Simpletech 320gig hard drive crashed?
Been working fine for months. Today the desktop shortcut was a red "?" and now my computer will not even see it. It turns on (red light is on) and blue lights on top just flash for a moment where they used to flash in a circle.
There was a thunder/lightning storm the day before it stopped working. Could a surge have damaged it? I have TONS of photos on this baby and am scared I will not be able to get them back.
HELP!!!!!!!!!!!!!!!!!
  • Anonymous Dec 03, 2008
    I don't think this is a lightning issue as this just happened to me as well and there was no lightning or power surge in my area
    Sergeant:
  • 300 Answers
I like ones like you who already understand that a lightening power surge can really kill the computers will to live lol
1. always put the computer on a surge protection strip or even better a UPS backup device to protect it from surges , and in the case of brownout the UPS backup would take care of that circumstance
or at least some kind of VR , voltage regulator ... not that computer powersupplies do not protect the PC , the PC powersupplies of today to have some built in protections , but ooops there went your power supply anyway if you know what I mean.
2. if you suspect the power supply is the culprit , you can test by using another power supply
which is a good investment because if it was the power supply you just got yourself a nice new one
and even if it's not the power supply , you still have a nice new one in your hand
a power supply in the hand is worth two in the bush :-> lol
and if it's the motherboards fault , at least you'll already have your nice new power supply for that new motherboard you get.
a good strong power supply is a good investment no matter how you slice it.
I always keep any spare power supplies I get , because you can use them while your dead power supply is being RMA-ed or sent back. ,, that time gap is not fun lol
shalom
Posted on Sep 11, 2008
I dropped my Simpletech 250 gb external drive for several times, now when i plugged in to my pc the red light is on but the blue light is not coming out, and i cannot see the external drive in my pc, how...
Take out the hard disk from your case and put it inside a desktop- if there's still some life left in it it will appear in My Computer. If it doesn't appears even there then it's dead for sure and all the data on it is lost.
Jan 30, 2011 | SimpleTech 250GB USB2.0 7200 RPM External...
Six month old Simpletech 500 GB ext. drive not recognized
I had the exact same problem. Solved by removing Simpletech drive from the 'flashy-box'. Unplugged drive from internals and threw the 'Pinnaferrina' case away and installed it on my motherboards extra sata plugin site (if it has one). If you open your computer case it should be labled on the Motherboeard as such. Mine has four. On the first attempt when I started the computer i Had no OS system showing on first boot-up. Shut off computer and power and shifted SATA (RED Cable) to another Sata plug on Motherboard and it booted right up and I had the drive back. You will need a longer Sata cable than the attached to the Simpletech drive and a power cable that matches the one on the Simletech . Forget looking for the drivers on the net and the Simpletech web site was no use.
Oct 10, 2009 | SimpleTech 500GB SIMPLEDRIVE EXT HD-USB...
SimpleTech 500 GB external hard blinking red light
I got one with the same problem. I opened up the case and hooked up the hard drive to a generic usb to sata adapter that i picked up on ebay and it works fine now if a bit clunky looking.
Sep 10, 2009 | SimpleTech 500GB SimpleDrive Pro External...
500Gb SimpleTech Ext Drive No Power
Hello.
It sounds like you might have a problem with the power supply.
I have seen MANY external hard drives with failing power supplies. Take it to the store you purchased it from for a check up, it should still be under warrantee if its only 3 months old.
Good Luck!
Jun 17, 2009 | SimpleTech SimpleDrive Pininfarina 500GB...
External HD not recognizing USB ports as being Hi-speed ports
I have the same issue. I have 4 Simpletech Signature 250GB drives. They all worked fine at first. After about six months two of them started connecting at USB 1 speeds. It occurs on 4 different computers!!! The post about it being the computer assumes is wrong. How can it work fine for six months and then suddenly change. Also it occurs on different computers. I have submitted a tech support request with simpletech and will post the results.
Jun 14, 2009 | SimpleTech Signature Mini 160GB External...
Simpletech 500 GB external hard drive - unresponsive
If you really can not get it to work anymore, you could try opening it up and connecting the hdd directly on a IDE/SATA port in your computer. This will only work if you have a desktop, for a laptop you would need all kinds of converters.
May 03, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
SimpleTech 3.5inch 250 gb wont start up.
Contact simpletech about a product replacement if you believe that the item is defective. I had the same problem and they had got me a new one FREE of charge.
Jan 24, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Computer not seeing the external Hard drive
try the drive on another pc - if you sill cant see it, you may have had drive head crash in the new drive and that is a write off.
Aug 16, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
My 320gig Simpletech Black cherry signature mini hard drive isn't being recognized by my computer. I have tried using the hard drive on a desktop computer and it still doesn't work. I have a lot of...
Try using the included USB power cable to make sure the hard drive is getting enough juice. If that doesn't work, then try getting a power adapter to plug into the back of it, just make sure it is the right voltage for the hard drive. You can usually find the voltage written on the back of the hard drive where the plug-in is for the adapter or in the user manual, and you can find adapters in electronics stores such as RadioShack or CircutCity.
Aug 08, 2008 | Computers & Internet
Simpletech pininfarina problem
It appears that this is happening a lot with external drives. Inside most of them is just a regular internal drive. In my case I simply removed the drive from the external enclosure (a SimpleTech 160 Gig) and installed it in my PC, where it works like a charm. Most people who have this problem go out and buy a replacement generic external drive enclosure for about $30.00.
Jp
Dec 05, 2007 | SimpleTech Pininfarina 80GB External USB...
Computers & Internet Logo
174 people viewed this question
David Payne
David Payne
