Question about HP LaserJet 1100 Printer
HP LaserJet 1100 to print from new MacBook Pro running Mac OS X 10.5.4
Hello problem solvers:
Bought parallel cable and mini-Centronics adapter to connect HP LaserJet 1100 Printer with new MacBook Pro running Mac OS X 10.5.4. Tried to install drivers recommended by http://www.electrictao.net/mac.shtml (had difficulty w/some instructions as they were probably written for older version OS X like Tiger) but one or two pages eventurally printed and then it stopped cold. Received message (paraphrase): Generic warning class: Looking for device. How can I get consistent, multiple prints just as I do/did when it was connected to old (once reliable, but no longer) Dell?
A step-by-step guide would be most appreciated, but any and all help is welcome!
Best, Joan S
  • mohammad shabbirgill Nov 11, 2008
    i have the similar problem, same printer and similar version of Mac Os X 10.5.4 system. since one month each and every driver download and even "use a printer attached to a windows Xp computer in Mac Os X". I have developed sores on back for the last one month. As mentioned in the above post simply attaching HP 1100 through USB and what kind of drivers are needed to run this workhorse of its time.
3 Suggested Answers
fossildude
  • 832 Answers
SOURCE: Print Job enter's queue, but doesn't actually print.
hi thanks for using fixya!
Do you have 32bit or 64bit system?
Posted on Mar 24, 2009
muntejaya
  • 10421 Answers
SOURCE: Unable to get an HP
Please get it downloaded here :
www.hp.com/cposupport/eschome.htm
www.brothersoft.com/downloads/hp-printer-driver.html
www.downloadatoz.com/driver/
Jay pmnvbcrt
Posted on Feb 14, 2011
Keyboard Backlit not coming on at all
Set your backlighting in
Apple menu
System Preferences
Keyboard.
otherwise try:
Resetting the SMC on any type of Mac (and any version of OS X) and the type of problems that it may resolve.
When & Why Reset SMC on a Mac? Some Common Hardware Reasons
Typically it's power and hardware related issues that can be helped or resolved by resetting a Mac SMC, particularly if you're having these types of problems:
* Issues with your Mac's cooling fans and fan management: fans run constantly at high speed, fans run high despite low CPU usage and adequate ventilation, fans not working at all, etc
* Power management and battery problems: Mac isn't turning on, sleep isn't working, random shutdowns and reboots, battery isn't charging, Mac won't wake from sleep etc
* Light problems and improper lighting management: battery indicator lights aren't working, display backlighting isn't adjusting to ambient light changes, keyboard backlights not working, etc
* Video and external displays not working: display brightness functionality not working properly, target video mode isn't working properly, external display isn't working, etc
* General performance and functionality problems: abnormally sluggish behavior despite no CPU or disk usage, external ports not working, airport & bluetooth aren't showing up, external devices are not being found, etc
So now that you've concluded you need to reset your SMC (Note that the SMC is on Intel Mac's only), here's how to do it on MacBook's, MacBook Pro's, iMac's, Mac Mini's, and Mac Pro's. Notice that the reset instructions are different for MacBook and MacBook Pro's if you have an internal or detachable battery.
Reset SMC of a MacBook Air, MacBook Pro Retina, or MacBook Pro's with an internal non-removable battery
This is how to reset SMC on most modern Mac laptops:
Shutdown your MacBook Air / MacBook Pro
Connect the power adapter to your Mac
On the MacBook/Pro's keyboard, hold down the Shift+Control+Option keys and the Power button at the same time
Release all keys and the power button at the same time
Boot your Mac as usual
Here's the key sequence to hold down:
Reset the SMC of a MacBook Air or Retina MacBook Pro
Do keep in mind that by resetting the SMC you will lose power specific settings, like the time it takes to sleep a Mac and other customizations to power settings. No big deal, but if you have made many changes to your hardware behavior you will want to adjust stuff like sleep behavior again.
