Question about GE GSS22JFMWW Side by Side Refrigerator
Ge gss20Iembww evap fan inop.
Evap freezing up, clip on switch at top of evap clicking excessively after freeze up, fan will not com on, low side pressure at 15-20 psi, high side peaks at 350-400psi and will keep rising if not unplugged.
    Novelist:
  • 166 Answers
How old is your fridge?
Posted on Sep 11, 2008
If the evap coil is blocked, what readings will I see on the low and high sides? Seems after 5 minutes with a/c or def on, the fan "slows"down, I put to vents, and the fan seems to speed up, like on a...
if you think it's freezing then you can see it at the dryer low pressure
when it freeze a/c compressor clutch is engage all the time and if evap is block from freeze air flow will be less almost nothing
it could be cause by low cycling switch the variable orifice tube
Oct 07, 2013 | 2004 Chevrolet Blazer
Have a gdn-49 true freezer freezing in evap to compressor what could be the problems
low refrigerant, leak, evap fan inop, thermostat inop.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 02, 2010 | True 49 cu. ft. / 1388 liter Commercial...
DEFROST PROBLEM
you said a mouth full . any of the 3 would cause freeze up.. so make sure the inside fan (evap fan is working ) . if unit is newer one the control in side fresh food may be bad and the sensor in the freezer. if it does not sense tempt properly the compressor run time is too long causing freeze up . now some times new components fail so ck them . . clean the bottom coils . and make sure the bottom fan is cooling the coils .. mm
Jul 29, 2010 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
GE GSH22KGM Frig not defrosting again
I would suggest replacing the # 4 thermistor , which is a 1 " long white piece with 2 white wires attached , clipped to the top of the coils . This thermistor , tells the main control board , the temperature of the coils and the board decides what to do next , such as defrost , end defrost cycle . Also , replace the defrost thermostat , the 1 inch cylinder with 2 wires going to it , which is also clipped onto the coils . This thermostat , cuts the heater off when it reaches a certain temperature , to keep the food from defrosting . It may also help , to replace the # 5 thermistor , which is below the coils , slid into a housing , with 2 white wires going to it also . This thermistor , tells the board , the actual freezer temp , so the compressor will cycle off/on , and the fan speed also . All 3 parts , are relatively not expensive . Be sure to get wire connectors because they do not come with these parts .
Apr 14, 2010 | GE GSH22KGM Side by Side Refrigerator
Evap fan stops running/low cooling, Unplug Frig Evap fan runs
Is there anything obstructing the fan area, ice build up ? It is normal for your freezer to get warm if evap fan is not working, it is essential for it to work :) A defrost cycle should kick on a timer or as needed (adaptive) and there should not be excessive frost buildup that it blocks your evap fan. I would have suggested you unplug your refrigerator for about 10 minutes and see if that resets your control board - if not, then you will need service - either replacing motor assembly or a faulty control board.
Aug 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
If the compressor runs continually will it burn itself out?
how hot is the top of the compressor head?is unit cooling/freezing o.k? if not cleal both coils(cond&evap)dirty coils or poor cooling could be coils or low on freon(refrigerant)
Aug 15, 2009 | GE Profile¿ 26.5 Cu. Ft. Stainless...
Everything in freezer defrosted
the defrost has a timmer you mite have to chang it ok
May 14, 2009 | GE GSS25SGMBS Side by Side Refrigerator
I have a Ge PSW26LSRDSS side by side the water line freezes
The water line keeps freezing going to the ice maker? The line in the freezer? Is there alot of ice build up around the fan because of this? If so, it sounds like an ice maker malfunction is the root of the problem, and that can cause evap fans to go bad.
Mar 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My firdge is operating, but not cool nor freezing
Did he check it out and make sure its bad... these ge models are tricky... sometimes they take out the mother board with a bad evap fan motor.. seems like it should still be his problem to help fix, if his repair didnt solve the problem
Aug 28, 2007 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
GE GSS22JFMWW Side by Side Refrigerator Logo
173 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
