Question about GE WHRE5260E Top Load Washer
Agitator on washing machine
Ge model wwa56oogalad cant get agitator off
  • john gagnon
    john gagnon May 11, 2010
    Thanks for the question why do you want to remove agitator . The only reason to remove agitator would be to remove tub . What is the problem with your washer
  • 943 Answers
Hi thanks for your question . Yhe only reason you would want to take the agitator off would be to remove the tub .And thats tye only reason thanks for the question The appliancd doc
Posted on Sep 12, 2008
Removing agitator
here is a video it covers both the agitator and the basket but you can stop once you get where you need
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&sqi=2&ved=0ahUKEwiw3fOYjpfOAhUl5IMKHdSzCkAQtwIIHDAA&url=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3Di9sEU9hvm0o&usg=AFQjCNGz3z8U6zW8r4yPdwQSGyWQqw3PJg&sig2=09AHxVoRxa6y7SgKQ3hNkw&bvm=bv.128153897,d.amc
Jan 02, 2014 | GE Washing Machines
How to remove agitator from GE washer? Model WHDRR418G1WW.
how to remove agitator from GE hydrowave washer machine?
Feb 27, 2010 | GE WBSR3140DW Top Load Washer
GE WHDRR418G1WW Washing Machine will not agitate or spin/rinse cycle
Tell me more Is there voltage to motor? The transmission makes it agitate .
May 28, 2009 | GE WBSR3140DW Top Load Washer
Washer will not agitate or spin
HI,
you can view this site to have some ideas about your agitator problem.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes
any further question let me know.
thanks,
Mar 29, 2009 | GE Profile WPRE6100G Top Load Washer
GE profile washing machine won't agitate it spins out, drains,
Pull the agitator out and check the drive collar splines.If you have the model I think you have just pull straight up on the agitator. Once removed you will see the drive collar with a 7/16 head bolt,remove it and pull off the collar.First before pulling it off spin it if splines are stripped it will spin freely.
Mar 25, 2009 | GE Profile WPRE6100G Top Load Washer
AGITATOR REMOVAL GE WASH MACHINE, MODEL WPSR3100
If you remove the top cover to the agitator, inside you will see a I believe 9/16" nut.  Remove this to take the agitator off the shaft.
Mar 12, 2009 | GE Profile WPSR3100W
The ge wcxr1070t uses a coupling under the agitator . There is a cap on the top pop it off and remove the screw if you see one , otherwise just pull up , the coupling is under the agitator check to see if it is stripped . dr fixit in the repair service directory will have it if bad
Dec 03, 2008 | GE WBSR3140DW Top Load Washer
Terrible noise while agitating
THAT COULD BE A BROKEN or LOOSE SCREW THAT HOLDS THE INNER TUB in the Center mast, hope this helps AJ
Oct 25, 2007 | GE WHRE5260E Top Load Washer
GE WHRE5260E Top Load Washer Logo
108 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