Reset SMC of an iMac, Mac Pro, Mac Mini
Resetting SMC is different for non-portable Macs:
Shut down your Mac
Disconnect the power cord
Press and hold the Mac's power button for 5 seconds
Release the button
Reattach the power cables and boot the Mac as usual
Reset the SMC of a MacBook or MacBook Pro's with detachable batteries
mac reset the smc Older MacBook laptops with a removable battery can reset SMC with the following approach:
Shutdown the MacBook/Pro and remove the battery
Disconnect the power adapter, hold the Power Key for 10 seconds
Release the power key and reconnect your battery and power adapter
Turn your Mac on
Let boot as usual
Hopefully that will clear up your problems, if not it might be worth a visit to the Apple Store or a certified repair center.
Happy New Year,
Kerry
Jul 08, 2012 | Apple MacBook Air
I am a new macbook pro owner. My new mac will not recognize my external wd mybook which is several years old. What do I do?
Hello!!
The MAC is not recognizing HDD because it may not be in FAT or MAC OS X Journeled Format.
Please Follow below steps to Reformat the HDD to make it Compatible with MAC.
1. Connect the HDD.
2. Open Disk Utility from Applications -> Utilities
3. On left side of Disk Utility you'll find your HDD.
4. Click on HDD and select the Format TAB.
5. Reformat the HDD in FAT Format.
6. Click Apply.
7. Done.
Hope it Helps..!!
Jul 07, 2011 | Apple MACBOOK PRO WITH PARALLELS NOTEBOOK...
I have a 24" aoc 2436Vh display and a new 15"
I purchased the AOC 2436Vh display yesterday. To get my MacBook Pro to work with it I purchased Apple's Mini DisplayPort to VGA Adapter. Since the monitor comes with the VGA cable, all you need is the adapter to plug it into your MacBook Pro. It works beautifully and set up is easy if you know your way around the Mac. Although the HDMI works perfectly with my PS3, I strongly recommend the Apple Mini DisplayPort to VGA adapter. I hope this helps.
Nov 11, 2010 | Computers & Internet
Need OSX Snow Leopard Driver for Laserjet 1018. Have MacBook Pro 13".
This is the best solution for that problem and works perfectly...
http://blog.ragnarson.com/2010/01/mac-and-hp-laserjet-1018.html
Feb 09, 2010 | Apple MacBook Pro MB991LL/A 13.3-Inch...
Naturally Speaking 10 for Windows usable on a Macbook?
check NS website for appilcable mac options
Jul 09, 2009 | Computers & Internet
MD5000 to MACBOOK PRO problem
MAC is NOT my forte... however, I do know that ALPS offered THIS a few years after the MD5000 came out:
USB Interface Kit for the iMac OS V8.01 and Windows ($99)
You might find it on ebay etc. and be able to use it (no support with this printer on OS X!).
Apr 08, 2009 | Alps MD 5000 Thermal Printer
Connecting an HPLJ 4 to a iMac
i think my friend that there is no solution for your problem...
i heared this problem a lot o f time...but noone can fix it...
i think that hp fault for this problem..
these printers are problematic
Jul 28, 2008 | HP Color LaserJet 2600n Printer
HP1100
I am currently using this print server with the HP Laserjet 1100 on the parallel port and it works flawlessly.
Jan 15, 2008 | D-Link DP-G321 Print Server
Connect to usb on laptop
The Easy affordable solution:
www.sewelldirect.com or (801)356-3823
* USB to Parallel Adapter, part # SW-1302 ($14.95) + * Centronics to Mini Centronics, Part # SW-2104 ($12.95).
I ordered before 2pm EST and received two days later.
Plug usb into computer, wait, then plug in printer. Voila! Instantly worked!!
PS: Found this site after www.monoprice.com Product ID: 2277 (parallel to USB) and ID 257 (male to mini) - $15
Oct 24, 2007 | HP LaserJet 1100 Printer
HP LaserJet 1100 Printer Logo
416 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
