Question about Maytag Washing Machines
If water is being pumped out suspect break stuck..for safety reasons best call repair ..there is large spring with over 200 lbs pressure holding break in position special tool needed to hold spring down while while 6 screws are removed from break stator
Posted on Sep 11, 2008
SOURCE: Front load Frigidaire Gallery washer
You are having a door switch problem change it out and you will have a new washing machine.
Posted on Dec 15, 2007
SOURCE: washing machine works, but wont do spin cycle- clothes sopping wet but clean
first off check to make sure its spinning at all. although the waters draining is it really spinning? are the clothes stuck to the side walls as if they had??if so i would tip machine back and look on floor and around the inside of cabinet approx 12 in. from ground level looking for oil,( transmission oil) . if present youll need a new transmission and clutch assy
Posted on Mar 04, 2008
SOURCE: Washing Machine doesn't spin fast enough
Most likely needs a new clutch. www.washermd.com dave
Posted on Jan 14, 2009
SOURCE: E20 code on washer : will not empty water on spin cycle?
something is stopping the water from drainning...check for kinked hose,,,check waste pipe,,,check units sump...onthejob
Posted on Jan 31, 2009
SOURCE: clothes coming out of washer still soaking wet
is it a kenmore top load?if so the motor is not kicking in to 2nd gear for high fast spin,does it have a speed control on the head?are you using it on the reg. wash cycle?-mike
Posted on Apr 18, 2009
Dec 22, 2012 | Kenmore 24032\24036 Top Load Washer
Jan 04, 2011 | Kenmore Energy Star 44092 Front Load...
May 16, 2010 | Frigidaire ATF6000ES Front Load Washer
Jun 24, 2009 | Kenmore 44072 Front Load Washer
Dec 25, 2017 | Washing Machines
Apr 18, 2009 | Washing Machines
Jan 13, 2009 | Whirlpool 3.2 cu. ft. Plus Washer
Dec 11, 2008 | Maytag Neptune MAH5500B Front Load Washer
Dec 14, 2007 | Frigidaire GLTR1670A Front Load Washer
41 people viewed this question
