Question about Nikon D300 Digital Camera
Nikon D300 Problem
Camera is only few months old. Several times while shooting I would loose auto focus. I have checked all settings with the Manual, making sure they are in default, or back to factory settings. I just don't have a clue, Of course mind you I am still not 100% knowledgable with this camera. It takes quite some time. I am still operating in " P " Programmed Auto Mode after a few months. Help ! Any clues would be most appreciated
Thanks'
Terry TBuMoon27@aol
  • 77 Answers
Try shooting in manual or aperture priority mode, make sure that the csm selector knob is set to S
Posted on Jun 14, 2009
HOW DO I SET MY CAMERA TO AUTO FOCUS
The D90 has three different autofocus modes. In the AF-S mode it will not shoot until it has focused. In the AF-C mode it will shoot when you press the shutter release button even if has not focused. In the AF-A mode the camera switches between the AF-S and AF-C modes so either can apply.Also, bear in mind that the camera doesn't really know what you're taking a picture of. It may focus on something other than your subject. If you're in the single-area AF mode then you control which of the eleven focus points the camera uses. In any of the dynamic-area AF modes the camera decides.For full details on how the various modes work, please consult your manual. You might also check out the Nikon D90 video tutorial.
Apr 24, 2012 | Cameras
Why does my Nikon D60 while on auto focus or quick shutter speed either not focus and take the pic or focus and not take pics?
I have a 5D Mark II that has acted up like this. 99% of the time it will reset itself it you power off, remove the lense and allow them to sync up. Try this, it may work for you too!
Apr 22, 2012 | Nikon D60 Digital Camera with 18-55mm lens
I have a brand new nikon coolpix s3000. it's on full-time auto focus. Any ideas?
You can change this in the menu while in shooting mode. This is from page 48 of the manual:
Choose how the camera focuses.
A (auto) M d (Shooting menu) M I Autofocus mode
A Single AF (default setting)
The camera focuses when the shutter-release button is pressed halfway.
B Full-time AF
The camera focuses continuously until the shutter-release button is pressed down
halfway. Use with moving subjects. The sound of lens drive movement will be heard
while the camera focuses.
Sep 28, 2010 | Nikon Coolpix S3000 Digital Camera
My cable release is not working. It triggers the auto focus but will not take a picture.
Try setting the camera to M manual focus and manually focusing on the subject. Some combination of focus size and focus type may not focus unless the sensor sees a subject and is in focus. So if the sensor cannot see and know it is in focus it will not fire. If you subject is not moving then focusing in manual will ensure the subject is in focus and the camera can shoot.
Apr 10, 2010 | Nikon D300 Body Only Digital Camera
Shutter frame rate drops to about 1 per sec on CH with MB D10 while using any auto focus lens. 14-24,24-70 or 70-200 and an older 20mm auto focus. With no lens or a manual focus, very old 55mm Micro, lens...
Wow, that's weird. Does it do it with the auto-focus switch on the body turned to manual? I shoot a D300 and know pretty much everything about it there is to know and the D700 is basically the same camera with a full frame sensor. The only things I know of that drop CH frame rate are shooting in 16-bit raw and it shouldn't kill it like that, using full-auto with tracking will also cause a lag in auto-focus but that still doesn't seem right here. If it only does it with the auto focus on then it may have trash on the AF screen in the camera and needs to be cleaned. Try setting the body switch to manual focus, remove the grip and shoot jpeg and see if it still happens. If it does, reset the menu settings and try again. If it still does it than you probably need to give it a trip to Nikon. If it quits than start putting things back one at a time until you figure out what is doing it.
Somebody told me that Nikon will clean the pro cameras for free once a year while under warranty, I haven't looked into it yet to make sure.
Nov 01, 2009 | Nikon D700 Digital Camera
Nikon D300 - Auto focus point won't move. Autofocus doesn't work.
The lock that's around the 4-way button that moves the AF point will stop it from moving. The AF switch (says C,S,M) on the body below the lens release button gets knocked to manual and turns off the AF
Oct 11, 2009 | Nikon D300 Digital Camera
Nikon D300 When I depress the shutter half way or fully on my D300 the frame counter reads r27 and the lens (any previously compatible Nikkor lens) will not auto focus. The camera is not set in burst mode...
Only reason the lens will not auto focus when you depress the shutter half way is due to either lens AF switch is set to Manual OR camera body's focus system is on M. There is 3 way toggle switch below the synch port around the lens mount. It should be set to C or S in order for auto focus to work. If all the settings are correct and even "AF-ON", next to rear dial doesn't activate auto focus then the issue maybe in the setting or the body itself. As for the buffer reading r27, I think mine displays r## regardless of burst/continuous mode.
Jul 13, 2009 | Nikon D300 Body Only Digital Camera
Nikon Lenses
They will fit but will work only in manual mode
Jun 14, 2009 | Nikon 50-300mm f/4.5 Manual Focus Lens...
Nikon D300 camera body shutter doesn't always work
Perhaps it is a focusing problem- try it on manual focus setting to see if the problem still persists...
May 05, 2009 | Nikon D300 Digital Camera
Trouble shooting in auto focus
Maje sure you lens it not set to manual focus and that the lens is mounted correctly. Also - FWIW - shoot with a fast shutter speed (1/250 or better) to avoid blur.
Apr 24, 2009 | Nikon D200 Digital Camera With 18-135MM
Nikon D300 Digital Camera Logo
90 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
