Question about GE Refrigerators
New board installed runs all the time - GE Refrigerators
    Novelist:
  • 166 Answers
Bobm1,
ngafm at your service,
You have a new board installed and it runs all the time?
Sounds like the thermostat is malfunctioning as the compressor is not cycling off and on!
You need a hands on dignoses.
Bless you,
ngafm
Please rate me before you sign off.
Thank you
Posted on Sep 11, 2008
Starter runs all the time with key on or off.
I had the same problem with my John Deere F725. On mine there is a small circuit board that contains the starting relay for the starter. This part can get damaged or overheated when the voltage on the battery during starting is low. By the time I realized what was happening I had burned out the starter too. I installed a new circuit board and starter and she's good as new. Good luck.
May 09, 2016 | Garden
How to remove power running boards on a 2007 cadillac escalade esv
You are better off Getting some Mechanic Wire and removing the 8 bolts holding the Front of the Running Boards and having it repaired or replaced. I would recommend not using the Running board on that side, you can do that by Climbing under and disconnecting the Plug to the Motor. I would also put a BAG over the 2 connectors and protect them. You can even put a dielectric to keep the Water Out.... Order the Bracket and install the new one at the same time... SAve you time and Effort.
Apr 05, 2013 | 2007 Cadillac Escalade Ext
CPU runs at 100% a lot of the time, mainly when opening internet files, freezing the system and causing the fan to kick in for long periods. I have removed as many programmes as possible and increased my...
It can be possible that the CPU and the mother board has some conflicts .If all unwanted programs were taken off , the OS was installed fresh, an antivirus was installed and the drivers installed then , the system must run well. If not cross check the CPU and the board as your memory is new. Does the CPU/board support the memory.
You have not mentioned make/model
Sep 30, 2010 | Compaq Computers & Internet
When I close the door to the mircowave the light stays on and the fan continues to run?
Assuming that the time has expired, you have a problem with the control board in the unit. You can get parts at www.repairclinic.com . To install the board, unplug unit, remove the cover. Remove all mounting screws and cable connectors on the old board. Install new unit and reassemble. You should have the problem solved. Let me know if you need more information.
hardrocko
Thanks for using FixYa
Feb 26, 2010 | GE Microwave Ovens
Mother board
USB not working its mean driver correpted. BEfore change *********** board uninstalled all the external driver and restart system. then use your driver cd for run again. Or format your system and installed it again . Hope you no need to buy new mother board. Some time these happend for driver file corraption.
Jan 29, 2010 | Averatec 3200 Notebook
New mother board installed and new battery still does not recongize battery. Must run with Ac adapter all the time.
Its obvious the problem is in the power supply of the laptop or the Dc controller, board and battery has nothing to do with that part.
Oct 04, 2009 | HP Compaq nx7300 Notebook
Can't stop timing buzzer from ringing.
remove buzzer from board if all still runs well or new pc.board is to be installed.
Sep 14, 2009 | GE Microwave Ovens
Brand new unit will not run
You have a bad control board from the onset. This happens sometimes, I have had issues like this before.
Apr 11, 2009 | Ruud Handler Air Conditioner
Fujitsu air con fault (new system)
steve, first look at the manual if really it is stated in there that the three blinks indicates an o.u. pcb. second, do you install them yourselves?. im not sure regarding warranty if you install them. normally there should be a qualified installer to install it to cover warranty. again if you install them yourself, double check the wires that goes to the outside unit. make sure each wire goes to its corresponding location. any mis-wiring would may also indicate a 3 blink alarm. if its covered in warranty. they should shoulder the expense if it needs board replacement. i hope i was able to solve your problem.. tnx
Feb 14, 2008 | Heating & Cooling
Refrigerators Logo
52 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
