Question about Dell M570 15" CRT Monitor
Model no. 828fi (800f series)
Everything seems ok but: the vedio is progressively stretched towards the top , seems ok in the middle, and squashed progressively towards the bottom. this monitor does not vr for this adjustment. what could be the cause. could not detect any faulty component. (sorry techman i quoted wrong model previously_m570) william
  • WILLIAM TSURA Apr 14, 2006
    THAT IS VALUABLE HELP TECHMAN. I SHALL TEST ALL CAPS IN THAT SECTION. ONE OTHER THING , THE VEDIO SHAKES. IS THIS ALSO BECAUSE OF CAPS? AND IF SO WHICH ON OR IN WHICH SECTION
    CHERIO
    WILLIAM
    President:
  • 3,130 Answers
There is a vert height control on the main board somewhere as sometimes look in the back of the back cover after you take off the back and see if they put a diagram of sorts in there . Good Luck
Posted on Apr 14, 2006
  • Larry  Dillon
    Larry Dillon Apr 14, 2006
    oh never mind mman about the vert height control as I didnt read carefully your complaint. Your problm is for sure a bad cap in the vert drive curcuit . What one is bad??? Youll have to swap them pot or get a cap checker and check them out of curcuit too>
Old club car battery wireing digram
How old? The two most common wiring of the batteries are: (old) two batt on driver side , front one neg toward middle of cart, back one positive toward middle. Middle batteries-- both positive towards front of cart. Passenger side-- two batteries- front one - positive toward middle, back one negative toward middle of cart. Connect main negative to drivers side and main positive to passenger side- rest of them are connected in series( neg to pos to neg). The newer wiring only has two batteries that are switched- The main positive and the main negative batteries are reversed but the main cables are connected differently, you can tell by looking at what posts are not connected after wiring them in series. They will be the back ones on each side.
May 22, 2017 | Golf
Why has my picture stretched tall eg inch of top and bottomof picture cant find a remedy
Look on your remote for the button marked P. Size in the middle towards the bottom and select full or 16:9.
Feb 21, 2015 | Samsung LN40A550 LCD TV
Monitor display squashed at edges
check your video card for loose connections
Apr 02, 2010 | Computers & Internet
Monitor screen display stretched center but squashed/narrow edges
On the monitor itself, I am guessing this is a desktop? There are buttons for adjustment. Look for the menu button around the bezel of the monitor and press it. Scroll through the settings for the default setting and press that. Once the default settings are made for the monitor, then you can go to the graphics settings available through windows to get the resolution straightened out.
Mar 26, 2010 | Computers & Internet
Seems everything works, but no heat. Progressively worsened over the past month-now 3 hours to dry a regular load
Try this link I hope it helps, I know it helped me a ton!! ps don't forget to rank my help. Thank you and have a nice day!
http://fixitnow.com/wp/2004/11/13/mailbag-how-to-troubleshoot-a-gas-dryer-with-no-heat/
May 06, 2009 | Dryers
Washer wont progress through the cycles, suspect timer.
I was able to fix the problem by replacing the timer ($106 CDN). Thanks for everything.
Jan 06, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Progressive 100
Check the brush roll ends, make sure they turn freely, if not then replace it. The belt may look ok, but they stretch after a short time and should be replaced.
Mar 24, 2008 | Kenmore 31912 Progressive Direct Drive...
SHAKING IMAGE, STRETCHED IMAGE
Like I said last night cobra there is a vert shaper cap off the jungle/drive ic usually a smaller value and will check good but its bad. Or the b+ filter cap off the fly has caused sysmtoms like this as well. Good Luck
Apr 14, 2006 | Dell 828FI 15" CRT Monitor
Dell M570 15" CRT Monitor Logo
114 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
