Question about Lowrance GPS
I have a 2005 suzuki df250 with the ep20 and the suzuki SMIS Gauge (LMF400) I have gone thru the setup a number of times, but the problem is: after setting up the engine information to the correct engine the engine fuel floe at idle reads 4.2gph and the trim reads -1 all the time (yes the trim 2 wire plug is plugged in). I had a Yamaha fuel flow gauge on this engine prior to purchasing this lowrance stuff and my fuel flow at idle was .03 to.06 at idle. I am a Suzuki outboard dealer and spoke to Suzuki Tech service about this problem and they told me to call Eli Bates, I have left messages with no return phone calls. How are we suppose to sell this product if NO ONE knows how to fix it. Can you help? Thanks Doug Minke atl Performance Marine 425-258-9292 Washington State
SOURCE: tom tom go 300 product code lost
Hey i have the solution :o)
Just managed to download a keygen here:
Followed the complimentary instructions to the letter and now my western europe map is activated. Hope its helpfull
Posted on Dec 19, 2007
  • 191 Answers
SOURCE: Streetpilot 2620 map upgrade
Get it upgraded from
Posted on Aug 20, 2008
SOURCE: 95 GMC Jimmy 4.3l W vin rough idle
My problem was solved when I repaired my 4 wd activation dash switch. The switch was contacting on 2WD & 4HI at the same time. The front differential activation is vacuum activated possibly creating a tug of war that didn't actually engage it but drained off vacuum from the engine? A theory at best but stumbbled across it because I knew the switch wasn't working properly I repaired it and low and behold rough idle disappeared and all is good for 3 weeks running.
Posted on Dec 10, 2008
  • 29 Answers
SOURCE: Fuel Gauge reads empty all the time
The circuit for a fuel gauge is: battery positive through the gauge resistor to the sending unit to the fuel tank(sheet metal) to the chassis to the battery negative. If you didn't remove the sending unit the most likely problem is the fuel tank is not grounded to the frame. Scrape some paint at the rear mounting bolt where you can't see it and re-tighten the bolt. If you removed the sending unit, check the cork gasket. There should be a staple in it that is the connection to the sheet metal. No kidding.
Posted on Dec 31, 2008
SOURCE: 2001 volvo s60 t5 - performance reduced warning message, limp mode activated
I had exactly the same problem on my UK 2001 S60.
It was caused by the throttle control housing gaskets not being serviced properly and consequently the entire housing had to be replaced - not a cheap job -and a valuable lesson learned - use a reputable volvo specialist to service your volvo - I didn't and I learnt the hard why! only a volvo specilaist would have known about this I went to several other main street garages & none of them could even diagnose the problem let alone fix it. Although they did do numerous other things first before they gave up - ie replaced titanium spark plugs.
Before it stoppped running altogther and went into "limp home mode" there were tell-tale engine/throttle surges when the car was idle, but in gear.
It is now running "like new" & I will never get another garage to service it, as this could have been avoided - however they can also wear out after about 10years - so my bad services just made it happen sooner!
I hope this helps!
Posted on Apr 06, 2009
Can I put a throttle tps come off a 2004 Suzuki verons on a 2005 Suzuki verona
tell it straight? you want swap used parts)right?
,the 2005 is now throttle by wire.
I say no.
call suzuki? (they will say no ,no)
no not sold, no cant do.
ask for both parts (missing on their page)
see those part-numbers
but is missing online (USA SUZUKI)
the tps is not sold by suzuki, either year.
whole throttle body yes, (and old old suz trick)
(lawsuits on , idle out of control caused this)
and SMP DONT SELL IT. (A top maker)
2.5l V6.
AIRTEX WELLS. has 04 but no 05.
i think airtex has
sorry, break out the crying towel
the car is known to fail with throttle by wire.
and the part is $500
loves to fail, even on low mileage car.
the left part is TBW TB throttle body, MTIA
the right part is PCM.
see the 2005 schematic, you can see its not a sold part. clearly, its 100% integrated to the Throttle body, now.0a5e5185-1c60-447b-949f-fc9c20d78744.jpg
Jan 10, 2016 | Suzuki Cars & Trucks
2005 suzuki verona engine surges at 45-50mph when the engine is cold after it heats up it goes away?
Plz check engine coolant temperature sending unit that feeds the computer. (Not the one that controls gauge on dash).
Nov 14, 2013 | 2005 Suzuki Verona EX
I need an 1982 Brother EP20 battery drive electronic typewriter manual
Go to click on support, poke around there you may find one.
May 28, 2012 | Brother Office Equipment & Supplies
Lost my user manual for my frymaster plus DF250
i have a user manual - and have the DF250. Unfortunately, I'm missing my cord
Jan 28, 2012 | Black & Decker DF250 Cool Touch Deep Fryer
Headlights not working high and low. all fuse are good
there is an open recall for this exact concern. contact your local suzuki dealership service department and give them your VIN number so they can run it thru suzuki's website. If it comes back with open recall code NB then they will fix your vehicle at no cost you from suzuki coorp.
Dec 04, 2010 | 2005 Suzuki Forenza
Raymarine C120
You need to download the latest software version from which turns on nmea2k.
Jul 24, 2008 | Raymarine C120 System Pack C120 Raystar...
GPS Logo
207 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
