
5. Rotate the flywheel control until Exit is highlighted, then press
it to exit the OSD control system.
OSD OPTIONS:
Contrast increases or decreases display image contrast.
Brightness increases or decreases display image brightness.
Horizontal Size increases or decreases the width of the display image.
Horizontal Position moves display image to the left or right side of
the screen.
Vertical Size increases or decreases the height of the display image.
Vertical Position moves display image to the top or bottom of the
screen,
Pincushion curves the sides of the display image inward or outward.
Trapezoid increases or decreases the trapezoid distortion of the
display image.
Degauss removes magnetic discoloration from the display image.
Recall returns most options to the original factory default settings
if the monitor is currently using a preset video mode. (See the “Video
modes” section in this guide for information about the factory preset
modes.)
Advanced Option opens the Advanced Option menu. Color opens the Color
Manager menu.
Language changes the display language for the OSD control system.
User displays information about the monitor’s preset modes.
OSD Manager moves the OSD control window on the screen.
Exit closes OSD control system.
Jun 21, 2010 | Gateway EV 910 19" CRT Monitor
The view on my monitor is very truncated - about two inches top and bottom are not filled
Press the MENU button on the monitor and adjust the width and height of the picture to full screen.
Oct 10, 2009 | LG Computers & Internet
The screen is stretched there is nothing distorted
What kind of monitor? They can all be adjusted for width and height by using the buttons along the bottom of the screen. Often it can be confusing and a bit of a pain but look under the monitor menu for 2 sets of icons that look like 2 boxes on top of each other both horizontal and vertical. That is how you adjust it.
May 29, 2009 | Acer AL2216WBD LCD Monitor
Picture not filling monitor screen
what is your sceen resolution set at on your laptop. try adjusting them and see if that works.
mj
Nov 01, 2008 | Samsung Syncmaster 730B 17" Flat Panel LCD...
CRT Monitor and
The pot (variable resistor / preset on the circuit board inside the monitor) in the horizontal sync section needs cleaning, replacing & adjusting. but before that try the horizontal adj on the front panel of the monitor. Every monitor (digital or analogue) has it. Only if it doesn't clear the problem, try opening the monitor. Be careful so as not o venture too close to the EHT transformer.
Also make sure to degauze the CRT by earthing it (after switching it OFF) before toching any components inside. Also when you adjust the preset, make sure to use a highly insulated flat screw driver and wear heavily insulated rubber / PVC soled shoes because you'll have to adjust it with the monitor Powered ONonly then you'll be able to see the results. For your convenience, put a mirror in front of your monitor when you adjust the preset on the circuit board. Also make sure that you don't turn the preset very fast or put excess pressure on it as it may brea causing further damage to the circuit board.
Better still, if you don't wish to go deep into all this stuff, get it repaired by an authorised technician.
May 05, 2008 | Computers & Internet
Adjusting vertical height
I looked for info for your the Mct-2051 & imagine my surprise that Magnasonic not only doesn't have a manual for your model they don't recognize the model #. Excuse my sarcasm.
If MCT-2051 is not a typo, then the closest I could find was an MCT-2053 & there was no mention of a vertical height adjustment by software control. From my past experience this adjustment can only be performed by a TV tech because you need to access the inside of the TV.
The fact the picture has shrunk this much means that the vertical height driver is failing & eventually you will see nothing but a vertical line, stretched across the screen. Which will mean, that do to Magnasonics' lack of support, you'll be out of luck.
When shopping in the future for a TV try to stay with name brands who will support their products.
By the way, where did you hear that you could adjust the VH utilizing the remote? That could possibly be a function of digital device like a computer monitor, not an analog device like your TV.
Feb 25, 2008 | Televison & Video
STRETCHED IMAGE
if its stretched from top to bottom your gonna need to go inside and find the verticale height control -and adjust it.
Apr 12, 2006 | Dell M570 15" CRT Monitor
Dell 828FI 15" CRT Monitor Logo
222 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
