Question about Creek 5350SE Amplifier
Cordless phone, no power
I have a BT Synergy 3505. I can get it to switch on if I press 0 and hold it, but as soon as i release the key it switches off. Your help would be very appreciated Thanks
    Novelist:
  • 130 Answers
Amps now have protection circuits on them now to protect them from blowing the electronics. Speakers dont usualy have any protection and can blow quite easy. Usualy when they blow they short out or short to ground and then the amp overheats and kicks off. What you can do is un hook both speakers and turn the power on if it stays on then plug each speaker back in one at a time. If it shuts off again without the speakers then it has to be somthing internal already damaged. Bass and volume are the #2 killers of systems. If when its up loud and the woofer speaker is moving in and out pretty far its on the edge of blowing.
Posted on Apr 14, 2006
  • Ron Bower Apr 14, 2006
    There is no warning when they blow either, they can be working fin then quit. The can also be working fine and when you turn it off it doesnt come back on.
I have changed the batteries on a Synergy 6500 handset but it does not charge and the display is blank. What could be the problem?
No actual idea, but check user manual, go to BT website and check there (esp FAQs). Do BT have a customer helpline?
May 16, 2015 | BT Synergy 6500 Cordless Phone - DECT -...
Additional handset on BT Synergy 6500 phone is stuck on 'Test Mode'
is possble to use 8 bt 6500 hand phones via 2 base unit on the one bt line
Feb 28, 2012 | GE 25942GE2 Cordless Phone System
Hi m having the same problem when i play ma music player it shows not enough memory...i hav already upgraded my software nd stored settings aswell bt its nt working....some ppl say it backup files cn solve...
Just follow the steps
Make a backup of contacts in your another sim.
Switch-off your phone.
1. Press and hold theree keys at a time;
Green dial key,
* Star key,
No. 3 key
Then Power on/off to swtich on the phone.
All switch will be pressed at a time.
.Soon an formatting text, will appear ,then stop pressing those switch, remember. 2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory setting.
Hope this helps.
Jan 16, 2011 | Nokia 5130 Cellular Phone
Base unit on bt synergy 3505 keeps beeping and handset keeps displaying base 1 and losing signal.... intermitent fault....have changed batteries in handset and switched unit on and off but still not...
If the handset displays 'Searching', 'Base' or 'Range out' on the screen, this indicates that the handset has lost its link with the base. The following procedure should be followed to help resolve the problem:
  • Confirm that the power lead has not been inadvertently disconnected from the base.
  • Ensure that the handset batteries are correctly installed and are fully charged.
  • Ensure that the handset and base are within range of each other.
  • Switch the mains power off, wait five seconds and then turn it on again. This will reset your product.
  • Carry out a reset procedure on both the handset and the base to return the settings back to the factory default. Your user guide will guide you through the correct procedure.
  • If none of the above remedies solve your problem, please contact the helpdesk.
Jul 20, 2009 | British Telecom Synergy 2110 Cordless...
We have a bt synergy 4500
It sounds like you're pressing the green button when you pick up the phone - when the phone is in the charger and you pick it up to answer it you'll be speaking straight away, no need to press any buttons.
You can toggle between speaker and the phone by pressing the green button.
Hope this helps...
Dec 19, 2008 | British Telecom Synergy 2110 Cordless...
I have a bt synergy 2110 cordless phone. There are 3 lights on the right hand side. one for power/in use, one for charging one for new call . All3 are lit up. How do i get the "new call " light to go out...
I may have a solution you can try.
1. Take handset out of cradle.
2. Press and hold bottom, right hand side, bottom button, marked "Calls"
3. Hold until "Display" shows number of calls, usually 10 and makes a bleep-type noise.
4. Now press top left button, marked "Del" in red, until the display scrolls through all 10 numbers and deletes all the numbers stored in the memory. The phone should then make a bleep noise.
5. Press "red handset symbol" (finish call) twice.
6. Replace handset onto cradle and the "new call light" should go out.
You should now be able to make calls.
Good luck !!!
Nov 27, 2008 | British Telecom Synergy 2110 Cordless...
Set time and date on bt synergy 3505
to set the time the instructions are on page 9 of the instruction manual in the getting started section.
in case you no longer have the manual....
1. press the tick/menu button twice.
2. press 0 and you hear 'to set the day and time press Star, to hear the day and time press Square.
3. press star. you hear 'please enter new day and time after the tone' enter the day (1=sun, 2=mon etc) enter the time using 24hr clock.
4. press the X/security button twice to exit.
hope this helps.
Sep 26, 2008 | British Telecom Synergy 2110 Cordless...
BT Synergy 3505
Hold down the forward skip button on the answer machine, it will say 3, if you have it set to 3 rings, just press the forward skip button again to the required number of rings, 10 being the max. Thats it job done.
Jul 20, 2008 | Lands Phones
Audioline 20 Memory Speakerphone
1. Lift handset (releasing hook switch).or just press SPEAKER, ignore any noises or BT messages while you..
2. Press and release STORE key.
3. Press the keys for the telephone number
you wish to store.
4. Press and release the STORE key again.
5. Press the keypad number (0-9) you want
that telephone number stored in.
6. Your number is now stored.
Apr 01, 2008 | Audioline TEL 100 Plus Corded Phone
85 people viewed this question
Top Creek Audio Players & Recorders Experts
 Grubhead
Grubhead
Pieter Vleeshouwers
Pieter Vleeshouwers
ray gallant
Are you a Creek Audio Player and Recorder Expert? Answer questions, earn points and help others
