Question about GE Washing Machines
My wife was washing clothes in our just missed the warrinty by about 2months, and the thing stopped in the middle of a cycle and started to fill again what is happening?
  • john gagnon
    john gagnon May 11, 2010
    what make & model please
  • 943 Answers
HI thanks for the question The problem could be as simple as a drain hose to low to the ground this coudd cause a siphoning and let the water drain away & stop and fill again to the water level you have selected thanks THE APPLIANCE DOC
Posted on Sep 13, 2008
Washing machine starts agitating before fill
Pressure switch stuck you can pop the hose off the switch and blow thru hose it may reset and fill correctly before agitation will eventually stick again.
Jan 12, 2014 | Maytag Washing Machines
Timer is loose, stopped working; basket filled with water, then stops.
try checking if the tube that drains the water is not clogged with something such as a small sock.
Mar 24, 2013 | Washing Machines
There is black residue left on the clothes after the spins cycle! It looks like soil? I have unscrewed the long thing in the middle and washed it clean but still the clothes aren't coming out 2 clean....
Hi just read your posting.Now select hot fill, high water level,and put 2 pkts of bicarb of soda in the empty tub.Start the cycle and let it fill and then let the machine wash for 5 to 10 mins.Do not let the water drain out.After 5 to 10 mins stop the cycle and let the water and bicarb soak over night.In the morning restart machine and this should clean the bowl.Please reply on how you got on or for further help.Looking forward to your reply.
Jun 19, 2011 | Washing Machines
The rinse cycle does not work, but everything else does
I don't know if the problem is solved but last night we ran the washer without any clothes in it and everything seemed to work fine. My wife was able to run a load of laundry and it seemed to work. I hope it was just too much clothes the first time it stopped or the washer was just acting up. Either way, I had nothing to do with the fix. Sorry I couldn't be any more help. Thank you for the link to assistance plan, it might come in handy in the future.
Thanks again,
Sandro Micocci
Mar 30, 2009 | Kenmore Washing Machines
Frigidaire FTF530F won't advance
Possibly the timer. next time it wont stop filling turn off the washer. if it still fills you have a water valve issue. Hope for the valve. Timers are big bucks.
Jan 24, 2009 | Frigidaire FTF530FS Front Load Washer
WHIRLPOOL ELECTRIC WASHER STOPPED WORKING MIDWASH BC OF OVERLOAD?
My wife did the same thing,trying to do all the laundry at one time.Even if it says high load compasity it will only handle so much.sounds like you killed your motor.Hope this helped.
For more help go to live chat.
lenwest
Jan 10, 2009 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
The Maytag top loader washer MAV7750BGW started to fill at the beginning of the washing cycle then stopped. Could not get it to do anything on any other cycle steps. Electrical supply OK. Managed to get...
It sounds like you have a lid switch problem. Check your the lid on your washer and see if it's not bent towards the middle. Often as things get sat on top, it will bend and not allow the switch to make contact. The washer doesn't do anything but fill when the machine thinks the lid is open. Try bending the middle of the lid back to where it is straight.
Jun 18, 2008 | Maytag Washing Machines
Washer fill with water after final spin cycle
CHECK THE TIMER MODULE ,the one you pull and push to start and to stop ,that could be damaged , try different cycles , like DELICATES cycle , see what happens, hope it helps AJ
May 05, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
20 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
