Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
Doesn't spin the clothes
The washing machine is not spinning the  clothes so they are soaking wet at the end. It seems to fill with water -- say it is washing but there is no action at all in the machine.  Then it says it is draining and it does.  Then it says rinsing and it fills with water and sits again.  then it drains but doesn't spin and then it say remove laundry.
  • 1,462 Answers
Take rear panel off, disconnect plug and socket electrical connections to motor and remove belt. undo bolts that hold motor and remove. check motor brushes as this is the most likely cause of the fault
Posted on Sep 11, 2008
Ge washing machine fills up with water on spin cycle
Sounds like the timer is screwed... Sending out the wrong signals and the dryer is doing the rinse cycle when it should just be the spin cycle. Do t know what your timer looks like in that washer but most now days look like the picture. 11_11_2013_2_52_52_am.png
Aug 16, 2013 | Washing Machines
Washer will not spin at all no code . will drain and tumble back and forth,when it comes time to spin it turns off.
A washing machine is basically a big tub that repeatedly fills with water and then drains, spins to wring clothes dry, and has a device for stirring things up-- either an agitator in the middle of a top-load machine or a rolling drum in the case of a front-loader.
The four cycles that every washer performs are fill, wash, drain, and spin. Though these functions are pretty basic, a number of things can go wrong with them.
There are a number of problems that you can fix quite simply; some issues, however, are better left in the hands of an appliance repairperson.Problems that commonly occur with a clothes washer are discussed in depth below.If your washer doesn't run, be sure it's plugged in and that the receptacle works (the circuit hasn't overloaded). Before working on the washing machine, be sure to unplug it.
To prevent problems, follow good maintenance procedures. Use the right amount of detergent for your washer and your water hardness, make sure the machine is level, and don't overload it for the cycle chosen.
Washing Machine Does Not Fill
If the washer doesn't fill, the water inlet screens may be blocked. Clean or replace them. (Check your owner's manual for the location of the screens; they're often located at one end of the supply hoses, or you may have to remove a panel to access them.) Other reasons for not filling may be that either the timer or temperature selector is broken--both of these are repairs for an appliance repairperson.
Washer Does Not Spin
If your washer doesn't spin, check to see if the clothes have jammed or are unbalanced in the drum before calling a repairperson. Unbalanced clothes will also cause a w
asher to shudder or "walk." If straightening out the load doesn't stop the washer from shaking, look at the feet underneath and be sure they are properly adjusted to keep the washer sitting level on the floor (you just turn them to move them up or down).
Clothes Are Wet After Spin Cycle
If your clothes remain wet after your washer's spin cycle, perform the following diagnostics:
1) Lift the lid during the spin cycle. If the tub is not spinning, you may have a damaged motor coupler. Call a repairperson to replace this part.
2) If the tub is spinning, recheck the load to make sure it is balanced. If you are certain the load is balanced but your clothes are still wet, you may need to call a repairperson to replace a damaged motor pulley, tub bearing, belt, or clutch.
3) You can also follow the troubleshooting steps outlined in "Washing Machine Doesn't Drain." You may have a problem with your drain hose or pump.
Oct 27, 2011 | Washing Machines
The washer won't spin dry. It fills and empties but the clothes are soaking wet.
If washer is spinning but clothes are wet suspect a partial blockage in the outlet pipe. This will cause the water to drain to slow and leave some in the outer drum while spin occurs but this ends up back in the clothes.
Feb 25, 2010 | Washing Machines
Clothes are not completely rinsed (they're soaking wet) at very end of spin cycle.
Try to fill minimum water level in your machine with out adding detergent or clothes and complete cycle and see if it is any watter inside. Could be a water pump.
Dec 29, 2009 | Roper RAX7244KQ Top Load Washer
I have a Kenmore frontloading washer, model no. 417.42042100. At the end of the wash cycle, the clothes are still very wet; that is, still SOAKED with water, even though all the water has been drained...
HI. your unit is equipped with a spin control board. this board, if damaged, will not initiate an adequate spin. This will not allow for proper drainage and drying of the clothes. The spin motor regulates the rotation speed during the spin cycle. It seems to be the culprit at this time. Have the spin board replaced asap.
This part will usually cost around $150.00 at the most.
Aug 27, 2009 | Kenmore Washing Machines
My clothe come out very wet at the end of the wash cycle
If the pump is clogged and can't release all the water it won't go into final high spin. Remove lower cover and locate coin catch and unscrew it. Water will come out, so be ready. If it's full of stuff, this is probably the problem.
Mar 13, 2009 | Kenmore HE2 Plus Front Load Washer
Spins fine, but clothes still soaking wet
Clogged water pump. Not draing fast enough. If this is helpful, please post as such.
Feb 21, 2009 | Maytag Performa PAV2200
Whirpool Duet Was. WFW9400SZ01--Spin cycle leaves clothes soaked.
the problem is your spin program is normal but the machine could not do its job usually there is broken pin clucth under the spinning tube and sometimes the spin gear.this is due to overlload problem. you should brought the machine to your trusted machine repairer as this cost you around US 100-200 in comparison if you buy new one
Sep 25, 2017 | Whirlpool Washing Machines
GE Front Loading Washing Machine seems to be holding water....
The high speed spin of a front load washer should normally do a good job of getting squeezing out the water but if there is an oversudsing condition that makes it hard for the drain pump to operate then the suds and water will just stay there. First make sure there is no actual clog in the drain line then run a load with no soap or detergent and see what happens. It's always better to use a low suds detergent with this type of machine
Mar 08, 2008 | GE WSXH208A Front Load Washer
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
238 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
