Black screen will not boot up, Monitor says that my resolution is too high for it. It flashes a window for the Optimal Resolution which is 1650x1050.
I reseated the RAM dimms and the hard drive and doesn't work. I've also tried resetting the bios by disconnecting the little battery for a few minutes.
Tapping F8 to change the resolution doesn't work. I have Vista Home.
HP pavilion elite m9252p 4G RAM
Base processor
Core 2 Quad Q6700 (K) 2.66 GHz
  • 1066 MHz front side bus
  • Socket 775 Chipset
Intel G33 Express Motherboard
  • Manufacturer: Asus
  • Motherboard Name: IPIBL-LB
  • HP/Compaq motherboard name: Benicia-GL8E
I have an acer aspire5517, when I turn it on i see the windows 7 startup screen, then just all black. After about 30 secondsmy screen savercomes on, as soon as i move the mouse it returns to a black...
might have the resolution set higher than the LCD will display. at boot press F8 select Enable Low Resolution mode, and see if you get a desktop, if you do, then adjust the screen resolution to optimal and reboot
Aug 08, 2011 | Acer Computers & Internet
Iinstaled win xp, now monitor will not work. can i download and install driver onto flash drive without seeing my monitor
Turn your notebook off.
Turn your notebook on, and immediately start pressing the F8 key, once or twice per second,
until you see the Windows "start-up" menu (white text over a black background).
Choose the "start in VGA (low-resolution") mode" (or some wording similar to that).
You computer will start-up in '800-by-600-by-256-colours' mode, which should work.
Adjust the screen-resolution, and the number of colours to "optimal" values.
Jan 31, 2011 | KDS Valiant 6480iPTD Notebook
Samsung SyncMaster 2233SW Monitor "Not
The "native" resolution of the monitor is the "optimal" resolution -- it looks best to use this resolution.
So, right-mouse click anywhere on your Windows desktop "wallpaper".
Click Properties.
Click Settings.
Move the "Screen Resolution" slider to the recommended settings.
Click Apply.
Click OK.
Nov 21, 2010 | Samsung SyncMaster 2233SW Monitor
Input Not Support
This means, that your operating system is not set to the recommended resolution of your monitor. Your monitor has a "fixed" resolution where the image will look best. You can change the solution in Windows XP if you right-click on a free space of your desktop, then choose "Properties". In the new window, that comes up, select the rightmost tab. There you can use the slider to adjust your resolution. Just try some different resolutions until the message disappears. If you use Windows Vista oder Windows 7 you can access the resolution windows by right-cliking on your desktop and selecting "Screen resolution".
Jul 18, 2010 | AOC 19LVWK LCD Monitor
Out of frequency set resolution or see monitor
If you are getting a splash screen (COMPAQ) then video goes black, you can try this. Boot system in Enable VGA mode from the F8 menu and see if you get to the desktop. If you do, you can then go to display properties and adjust the resolution to the Optimal for the monitor.
If you do not get a splash screen, check you cable connections and ensure the Video cable is properly seated and no bent pins. If issue is occurring after the system was moved, also ensure that the correct video adapter connection is being used on the tower, as there may be 2
Oct 04, 2009 | Compaq 7500 17" CRT Monitor
When i power it on it comes on then screen goes black but power boton shows its on.
You might have the resolution set too high so when it goes into Windows the monitor can't display it. Try booting into Safe Mode to change the resolution.
There is a guide on how to boot into Safe Mode here
Sep 16, 2009 | Dell E176FP 17" LCD Monitor
GeForce 9400 gt, black screen problem
It looks like your graphics card changes the screen resolutions and/or refresh-rate to something beyond your monitor's capabilities.
After installing the drivers and the screen goes black, restart you're computer and press F8 to get the Windows advanced menu boot and choose "Enable VGA Mode".
When booted into Windows, right click on the desktop and select "properties", select the tab "Settings" and pick a really low resolution like "1024x768" and press the "Apply" button (but don't reboot yet when asked to). Next press the "Advanced" button, then select the tab "monitor" and change the monitor resolution to "default" or 60Hz.
Now restart your system and see wether Windows will boot normally. If so, you can change the resolution and refresh-rate back to you preferred values. Whenever you pick a too high resolution or refreshrate the screen will turn black again, but don't worry, don't press anything and just wait 15s, after which Windows will roll back to the previous setting ...
Aug 16, 2009 | Computers & Internet
Acer AL1511 15" monitor Screen Menu Problem
What operating system do you use? If it is a windows OS press F8 while the system is booting to access the Boot Manager, choose to boot to last known good configuration and if this does not work retry but select safe mode and change the resolution back to the previous one.
Jan 19, 2008 | Acer AL1511 15" LCD Monitor
Blue Resolution Box
To turn off the reminder, use the buttons on the front of the monitor to do the following:- Press #1. Use down arrow to highlight Setup Menu and press #2. Use down arrow to highlight Resolution Notice and press #2. Select Disable and Exit.
Aug 13, 2007 | ViewSonic VX2235wm LCD Monitor
Computers & Internet Logo
336 people viewed this question
David Payne
David Payne
