Question about RCA P52926 52" Rear Projection Television
What is the location of the fuse. The board that has the fuse will have markings for location, ie f470 or something to that effect near the fuse usually it will also say what the value of the fuse that belongs there, 2 amp or 5 amp and also the voltage. If you have the set open look at the board underneath or on the top and it should note the fuse you need. Glass fuses are GMA fuses and solder in type fuses are called pico fuses
Posted on Sep 24, 2008
Rca projection tv p52939 fuse locations
These sets are well known for Bad High Voltage Trippler and Bad FBT Flyback Transfomers.
Oct 18, 2011 | RCA P52929 52" Rear Projection Television
P52929-----ctc195s1--------chirping sound
The Horizontal output and Flyback are the two main causes of that symptom. You can get the repair kit from
Jun 19, 2010 | RCA P52929 52" Rear Projection Television
Hi I have an RCA TV Model# P52929 that is not turning on for me at all what so ever.
FBT flyback Transfomer 239111 Ck your hori output Transistor also. Call Mats Electronics for Parts 1-800-628-1118
Dec 21, 2009 | RCA P52929 52" Rear Projection Television
My big screen was working and then just turned off and all i get is a click from the power box what do i do to fix this and what parts do i need it is a 52" rca tv model P52929 i really like my tv and dont...
The cicking sound comes from the relay starter . Its like a Fluro tube starter.It is tying to start but because it is damaged can only witch on and off without firing up the display. There may be other parts associated with this when it fails and is not really a DIY job if you are not into electronics
Aug 27, 2009 | RCA P52929 52" Rear Projection Television
Is there a simple fix for my projection rca P52929 ? It wont hold a channel and the picture rolls after about 15 minutes
is the reception clear? if yes only rolling picture. check the vertical section for leak capacitor or change value resistor.
Aug 11, 2009 | Televison & Video
RCA P52929 changes channel non stop
try unplugging it from the electric wall outlet for an hour then plug back in, this should reset your tv back to factory default, you will have to adjust your setings if you changed them
Jan 25, 2009 | RCA P52929 52" Rear Projection Television
Picture is warped. rca 52 inch model p52929
This is hte beginning of a convergence problem. If you can solder, try resoldering the pins on the convergence ICs. These are large black ICs attached to a heat sink and will be marked STKxxx. If that fails to resolve the problem, replace the ICs.
Keep us posted.
Aug 25, 2008 | RCA P52929 52" Rear Projection Television
NO POWER, Yes blown fuse.
Was this the 220 ohm in the power supply??? and if the 5 amp blew right away then it probably took out the bridge rectifyer with the power surge that comes alog with hurricane damage to the power lines as I used to live in florida and repaired lots of sets damaged from storms!! After you check the bridge rectifyers I would start looking to find any other shorts. First measure across the ac line with the fuse replaced but not plugedf in . If its shorted check what I mentioned before if its good after you replace the shorted parts you maybe in luck. need more assistance go to sams photo facts download a schematic and we will trouble shoot this together if you post it here so i can look at it. good luck
May 02, 2006 | RCA P52929 52" Rear Projection Television
RCA P52926 52" Rear Projection Television Logo
336 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
