Question about Alesis MasterLink ML-9600
Masterlink "Disc Read Error"
I have burned a playlist with 16 songs onto numerous cds (different brands) and with different running orders of tracks and everytime the cd gets to about 40 seconds from the end of the burned cd (54:05 total time) the Masterlink stops and "SYS ERROR, Disc Read Error" comes up, followed by "HDCD to reset, Disc Read error." I have reset everytime and the problem keeps happening. These cd's play fine on other cd players. Curiously, it seems like the "error" messages are affected (coming a little later) if I have different settings for the TIME DISPLAY on the Masterlink. Any suggestions?
  • googler too May 11, 2010
    Do all of the CDs play fine on other CD players?
    You're saying you get this error ONLY when you play back one of these burned CDs on the Alesis? Or when you play the playlist from the HD?
  • 37 Answers
Try to reinstall the O.S. /firmware.
the firmware is avail on the alesis site
dave
Posted on Jun 24, 2009
I cant make recordings on my masterlink every time a record a few songs and try to burn a red book cd from the hard drive it says songs less than 5 seconds
Look at all the tracks in the playlist that you're trying to burn to CD - is there a track that you've perhaps forgotten about still in the playlist, one of less than 5 seconds?
When you press Create CD, you're telling the Alesis to create a CD from the WHOLE of the current playlist, not just the track you recorded most recently ...
Oct 13, 2011 | Alesis MasterLink ML-9600
Tip
How to Play iTunes Music on Windows Media Player
There's a good chance when you buy music from the iTunes Store that the files that you download will be copy protected by Apple's FairPlay DRM system. It's a great system that protects the rights of the artist and publisher by making it difficult for the consumer to distribute copyrighted material. However, DRM can also be very restrictive by stopping you playing legally purchased music on your MP3 compatible hardware. So, what happens if you want to play your DRM'ed music on a non-iPod?
This tutorial will show you a way to produce DRM-free music that doesn't require any special software that you would normally need to buy. All you'll need is the iTunes software, and a blank CD (preferably a rewritable (CD-RW)).
Before we begin, check for any updates that are available for your iTunes installation, or download the latest version from the iTunes website。
Configuring iTunes to burn and rip an audio CD
CD Burner Settings: In order to set up the iTunes software to burn an audio CD, you first need to go into the settings menu and select the correct disc format. To do this, click on the Edit tab on the main menu and select Preferences from the menu list. On the preferences screen, select the Advanced tab, followed by the Burning tab. First, make sure your CD burner is selected from the drop-down menu alongside the CD Burner option. Next, Select audio CD as the disc format that is to be written by your CD drive.
CD Import Settings: While you are still in the preferences menu, click on the Importing tab to access the CD ripping settings. Verify that the On CD Insert option is set to Ask to Import CD. Next, set the Import Using option to a format of your choice; the MP3 Encoder is your best choice if you want to import audio CDs as MP3 files that play on virtually all compatible devices. Choose an encoding bitrate from the Setting option; 128Kbps is the normal setting that is good enough for the average listener. And finally, make sure the Automatically Retrieve CD Track Names From Internet and Create File Names With Track Numbers and both checked. Click the OK button to save your settings.
Making a custom playlist
To be able to burn your DRM copy protected songs to audio CD you will need to make a custom playlist (File > New Playlist). You can add music tracks to a playlist easily by dragging and dropping them from your music library to your newly created playlist. For instructions on how to achieve this, why not follow our tutorial on How to Create a Custom Playlist Using iTunes.
While creating a playlist, make sure that the total playing time (displayed at the bottom of the screen) doesn't exceed the capacity of the CD-R or CD-RW you are using; typically, the total playing time of a 700Mb CD is 80 minutes.
Burning an Audio CD Using a Playlist
Once you have created a playlist, simply left-click it (located under the playlists section in the left pane), and then click on the File tab on the main menu, followed by Burn Playlist to Disc. The CD drive tray should now automatically eject so you can insert a blank disc; ideally use a rewriteable disc ( CD-RW) so you can reuse it multiple times. Before iTunes starts burning the DRM protected songs, it will remind you that creating an audio CD is for your own personal use only; once you have read this notice, click on the Proceed button to start burning.
Ripping an audio CD
The final step in this tutorial is to import (rip) the songs that you burned onto audio CD, back to digital music files. We have already configured iTunes (step 1) to encode any audio CD that is inserted into the CD drive as MP3 files and so this stage of the process will be mostly automatic. To start ripping your audio CD, simply insert it into your CD drive and click the Yes button to start. For a more in-depth look at this process, read the tutorial on How to Import CD Tracks Using iTunes.
Once this stage is complete, all the files that have been imported into your music library will be free from DRM; you will be able to transfer them to any device that supports MP3 playback.
Note:The only downside in using this method is that if you have a lot of files that you need to convert, then it ends up a slow and tedious process. With this in mind, use a legal drm removal tool if you have a large quantity that you need to convert.
on Aug 25, 2010 | Computers & Internet
What does FS error 050 mean?
