Question about Danby Heating & Cooling
Water fill light stays on all the time how should I slove the problem?
  • 76 Answers
There should be a sensor that measure's the water, some work with a float and get's stuck,if so you can just push it down again,if it does not have a float the most possible cause is that its broken and need replacement.
If you don't know much of a a/c unit better get a repair man to have a look for you.
Regards.
Wouter.
Posted on Sep 11, 2008
After flush tank refills very slowly
Make sure that any valves that you shut to install the fill valve are fully open after the installation.
If that doesn't work, the following is from another fix your stuff site:
Shut off water supply. Lift the rod arm and remove top cap assembly by turning 1/8 turn counterclockwise. Using a straightened coat hanger, carefully clean out the inlet passage of the Valve.
If these don't help, check the model number of your Fluidmaster and include that the next time you write.
Dec 09, 2010 | Fluidmaster INC #B1F09 9" Faucet Connector
Low water light stays on
If water light and heating lights go on and off, Try this: Fill water, turn water nozzle on, let water flow out. Water light should go off. Shut off water.
If coffee lights are solid, turn off the machine, let it cool off and try the above again.
Jul 07, 2009 | Gaggia Syncrony Compact Coffee...
My dishwasher seems to start ok then the first light starts flashing and it do'es nothing just stays there any ideads what my problem is
Can you tell if it's filling with water. The first thing it does is fill with water (usually on a timed cycle) before the pump starts. If there's no water in the tub, it obviously won't wash dishes, since a dishwasher is nothing more than an enclosed pressure washer. If it does not fill with water, you may have a bad fill valve or the timer that turns the fill valve on may be defective. You DO have the water turned on, RIGHT?
Jun 11, 2009 | Indesit 18 in. D41 Slim-Line Free-standing...
Descale red light, wont go off, and can i use any delcale tabs
Solution: Just refill the water tank with water (no descaling solution) all the way to the "Max Line". Then run the full descaling program again --takes approx. 20 minutes. After the program runs completely you will get the yellow "standby" light on and the red "descaling" light will be off.
Next time you descale, be sure and fill your water tank to the "Max Line" before running the descaling program.
Hint: An incomplete cycle (not full tank) is what makes the red light stay on. In other words, it's staying red to tell you to run a full cycle (beginning with the water tank filled to the "Max Line"). Hope this tip is helpful!
Mar 12, 2009 | Bosch Coffee Makers & Espresso Machines
Water fill light stays on all the time and compresser will not come on
water fill light stays on how can I fix this problem ?There is no water in the internal tank or the external tank.Please help
Sep 10, 2008 | Danby Heating & Cooling
Bosch tassimo
Sep 03, 2008 | Braun Tassimo Espresso Machine/Coffee...
Water fill light stuck on
you say our fill the water light stay on lot they put a magnet in the water container fill it with water and gently tap the water container if the magnet stuck that should do it if it persite the magnet receiver under the cover is diffective normaly a few little tap do the trick
thanks for using fixya
pierre
Feb 25, 2008 | Saeco Incanto Classic Espresso Machine
Air-O-Swiss 7133
Okay, I just started getting this same deal with my 7133 on it's third season. I found in a blog that if you hold down the button that controls the heat while turning the mist knob on, it resets the machine. It worked. The red light went green and I turned off the heat button for cool air and the upper light still stayed green. Fingers crossed this continues to work. good luck!
Nov 27, 2007 | Air-O-Swiss 7133 Humidifier
Heating & Cooling Logo
121 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
Dan Webster
Dan Webster
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
