Question about Miele G 2630 SCi Stainless Steel Built-in Dishwasher
No power after one months usage.
New dishwasher was working prerfectly and now it will not power up.
I checked the breaker it's fine and I checked the outlet for power.
The dishwasher will not power up. There was water at the bottom of the tub so I took out the filter removed the water and cleaned out the drain pump.
Still no power. Any suggestions on what to do next?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 171 Answers
Hi Red15,
I'm Harvey the Master Plumber.
Your question is: New dishwasher was working prerfectly and now it will not power up.
You checked the breaker it's fine and I checked the outlet for power.
The dishwasher will not power up. There was water at the bottom of the tub so you took out the filter removed the water and cleaned out the drain pump.
I see this all the time! Your problem is electrical. 9 times out of 10 you'll find a loose, broken or burnt connection in the junction box. Turn off the breaker first, we're not going to get a shock. Look under the d/w and behind the kick plate. You'll find a small metal box on the right or center. Remove the screw. You'll then find the hard wire connections we're looking for. Take wire nuts off one at a time (so we don't confise them). Inspect carefully. Replace wire nuts and restrip wire ends as nessessary. Test the unit before replacing box and plate, there's a chance you might have missed something. Confirm d/w is working then recover.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 13, 2008
Since a new meter was fitted my lights keep tripping
1) Understand electric service:
http://waterheatertimer.org/See-inside-main-breaker-box.html
2) Do a heat test on breakers and outlets and switches, than a stress test on main breaker box.
http://waterheatertimer.org/Troubleshoot-household-electricity.html#heat
3) Check that wire size and breaker size match
http://waterheatertimer.org/Color-codewire.html
4) Break new meter with hammer and they will replace with another new meter made in China, intended to put local workers out of a job, so we can pay for automated meter reading requiring software owned by foreign investors charging at least 25 cents per month per customer to read the meter, using workers located somewhere else, which doesn't include cost of necessary towers and maintenance, or include software upgrades, or include needed security upgrades. Oh, but you will be able to pay additional monthly fee to get static snapshots of power usage at 15 minute intervals, and the switch controlling your power will be located somewhere besides your town.
Dec 02, 2012 | Electrical Supplies
My dishwasher stopped working, bought within the past few months, it seems like no power is getting to it. I've checked the breaker and all other appliances in house are fine.
Please provide make and model number of the dishwasher along with some indication of the last cycle it completed before this problem occured.
Aug 30, 2011 | Dishwashers
Kenmore Elite Dishwasher Lights won't come on
Try checking the door lock switch, thats the usual suspect.
Mar 05, 2010 | Dishwashers
Not getting anypower checked the breaker and that's working fine
you need to check that you have power going through the breaker. you do that with a voltmeter.once you know you have power through the breaker you have to check you have power at the Dishwasher with the voltmeter.if you have power there you could have reset on the motor. or the clock has gone bad.I have seen some feed out of a GFI outlet to the dishwasher.
Feb 26, 2010 | Dishwashers
No power to dishwasher
Do the following:
  1. Check the power from the wall outlet or the branch circuit itself.
  2. Check for a blown fuse or a tripped circuit breaker.
  3. Check the wiring connections of the dishwasher from the house wiring.
  4. Check the door switch. Remove the control panel cover or the interior liner of the door whenever it is applicable. Replace if defective.
  5. Check the timer or selector switch. replace if defective.
Aug 30, 2009 | GE Nautilus 24" Built-in Dishwasher
GE Triton not working
Jitterbugclu-
I may have the solution. Husband just turned off power to dishwasher via circuit breaker. Waited around 30 minutes.
Restored power and Triton came back with normal lights.
I just ran a cycle and all was well. Hope this helps you.
My fingers are crossed because I don't know what happened but did read on another site that this should be the first thing you try before expen$ive repairman.
Reply back if it works!
TootieC
Dec 25, 2008 | GE 24 in. GSD6660GSS Built-in Dishwasher
Faulty Diplomat Dishwasher - tripping mains fuse
My dishwasher a diplomat 12 program (hja8640) was doing exactly the same where every now and again when turned on at the plug it would trip. After engineers coming out several times and failing to fix it, they condemed it. New one was supplied, however did exactly the same thing. The electrician came back, checked the RCD power breaker and this was fine. It was then discovered that some dishwashers and washing machines send out a lot of earth leakage, combine this with other appliances on in the house can be enough to trip.
Soloution. The electrician removed the kitchen circut from the RCD breaker and intalled another breaker RCD just for the kitcehn loop, this therefore means that the kitchen has a seperate trip from the rest of the house, and touch wood, has solved the problem. This mind you has taken about three months to work out so i hope it saves you some time.
Always use a fully qualified electrician though.
Thanks.
Oct 21, 2008 | Dishwashers
JDB3610AWX - Controls (pushpad) does not respond to input (doesn't turn on, led doesn't light)
in the manual there is a sequence to unlock the control check the manual for the unlock sequence
Apr 25, 2008 | Jenn-Air JDB3610 Built-in Dishwasher
No power/not responding
Check your breaker first. If your breaker is fine , then remove inner door panel by taking out screws. Next remove cover from control panel, and replace control panel fuse. Write down the make and model # of your dishwasher, then go to appliance store buy new fuse. Then you will know what it looks like. Then you will be able to replace the one in the control panel. Afterwards seal control panel cover with silicone, and reassemble. that should fix your problem, but if not we would be more than happy to assist you further.
Dec 31, 2007 | Kenmore 15899 Built-in Dishwasher
Miele G 2630 SCi Stainless Steel Built-in Dishwasher Logo
592 people viewed this question
Top Miele Dishwashers Experts
mpservices
Mike
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