It's a File System error on the Hard Disk. I think the only solution may be to reformat the disk. If you're only getting this on one track on one playlist, you may be able to access the other playlists to burn all other tracks to CD so you don't lose them
Aug 17, 2011 | Alesis MasterLink ML-9600
I have a Master Link. All playlist are full with 3 to 7 songs per play list. They are in 24 bit 96 k and too long for a cd24 to back up. How do I back up at this point so I can clear the play lists? Thank...
Reduce the playlists, one by one, to a number of tracks that will fit on a CD24. The manual states the max time that can be fitted onto a CD24, I think it's around 12-16 mins or so.
This will mean that if you have single tracks longer than this, you won't be able to write them to CD24 of course.
Jan 12, 2011 | Alesis MasterLink ML-9600
I bought an Alesis Masterlink ML 9600 for my church but have come to realize that its operation manual is not the best written thing I've ever read. I have it connected for analog input from my audio...
Have you thought the posibillity that the track is too short so there is plenty of remaing "time"to write to the disk? Try putting some more tracks in the recording line. Don't forget that the mean time for recording on audio cd is about 74 minutes (or 99 tracks, whatever comes first).
Try this and in case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Jan 15, 2010 | Alesis MasterLink ML-9600
Tracks too short to to create CD from hard drive.
either have to delete the short tracks from playlist to burn...when i get mssg theres usually nothing there (hit new track 2x by accident, just silence) Or if u want what is on the short tracks, have to join it to longer track b4 or after it, making one longer track, and no more 1 sec track...to do: hold playlist edit and delete track button, will ask if want to join two tracks, say yes and its done...When u do this, the track you do this on will b joined to the previous track, it will give u mssg showing which two tracks about to join and what track name will b left...(for example do u want to join track 01 to track 02...resulting track name will b track 02)..can then burn once all short tracks either deleted or joined to larger tracks...
Apr 03, 2009 | Alesis MasterLink ML-9600
I get an error 4280 when I attempt to burn an audio cd
Apparently a common error; if you google error 4280 you'll get several different versions of what is happening. Some blame the Sony CD's other blame Dell, HP, etc...like I said there is a long list so I didn't want to pick out just one, it depends on your Computer type, combined with the CDs..so go ahead and take a look. Personally from reading some of the fixes I came up with; don't use Sony disc and run at 16x to get rid of the error. Hope this helps..
Please rate this solution.
Mar 18, 2009 | Computers & Internet
Masterlink ml-9600
To delete a Track from a playlist, you must currently have that Track selected in the display. Pressing the DEL TRACK button will cause a confirm delete page to be displayed,where "Song 01" is the name of the Track to be deleted. Pressing UP/YES will remove that Track from the playlist, moving the next Track in the playlist in its place. Pressing DOWN/NO will cancel the operation and return the unit to its previous state.
NOTE: Deleting a Track from a playlist does not delete the audio samples from the hard disk. The audio remains on the disk in an "Audio File"
Jan 15, 2009 | Alesis MasterLink ML-9600
Downloading my music and then burning to a cd
Have you read the section of manual relating to 'Importing CDs' ?
Select a playlist, press 'playlist edit' - press HD/CD - insert CD, close drawer. Once Alesis has scanned disc, press 'track move' - display should read Move CDTrk -> Trknn where 'nn' is the next available track in playlist. Press Cursor Left to place cursor under CDTrk, press Down/No, and display should read Move CD->Playlist. If you now hit Yes it will copy all CD tracks to the active playlist (it'll prompt if the playlist isn#'t empty to make sure you want to add the CD to the tracks already in the playlist).
Once they are copied to the playlist, you can move them around if required, DSP them, then burn that playlist to a blank CD
Dec 02, 2008 | Alesis MasterLink ML-9600
How to rip musc to my harddrive
Play Recordable CDs Containing MP3/WMA Audio Files
To play recordable CDs containing MP3 and/or WMA audio files:
Press the eject button on the Xbox 360 console (or select Open Tray from any area of the Xbox Dashboard) to open the disc tray.
Place a data CD-R or CD-RW containing MP3 and/or WMA media on the disc tray with the label facing up (to the right if the console is vertical).
Press the eject button (or select Close Tray from any area of the Xbox Dashboard) to close the disc tray.
Go to the Media area of the Xbox Dashboard. Select Music, Current Disc.
To play all tracks on the CD, select either Play All or Add to Current Playlist.
If you have an existing playlist open, Add to Current Playlist will append all tracks on your current CD to that playlist. Selecting Play All will clear a current playlist and create a new one consisting of all the files on the current CD. (Be sure to save your playlist, if desired, prior to selecting the Play All option.) Files are added to a playlist in alphabetical order by file name. Playlists start again from the beginning once the final track has played.
riz.
Nov 18, 2007 | X-Gaming X-Arcade PC Joystick (XGMPC)
Alesis MasterLink ML-9600 Logo
378 people viewed this question
Top Alesis Televison & Video Experts
Are you an Alesis Televison and Video Expert? Answer questions, earn points and help others
