Question about Focal Utopia Audiom 6W Car Mid-Range
Car audio i am trying to put together a caraudio system. i need some info. i have 1 jl audio 300/4 2 250/1 1 500/1 amps a pr of foal tlr tweeters 6ws mids 5ws subs and jl 10w7. help me with puting it all together.
Mike, this is a beautiful and perfect setup! if you dont have a headunit yet i know the #1 perfect one for you CLARION DRZ-9255 .http://www.clarion.com/us/en/products/2008/audio/source_units/cd/DRZ9255/us-en-product-pf_1172385113235.html i have owned every single piece of equipment that you have! my set up was the same exact way except i used focal utopia 33wx for my subs. but JL AUDIO are the masters at making the best subs for the money by far! i have owned every line of subs JL AUDIO has ever mad,my overall favorite. sean314 623 7054 cell
Posted on Apr 03, 2009
I have 2 ma audio hk15x2 2000rms how can i wire them to 1 ohm
Yes and no. If you wire them together you can only wire them to 2 ohm or 4 ohm.
http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=22#results
If you wire them separately then you can wire them down to 1 ohm each. http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=1&I=22#results
But you will need to amps.
Sep 02, 2012 | MA Audio HK15X2 Car Subwoofer
Installin car systems
you dont want to connect both of those amplifiers together. You could run them separately to separate subs or the jl to your sub and your alpine to your front speakers. But you dont ever want to mix and match amps to the same sub. Even if you had 2 jl500/1's you wouldnt want to just hook them up together. Because they both have to be putting out the exact same amount of power. Which no 2 amps are ever exactly the same. Some companies make bridges to properly connect 2 exact amps together. I Hooked up 2 JL 1000/1's to each voice coil on a 13.5 W7 and i smoked the sub. So i definitely dont reccommend doing it unless the amps are conneccted to separate things.
Apr 28, 2010 | Jl Audio 500/1 Car Audio Amplifier
JL Audio 500/1 Amplifier "Thermal" light flashing
Re-check all the connections to the speakers, The uPC monitors all the outputs and if any are taking more power than they should, the uPC shuts the amp down to protect the internal components. Don`t use tape joints alone, try to run the cable the full length without any joints. If you do have to piece the wires together, solder them and stagger the connections, in other words, make one lead shorter than the other so that if the tape does come off, the offending connection is well away from the other so they can never meet or connect to each other. Ian
Jul 24, 2009 | Jl Audio 500/1 Car Audio Amplifier
What would be a better amp for my jl audio 12in w6v2
its not the amps my dude ur ohm loading is wrong if u have a 4 ohm stabled amp n ur speakers r 2 ohms naw thats not gonna fly caus it cant put out what ur asking 4 so u need 2 reload ur subs try this link http://www.bcae1.com/spkrmlti.htm this should help u out n save u money
Jun 17, 2009 | Jl Audio 12W6v2 Car Subwoofer
No sound out of tweeters, highs out of woofers?
it does sound like you shorted out your crossover which can be fixed if you know what you are doing, but in the long run i would try to get another one i know that raidoshack sells some small ones and is also cheap, if your positive that you didnt short out the crossover se if it needs power, see if you can cross your woffers and tweeters on the crossover, if not is there any settings that u can change on the crossover? hope i helped :)
Apr 28, 2009 | Jl Audio VR650-CSi Car Component System
Low ohms light flashes and bass distorts at high volume
Sounds like you need to invest in a capacitor. Those are used when subs receive a bass spike. You just a need a 1 Farat Capacitor (1,000 watts) ran between the head unit and the amplfiier to fix your issue. Also, try reducing the volume gain to half gain and low pass frequency to half gain; this will increase your clarity and make your amp less hot. This may fix it without a capacitor. Also find out what amprage your alternator is. Your alternator may not be designed to run the amplifier. Most alternators are 200 amps now if they are gold plated.
Hope this helps
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=20378
Feb 10, 2009 | Jl Audio 500/1 Car Audio Amplifier
If I buy 2 12 inch jl audio w7 subs would it be better to get 1 or 2 jl audio 1000 watt amps
two amps and get a 2 farad cap please because if u dont u could melt wires together cause a fire or toast ur alt.
Oct 30, 2008 | Jl Audio Car Audio & Video
Have a jl 500.1 amp
for that amp u need a compasitor to mantain the amps the amp draws the amp is being choked when the car is off and when its running its killing the cars charging system
Jun 25, 2008 | Jl Audio E1200 Car Audio Amplifier
2 12w6v2's with a 1000/1
I dont know how you blew both subs with a 1000/1. the subs have an rms of about 400w. according to jl,the sweet spot for them is about 500-600watts. are you sure that you had the jumpers wired correctly and the amp at 2ohms?
Jun 11, 2008 | Jl Audio 1000/1 Car Audio Amplifier
Focal Utopia Audiom 6W Car Mid-Range Logo
155 people viewed this question
Top Focal Car Audio & Video Experts
xxxxxx xxx
Are you a Focal Car Audio and Video Expert? Answer questions, earn points and help others
