I have a lxi tv with us precison lens they are delta 21 part #645959-1 and it's three of them and two of them are empty and one's half full what type of fluid do they take
  • 8,617 Answers
They take optical grade coolant. you can get replacement coolant at the following link.
http://servicemanuals.vstore.ca/
Posted on Sep 11, 2008
Can I Run 3 Phase Motor On Y Or Star Connection Without A DELTA?
Some motors need a Y and Delta, with a special switch, to start up, you start with the Y. the motor starts turning, but does not give full power. after a few seconds (depends what the manual says) you switch to delta, to get full power. To let it run on full power in Y you need 1,4 times the voltage.
If everything runs fine, you won't have damaged anything.
Jul 13, 2014 | Baldor RM3120 HVAC Fan and Blower Motor,...
I want to download this precison lens f2.4
Hi... I want to download this precison lens f2.4
Feb 20, 2012 | Logitech QuickCam for Notebooks Deluxe
Car of year 1998, when tank is full or medium from fuel, guage shows empty. When tank is completely empty, the guage shows full. Guage is of digital type with the bars. What can I do ? Any tests I...
Digital gauge also gets its input for fuel level from a float in the tank. Here the culprit can be that float because the error is systematic i.e., full on empty and empty on full/half. If the reading was erratic then it was something to do with IC in the bars display panel.
Aug 15, 2011 | Toyota Yaris Cars & Trucks
I wanted to find out if the delta marine crib was recalled
There have been Delta Crib recalls. To determine if the Marine is one of the recalled models, go to www.cpsc.gov - the U.S. Consumer Product Safety Commission web site.
This is a recent document on Delta Crib recalls:
www.cpsc.gov/CPSCPUB/PREREL/prhtml10/10273.html
From the above document: This recall involves Delta drop-side cribs with three different types of drop-side hardware and Delta cribs with wooden stabilizer bars that support the mattress platform. Consumers should visit www.cribrecallcenter.com for photographs and models of the affected hardware types and instructions on correct assembly of the stabilizer bars.
Oct 04, 2010 | Baby Gear
Hot water: Pipes make a banging noise when turned on full force.
Hi, That banging is sometimes called a water hammer. It is made when the water hits an elbow in the piping with a force and bangs into the pipe itself. It is more likely to occur in a long run of pipe. This can be reduced or eliminated by installing an empty tube verticle in the piping near where the hammer is occuring. This tube can be found at most building supply stores. The tube is a pocket of air that acts to absorbe the extra pressure from the piping and stops it from hammering.
May 05, 2010 | Delta 2 Handle Lavatory With Metal Pop Up...
27'' lxi reduced picture
This is a problem with the vertical circuit and can be as simple as poor solder connections within that circuit or defective parts. If you have no experience with soldering or TVs, this should go to a service shop. Expect a parts cost in the $30-$40 range for and IC +/or capacitors. If you'd like to attempt this yourself, please supply the exact make and model so I can post the parts required along with additional instructions. Please note that TVs contain potentially dangerous high voltages even when unplugged.
Thanks,
Dan
Mar 15, 2010 | Televison & Video
I have a Slim-View LXI TV Model # PTV 515 AHO1 Has no Picture
while i dont have a true answer, I can tell you its a magnavox tv sold by sears produced back in 93. Ours just started doing this last week. I couldnt find any help online so we replaced it with a new led flat panel. WOW what a difference, the LXI was great for the past 17 years but the new tvs are better. We put the LXI in the garage because we couldnt throw it away. That tv was like a family member, if i figure out how to fix it i will post the how to.
Feb 24, 2009 | JVC Televison & Video
1992 LXI TV AND THE CHANGE TO DIGITAL
You should be fine. Direct TV advertises that they are already broadcasting in full digital. So your box or DVR will act as that converter.
Mar 14, 2008 | Televison & Video
Battery recharge
Motherboard is possibly bad. Try doing a Google search for NEC Versa LXi recharging board.
Jan 06, 2008 | NEC Versa LXi Notebook
Projection tv
I just saw your post, that is a permanat burn on the screen and there is suppose to be protection circuits inside this TV set to prevent this from happening.
Mar 21, 2007 | Hitachi 43UWX10B 43" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
