Repair front load washer
Not spin at theend of cycle washer frontload not spinning out after wash cycle Asko 10505
  • dcxsportsfis Apr 05, 2009
    ASKO 10505 does not spin and continues filling and emptying water
Wash machine not draining properly at end of wash. not fully spinning.
pls advise
Posted on Sep 11, 2008
Shoot machine and then yourself.
that's what i did and now i feel alot better except i have a headache...i think from the bullet...but i definitely took out the 10505.
hope that helps?!
Chris
Posted on Jul 17, 2009
My Asko washing machine wont go into spin cycle it just keeps on washing after 3 hours I had to turn it off now what
call a technician in
the problem is most likely in the program board not progressing the wash cycle
Jul 12, 2016 | Asko W6021 Front Load Washer
My front load washer will not spin on the final spin cycle. Washer spins in wash and rinse cycle spin. Cloths are still soaking wet.
I appreciate your post, Rachel Kovach!
From my understanding your Frigidaire frontload washer is not spinning the final spinning and the clothes are still wet. If you washer is overloaded it will not spin properly to release the water out of the clothes. Also, a small load will cause your washer to not spin properly. You should additionally check the drain hose to make sure it not kinked or twisted that could cause your improper draining. If all that checks properly it could be an issue with your drain pump, motor, and control panel. I would suggest consulting with a technician for proper diagnosis and repair. This will help avoid unnecessary part purchases. -Matt
Nov 19, 2014 | Frigidaire Washing Machines
GE frontload washer doesn't spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 12, 2011 | GE WSXH208A Front Load Washer
Why is it not spinning out completely in spin cycle?
heatman101
Sep 28, 2010 | Asko W6221 Front Load Washer
Asko 10505 washer will not spin
Hi, 2 things to check for. Obstruction in the drain pump or faulty drain pump, brushes in the motor worn out. The easiest way to determine the pump issue is answer this question. Does it drain ? Next, turn the timer to the drain/spin cycle, obviously it should drain & spin and advance to "off". The next thing with these 10505 asko is to see if the drum rotates in both directions in the wash/agitate portion of the cycle. You can just select the short wash for this (I forget if it's #4 or #5) If not, it's worn brushes. However, you'll have to make sure the armature isn't damaged before simply installimg new brushes. We can cross that bridge when we get there. Let me know. Hope that helps, though those are just the most common problems there could be others. Good Luck
Nov 01, 2009 | Asko W6021 Front Load Washer
GE Frontloader - will spin @ beginning of cycle, but never again
Check the switch on the door where clothes are loaded. I may be failing intermittently.
May 23, 2009 | GE WSXH208A Front Load Washer
Need information about an old ASKO 10604 washing machine
Hi there, we have a 10505 machine and the controls must me pretty much the same. The green E is "Economy" button - increases main wash length by 22 minutes so you can use cooler water. The two circles with diagonal may be a spiral with diagonal if you look real close - this is "No spin" button - no spin in any cycle. The 800 button - when pressed reduces spins speed to 800 rpm from 1000 rpm. Not sure about cold clothes though. Do you have the hot water connected? Have you got a temperature dial? If so, make sure you dial up the required temp. Good luck!
Cheers, Brian.
Jan 23, 2009 | Asko W6021 Front Load Washer
Asko Frontload wont stop running water
you need a new inlet valve take off the top panel then you see the inlet valve follow the inlet hose
Mar 17, 2008 | Asko W6441 Front Load Washer
We've had that same problem since we bought ours 3 years ago...but it was intermittent, and we never knew when we'd get the spin-dry cycle to work. Sears made 10 service calls, and replaced everything in the machine except the motor and motor control board. Those two parts were ordered and delivered as a result of the 10th service call. Of course, when the service guy was here, the spin worked! After he left, the next load did not spin. Frustrated, I opened the front end and looked around. I had noticed how violently the drum shook while operating when the service guy was here, so I decided to see if the wiring harness from the motor might be loose where it plugs into another harness that must go to the motor control board. There was a definite tightening of that connection as I squeezed the two harness plugs together. (I tightly secured a plastic zip-tie around that connection to prevent it from vibrating loose again) Since then, I have had absolutely no problem with the washer. I called Sears and told them I had managed to solve this long-standing problem on my own, and how, and also told them to cancel the service call to install those parts I ordered, but to pick them up and reimburse me for them. (I never opened the two boxes that arrived) They did just that, and we finally have a washing machine we can rely upon to complete the wash like it's supposed to. It's been a very frustrating and expensive 3 years, but now all is well.
Dec 15, 2006 | Kenmore 43142 Front Load Washer
Washing Machines Logo
469 people viewed this question
Top Washing Machines Experts
