Dishwashers
Problem for Dishwashers
Generic problem for all Dishwashers
Hobart Dishwasher electrical connection
By chefmail on Sep 11, 2008
Somebody disconnected our AM-14 to redo the floor, and left it disconnected. I know basically where the wires went, but could use some help or a diagram.
Solution #1
posted on Sep 13, 2008
Not Rated)
nav40
Rank: Guru
Rating: 87%, 180 votes
Hi chefmail,
I'm Harvey the Master Plumber.
You want to know: Somebody disconnected our AM-14 to redo the floor, and left it disconnected. You know basically where the wires went, but could use some help or a diagram.
I generally don't recomend this to the average homeowner so lets assume you're above average.
Lets also assume that the fellow who removed it knew what he was doing (he should have reinstalled it for you).
If all you need is help with the wireing:
First double check that the power is off.
There should be a romex connector a few inches from the end of the wire. If it's not there he may have left it attached to the junction box under the d/w. You must use a romex connector to connect the wire to the junction box. Make sure the romex connector is on the cover insulation not on the individual wires. The wires are color coded. Connect the blacks together, the whites together and the ground to the green wire (sometimes to a gound screw). Be carefull that the wire nuts are tight but none of the wire ends broke. Before you put the cover on finish instaling the d/w, water line, drain line, counter screws and be carefull to make sure the d/w is perfectly level. Turn on the water and check for leaks. Turn on the power and test the unit. Then put the junction box cover on. All that's left is the kick plate. If you run into problems you might consider utilizing our Repair Directory to find a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Was this helpful?
Yes
No
Popular Solutions for Dishwashers
Questions and Unsolved Problems for Dishwashers
Answer
kitchen aid model number kudco31vbs is it good
Answer
who makes the best trouble free dishwasher today that is 18" wide
Answer
Dishwasher leaves white residue on everything, including door. Happened before but cleared up after... (More)
Answer
Our Whirlpool dishwasher won't respond? The Green Light is flashing but we can't get the machine to... (More)
Answer
My Whirlpool GU 1200 has gunked up soap inside the filter module. I need to take it apart and clean... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwasher Experts
Top Dishwasher Repairmen
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
