Question about Whirlpool 24 in. DU800CWD Built-in Dishwasher
Dishwasher does not start to fill
Dishwasher had been working normally until today. Now there is no water entering the chamber. Is the problem likely to be the valve that lets water enter? How do I check it with my multimeter? Thanks
  • Anonymous Dec 26, 2008
    water is not entering dishwasher
  • 641 Answers
Check water entrance pipe, myaybe it was bend (if you have there a tap - see it is open). The water entrance valve is an electromagnet valve,loocated at the pipe's enterance to the machine. Test that it get power (with your meter). In case it get power and dosen't work - You can easyly open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!!! Check as well for valve's coil resistance. In case you have no resistance measurement - you should replace for a new valve. Good luck
Posted on Apr 14, 2006
Hi, i've taken the top and sides off my Bosch dish washer sgs45e02gbas it has not been working. the problem is ....when you switch it on is there is a pumping/throbing noise but doesn't continue...
Hello Phillip,
The reason only the pump runs anytime its powered up is because the flood detector has detected water in the base of the dishwasher and until that water is gone only the pump will run.That flood detector is (when looking at it from the front) is in the left front corner,its a styrofoam disc with a rod in the center of it and has floated up activating the flood switch on the letf side wall where the water enters the tub (can be seen on the left side with side panel removed) if thier is no water in the base frame perhaps some foreign object has wedged itself under the sytrofoam disc holding it up. Until the water is out of the base frame only the pump will run as long as the flood switch is tripped.
Possible things that will make water be in the base frame are,
oversuds from too much detergent
a leak of any component or hose
a defective water level switch allowing it to overfill
GENE
Sep 06, 2011 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Maytag dishwasher
Theres a Floater inside the tub protecting against overflow. when it is pushed up or stuck by debris, and does not fall down to its inactive position, it can prevent water from filling. So be sure there is no debris and move the floater up and down until it falls down in its normal position.
Also dishwashers can lose their pump prime and will not fill with water if there is no priming water in the bottom of the unit. To solve this problem, you must add several quarts of water to the unit. Let it settle down in the bottom until it stops going down. Start the washer and you will hear this water pump out of the drain and the unit will now fill with fresh water..
Thank you..Regards!!..
Aug 24, 2008 | Maytag 24 in. MDB4100 Built-in Dishwasher
How do I clean my burr mill (Models BM1 and BM3)?
Always unplug your burr mill after use and before cleaning.
  1. Turn the whole bean chamber to the right until it can be lifted off the base. This will allow you to clean the grinding wheel. NOTE: Never use water or liquid for cleaning the lower grinding section of this appliance.
  2. Clean interior recesses with a soft brush (not provided).
  3. Wash the whole bean chamber and lid and the ground coffee chamber and lid in mild detergent and water. These items are only dishwasher safe on the top rack of your dishwasher. Wipe exterior with a damp cloth. Do not immerse mill in water or any other liquid or place in dishwasher. Use only non-abrasive cleaners to remove stains.
  4. After completely drying, replace whole bean chamber. Important: when replacing whole bean chamber, screw on completely before setting grinding rate. Turn chamber clockwise (as viewed from top), until it will not turn. Fill with whole coffee beans for grinding and replace lid.
  5. Replace ground coffee chamber and lid, making sure it snaps securely into place.
Sep 02, 2011 | Bunn NHB Coffee Maker
Dishwasher doesn't fill with water!
Here is a tip the will elaborate on your problem more, but the bottom line is that you need to replace that fill valve...
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
May 28, 2010 | KitchenAid KUDI24SE Built-in Dishwasher
No water?
If there's no water entering your dishwasher, check these:
Water-inlet valve
Float switch
Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Jul 24, 2009 | Dishwashers
KUDS24SEB3 - can't start cycle properly
I just had the same problem. I finally pressed Rinse Only and it started to fill. Without canceling, I depressed Normal, and it seems to be going through the proper cycle now.
Sep 17, 2008 | KitchenAid KUDS24SE Built-in Dishwasher
Leak of water in base of unit
is the plastic unit a salt chamber,depending where the hole is you may have to replace it or is it an over filling problem,its hard to know without seeing it hope this helps you.Thanks Ian.
Mar 14, 2008 | Neff 24 in. S5443X2 Built-in Dishwasher
Dishwasher not working again
is the clean light blinking, if so make sure water temp is at least 120 degrees
Jan 02, 2008 | Kenmore 24 in. 15933 Built-in Dishwasher
Dishwasher continuously fills....even when switched off.
Sounds like there maybe something stuck underneath the float, The float is the round coffee cup like thing in the bottom of the dishwasher That happend to me and something was just stuck not letting the float rise. I sure hope this help you out I just seen you thread and thought I would try to help you out Hope it does
Dec 12, 2007 | Frigidaire 24 in. FDB635RF Built-in...
Dishwashers Logo
119 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
