Question about Quasar TP-917 9 in. Television
Quasar TV The TV has a beautiful picture and NO sound. The sound "measurement" is stuck on zero and stays on the screen. The TV remote is absolutely dead - it won't do anything and I've changed the batteries 3 times. Is there a "reset button"? What can I do to fix this? Pleaseeeeeeeeee!! Babs
    Novelist:
  • 130 Answers
Some cable remotes can be reprogramed to control 3 devices. If you have cable try to program the cable tv remote before you buy one. Maybe you can get it to work with your tv. I have programmed mine to work for my tv,and vcr as well as the cable box. There are usualy 2 buttons you hold and it goes into a program mode then you punch in a code that is set for your tv model then you can use basic functions.
Posted on Apr 18, 2006
    President:
  • 3,130 Answers
Is there no buttons on the set to adjust the volume??? I've never seen a tv that didnt have at least under a door somewhere. Do you have an owners manual? You can get a universal remote to get this to work Good Luck!
Posted on Apr 14, 2006
Why did my Quasar TV (1993) picture go out again, blue line across the screen? We had it repaired, 3 months later no picture, same blue line.
Sounds to me like something else is causing those parts to fail. It should be under warranty but depends on the repair shop. Why not just buy a new one.
Here are some choices for a new one:
RCA 42 LED42C45RQ Class LED 1080p 60Hz 3 4 ultra slim HDTV
Why did my Quasar TV 1993 picture go out again blue line across the screen...
LG 24 Class 23 6 Diag LED 720p HDTV Black
RCA LED32G30RQ 32 720p 60Hz Class LED HDTV Walmart com
May 29, 2016 | Quasar Televison & Video
Quasar tv has small screen in bottom right corner any ideas on how to get it off The screen?
Not unless you find with the remote or in the menu it has a PIP or picture in picture feature which is what it sounds like, many you will need the original remote to remove or adjust that--check menu first for CC or closed captions, and if you are using a cable or sat box that also has the CC.
Dec 11, 2012 | Televison & Video
How can i find remote control codes for my quasar tv
Hello
Three digit universal remote codes for Quasar TV are:
003/ 054/ 055/ 062/ 070/ 148/ 149/ 170/ 171
Four digit univeral remote codes for Quasar TV are:
0171 0148 0054 0170 0062 0374 0381 0003 0070
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand. NB: Switch OFF and switch ON your TV, WITH ITS FRONT PANEL POWER CONTROL SWITCH, each time before trying an other code.
OK.
Feb 23, 2011 | Quasar VV-1301 13 in. Combo
Quasar 20yr old color tv sound but no picture, is it repairable
try adjust screen up, in you see horizontal line in bottom, the tv have the vertical ic with cold solder or bad.
Apr 20, 2010 | Quasar SP-2723 27" TV
Volumn inop,remote inop
sounds like the vol down button has stuck try agitating it ..good luck farr64
Apr 29, 2009 | Symphonic ST420FF 20" TV
Quasar combo tv/vcr, blue screen and no sound, I can play my dvd sound and picture, just no tv...help
Thank you, but I have resolved the problem, I read some complaints that sound close and tried plugging in the input jacks from the tv to the converter box and the picture and sound came on...oh what a relief and thankful
Mar 24, 2009 | Quasar SP-2723 27" TV
Tv locked
Enter all Zeros, if that does not work try 1234 or 9999.
Thank you for using Fix Ya!
Good Luck!
If you have any other questions, just let me know!
Don't forget to rate the overall satisfaction of this solution.
Feb 02, 2009 | Quasar SP-3235 32" TV
Quasar TV sp 2724E Loses the picture
Sounds like a failed vertical amplifier circuit. This is normally primarily contained in an integrated circuit mounted on a heatsink.
There are other possibilities along the line but the one above is the most likely.
Now all you need is a TV repair shop that is still in buisness.
Jan 03, 2009 | Quasar SP-2725 27" TV
20 year old Quasar colour TV (no remote)
That is because the switches of the front panel buttons are stuck or defective.
Try first unplugging power for ten minutes, this probably wont work.
To fix this the TV must be taken apart from an expert, and front panel replaced.
You can enquiry here for parts.
What you can do at home, is getting a replacement remote and using TV with a remote, or buying a freeview box, and watching and changing channels through the box.
You can get a replacement remote here: Replacement Remote Control orReplacement Remotes
My suggestion, if it is supported in your area, get a set top box with 30 channels : Freeview - digital TV from Argos.
Oct 11, 2008 | Quasar SP-2723 27" TV
Televison & Video Logo
233 people viewed this question
Top Quasar Televison & Video Experts
Steve Allison
Steve Allison
 Grubhead
Grubhead
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
