Monitor comes on but then goes dark as soon as you press a key on the keyboard
    Sergeant:
    Champion:
  • 251 Answers
Bad video card or connection
Posted on Sep 11, 2008
The screen is really dark
Locate the Fn (Function) key on your keyboard. It may be on the bottom left side with dark blue letters. Locate the two "brightness" keys near the top of the keyboard. These will be in the "F" keys, possibly if F6 and F7. They should have little sun pictures or something similar to indicate brightness. Hold down the Fn key while pressing F7, or whichever "F" key your laptop uses to increase brightness. Tap F7 repeatedly until you reach the desired brightness. Fn must be held down as you continue to tap. Hope this helps.
Dec 07, 2012 | Intel EasyNote E4 715 Notebook
When I open my laptop, I have to press F2 but could not enter the bios, the screen becomes dark and went straight to windows. what should I do.
From the symptoms, it could be a faulty keyboard -
First though, are you pressing the F2 key soon enough?
I'd turn on the notebook and then start pressing the F2 key repeatedly.
If that fails, I'd borrow an external USB keyboard to test it with first and see if it does the same thing....
Often, if the keyboard has had something spilt in it, or it has come loose, of just failed, the keyboard will not respond to any input.
If, under windows, the keyboard works fine, then that may not be the issue... if it fails under windows, you'll probably need to replace the keyboard - usually pretty easy and cheap enough to do.
"the screen becomes dark" - too dark to see? or just dimmer, as if you took out the battery charger?
if you cannot see it at all, or just barely see it - the screen inverter may have gone, or the backlight in the lcd panel, or the cable from the mainboard to the inverter...
If you are still having trouble, feel free to provide some more info re describing the dark screen issue...
Hope this info helps.
May 21, 2012 | Acer Computers & Internet
Dark picture on monitor
Occasionally, you may find your laptop's monitor is too dim for your liking. A normal desktop computer's monitor has an on-board menu system that lets you adjust the brightness and picture control settings as you please. A laptop monitor has no such controls. You can adjust the brightness of your laptop monitor using your laptop's keyboard.
1. Press and hold the "FN" key on your laptop's keyboard. This is the "Function" key, which operates much the same way that the "Shift" key does: It allows keyboard buttons to be used for multiple purposes. It's located in the lower left corner of most laptop keyboards, next to the "Windows," "CTRL" and "ALT" keys.
2. Look at the top row of keys on your keyboard for a key with a tiny triangle pointing upwards and the symbol of a sun on it. This is the "Increase Brightness" key. With the "FN" key held down, press the "Increase Brightness" key. On most laptop keyboards this is the "F7" key, but it varies depending on the model.
3. Continue to hold down the "FN" and "Increase Brightness" key until your dim laptop monitor has reached the level of brightness you require. A laptop monitor can only get so bright. It will stop at its highest setting.
4. Release the "FN" and "Increase Brightness" keys. You have now fixed your dim laptop monitor.
I hope you find it very helpful. Thank you for using fixya
Aug 17, 2011 | Acer Aspire 5610-2089 Notebook PC (ACER...
The computer starts and asks whether I wish to use the restore function. The microsoft logo appears just for a moment and then the monitor stays dark. Wonder if it might be a monitor problem
In order for you to rectify if its the display problem meaning the you monitor or if it is your harddrive where your OS is currently installed, try to go to BIOS and see if your display is working there properly..how? *Turn the Acer Aspire One computer on. Restart the computer if it is already on. *Press the "F2" key on the keyboard to enter the BIOS utility as soon as the "Acer" logo appears on the display. *Press the arrow keys to navigate throughout the BIOS menus. Press "Enter" make a selection. *Press the "F10" key when finished to exit the BIOS. once rectified that it isnt the display that causing the problem then, it must be your harddrive or the OS itself (if OS is the problem then you have to reformat your computer)
Hope this will help.. :)
Jul 06, 2011 | Acer Aspire One PC Notebook
Toshiba L355-S7905 does not want to connect to tv via vga port(no other ports available) The pc monitor goes dark after connecting vga cable to it. the TV says ''no signal'' is there anything that needs...
First without connecting the external Monitor/TV Go to display properties and Lower down resolution then when you connect the TV press and hold the Fn key on the left bottom of keyboard between Ctrl and Alt and while holding FN ket down press Change monitor button ( Normally F5)( must be having 2 monitor kind of image printed on any of the function key) once then twice or thrice to shift between different options like display output on one monitor, 2 monitor, extended display etc.
May 24, 2010 | Toshiba Satellite L355-S7811 Notebook
I have a new DELLS2209W Monitor. On occasion my
I want you to try something next time this happens, instead of rebooting the computer, just cut power to the monitor. Then switch it back on.
Does the screen come back up?
Comment back and let me know
Mike
Dec 19, 2009 | Dell Computers & Internet
Screen goes to sleep after "no signal" message
If you do not move the mouse or press any key on the keyboard it could be just going into video power save. Confirm it by moving the mouse or pressing a key on the keyboard. If the monitor comes back on, adjust the power settings in control panel and change the time for the "turn off display" to a more suitable setting.
Dec 31, 2008 | ViewSonic VA1930WM LCD Monitor
In power save mode
The monitor is not receiving signal from the computer. Is the power light on on the computer? If so - press and hold power button on computer until the power light goes off, then press again to restart. If the computer starts and you still have no picture it is most likely a video card or motherboard problem.
Nov 17, 2008 | Dell E173FP 17" LCD Monitor
Monitor won't stay on. Error message comes up that says "no input signal", then monitor goes out.
Problem with the monitor, monitor cable, or video output. For monitor, if you have more than one input, make sure it's set to the correct one. Try a different cable. Try a different monitor. Check your video card settings--if you see the BIOS bootup screen while it's coming up then the Windows splash screen, then monitor blanks out, it's a Windows display setting. Boot into safe mode, then change settings--
  • Turn the computer on or Restart the computer
  • Start tapping the F8 key. The Windows Advanced Boot Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. To resolve this, restart the computer and try again.
  • Ensure that the Safe mode option is selected (the top option)
  • Press Enter. The computer then begins to start in Safe mode.
  • When you are finished with troubleshooting, close all programs and restart the computer as you normally would.
Oct 31, 2008 | HP Computers & Internet
Won't come out of power saving mode
chek the connection cable between the CU and the Monitor and the power supply cable of the montor or give another outlet
Aug 16, 2008 | Gateway FPD 1730 17" Flat Panel LCD...
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
