Question about Maytag MER6772 Gemini Electric Kitchen Range
Maytag MER 6770 AAW Serial no. 14882525YB
I have a code displayed F 1-2 I would like to replace the lower oven sensor before I have to pay for a new panel. I unscrewed the sensor in the lower oven but it is connected to a long wire. Do I have to disconnect from behind oven? If so were do I find that part to disconnect from the back of oven? Also if you have the part number that would be great..thanks for all your help...
  • bevcna_102 Sep 25, 2008
    I have the same problem and i've tryed doing the same thing. I don't know how to get the element out. Do i need to go in the back of the stove?
    Sergeant:
  • 409 Answers
here is the service manual.
http://www.servicematters.com/maytag_library/docs/16010107.pdf
let me know if this helped.
thanks
Posted on Sep 26, 2008
Maytag gemini model MER6770 AAW error codes F 1-2 and F 3-2
Sounds like a heat sensor and limit switch problem, but it could also be a control board failure which is also pretty common in Maytag appliances. Lately any Maytag i have issues with, dishwasher, range, clothes washer, etc, usually leads to a bad control board. But if the sensors are cheap enough i would try swapping them first and making sure connections are good on everything, thats the cheaper first step compared to replacing the control board.
May 04, 2017 | GE Profile J2B915 Dual Fuel (Electric and...
Maytag gemini electric double oven, f1-f2 codes both ovens, tested both temperature sensor probes, both at 1100 ohms, called Maytag, said might be control board. Anything else to test before spending $$$...
make this test and fix it. God bless you
F1:-1 Runaway Cook Upper oven Test the temperature oven sensor replace if necessary F1:-2 Runaway Cook Lower oven Check the temperature oven sensor replace if necessary
Nov 04, 2013 | Maytag MER6772 Gemini Electric Kitchen...
Heat in lower oven will not exceed 185 degrees
Several possibilities:
1. Bake/broil elements are bad - can you see them glow red?
2. Temperature sensor is out of wack - does the temperature displayed agree with the actual oven temperature? The sensor can be tested by measuring its resistance.
3. If the elements and sensors check out and the oven "thinks" it is hot when it's not, then it is probably your control board. In this case we may be able to help you, we repair these at www.fixyourboard.com.
Sep 30, 2009 | Maytag MER6772 Gemini Electric Kitchen...
CRG9700 - OVEN TEMPERATURE BIG FLUCTUATIONS
biggest issue with any gas oven is a faulty ignitor, not maintaining oven temp, too long to preheat, taking too long to cook, possible slight gas smell during operation, all signs of a bad ( or going bad) ignitor
Nov 10, 2008 | Kitchen Ranges
Maytag Gemini Electric Kitchen Range
Codes are correct .The back needs to be removed and your sensor is a 2 wire part ,The easiest way to make sure you change the right one is by turning oven to on and run a voltage test at each end of the thermostat.Rule follows : If oven is on you should have 115 -120 volts present and make sure you have the same at the other end of thermostat ,if you have the volts at one side and not the other than that is the bad thermostat. Please rate this !
Aug 15, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Maytag Gemini Electric stove fault code F 1-2 when using the oven(s)
F1-2 Runaway Cook Lower Oven Check the sensor 1050-1100
ohms, wiring, control
F1-8 Keypad Shorted Replace Control
Here is the link for you to print off the service manual on your range
PLZ Rate my service
Feb 17, 2008 | Maytag MER6772 Gemini Electric Kitchen...
MER6770 Fault Code
No. just the one sensor part number 12001656. After paying a maytag repairman twice, I will now for the third time replace it myself, google the part number and you will see the different companies that sell it. Price runs up to 40.00, next time buy a different product and hope that Maytag goes out of business!!!! I know I will!!!
Dec 17, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Maytag MER6772 Gemini Electric Kitchen Range Logo
408 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
