SOURCE: PROTECT message display on JVC HX-D7 DVD Stero Player and turn off
I had the same problem with a jvc stereo set, it turned out the two cables of a speaker were touching each other.
How do i fix that i get the message on my cd play (JVC HX-D7) and it says PROTECT and shuts off by its self what do i do to fix the problem ?
SOURCE: my jvc hx-d7 radio is turned on in 2 seconds it
You can't. The main amplifier module will probably have a channel blown. The unit is detecting this and tripping into protect mode to stop further damage occurring. Needs to go to a repair place. sorry. ps If you get sound briefly before it trips off then it may just be a speaker wire shorting out! worth checking
SOURCE: I turn on my JVC HX-D7 and will stay on
It sounds like you have a short. Check that your speaker wires are not crossed at any point. If no look into the connections and see if some wire has broken off into one and caused a short.
SOURCE: When I turn mine on it will power up then go into
unhook all the wires and turn off the stereo (unplug the chord) plug it in again and turn it on not hooking the speaker wires yet. check if the stereo will come on if it does then unhook the plug again and hook the speaker wires before plugging it into the outlet then you are set to go.
That could meen that something is improperly connected. You should try to disconnect everything, and then reconnect it step by step.
