Router cannot find internet connection. - Computers & Internet
    Novelist:
  • 116 Answers
Your router should have a port on the back specifically for the internet connection (modem). If you do not plug the modems cable directly into that port you can encounter this problem. If you have, try using a different cable.
In the case that it still doesn't work you may want to reset your router. Most can just be turned off then on again, and some say to simply unplug for 30 seconds.
If that still doesn't help; consult the manual and see if the problem lies in the settings of the router. Without being able to see the router and the PC it's attached to I can't give you a perfect answer. However, try those steps and see what you can come up with. More than likely; if it has worked before it's just in need of a reset. :)
Posted on Sep 11, 2008
Connected wireless to router, excellent signal, but unable to connect to internet.
connected to wireless router with excellent signal may not means you are connected to internet. make sure your modem provided by internet service provider has signal! connect your computer to modem directly bypassing router. If you are online that means your internet is functional. Then connect modem to your Linksys router and use your wireless to log on to internet.
Your router wireless signal active and excellent means you are connected to router not necessarily the internet. The modem supplied by your internet service provider with active internet should be connected to you router on WAN port!
good luck!!
Oct 07, 2011 | Linksys Wireless-G WRT54G Router
Can't surf the internet. Says it's connected to my router but web pages not found
in that case i would first of all i would unplug the internet cord and then wait a minute and then plug it in and then try again and if that doesnt work try rescanning the internet connection
Dec 31, 2010 | Computers & Internet
I have connected my wlan connection. but still bsnl gets connected only through lan. if lan is unplugged it is not connecting through wireless though the wireless connection shows as connected
Connecting to the Internet using a router
  1. Choose a convenient location to begin installing your router, such as an open floor space or table. This does not need to be the permanent location of the router. For wireless routers, it may be necessary to re-position the unit after installing it as the signals may not reach all areas needed.
  2. Unplug the power to your Internet modem.
  3. Power down your computer(s).
  4. Plug the power in to your router.
  5. Connect your Internet modem to the router. The cable plugs into the router jack named "WAN" or "Internet". Turn on your Modem.
  6. Connect one computer to the router. Even if the router is a wireless model, connect this first computer to the router via a network cable.
  7. Turn on the computer.
  8. From the computer connected to the router, open your web browser. Enter the router's address, http://192.168.2.1, and press Enter on your keyboard.
  9. Click Login in the upper right-hand corner of the page. The router does not ship with a password, so just click Submit.
  10. To configure the router to connect to the Internet, you must enter information provided by your Internet Service Provider (ISP) into the "Connection Type" section in the left-hand column under the "Internet WAN" heading of the router's configuration page. If using DSL Internet, you may need to enter the PPPoE username and password. Likewise, if you have been issued a static IP address by your provider, the static IP fields (including network mask and gateway) must also must be set in the router.
  11. If this is a wireless router, change the network name (referred to as SSID). While the router comes to you with a network name set at the factory, you may want to use something more familiar for your network. Read Changing the router's wireless channel and SSID for a description of this process.
  12. Plug the power back into your Internet modem.
  13. Verify that this computer can connect to the Internet properly. Open a new web browser and visit a few Internet sites such as Google.com or Yahoo.com.
  14. Finally, configure additional network security features as desired to guard your systems against Internet attackers.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 19, 2010 | Belkin (F5D7231-4) Wireless Router
I can connect to the router but the router cant connect to the internet. If i directly connect the internet connection to my pc, it has internet connections, so the router is not connecting to the...
Firstly please check the connections. The modem should be connected to the "Internet" port on the back of the router. And the computer can be connected to any of the 4 ports of the router. Checked the lights. They should be steady. If you have a cable connection (cable modem) than you can connect directly to the internet. Else if you are using a DSL connection than you need to configure the router according.
**If this works please rate else let me know in case of further help.**
Jul 01, 2010 | Linksys WRH54G Wireless Router
Belkin 54g Router won't connect to internet.
If you can access the configuration page of your belkin router you have to copy the MAC address of your computer to the router. The router has the capability to clone the MAC address. It's because if you have a cable internet connection the MAC address is registered in the server.
Jan 06, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Router won't connect to the internet.
bypass first the router and check if there is an internet connection. It might be no internet service at that moment.
Feb 26, 2009 | Linksys WRT160N Wireless Router
Ineed to know what blue light tells me that my router is working?
Hi jackmyrtue,
Here's what the lights on the front indicate:
A. Wireless Security
  • OFF Wireless security is off
  • Solid Blue Wireless security is on
B. Wireless-Computer Status
  • OFF Wireless computer is not present
  • Solid Blue Wireless computer is connected to the Router
  • Blinking Amber Problem with wireless computer onnecting properly to the Router
C. Wired-Computer Status
  • OFF Wired computer is not present
  • Solid Blue Wired computer is connected to the Router
  • Blinking Amber Problem with wired computer connecting properly to the Router
D. Router/Power Status
  • When you apply power to the Router or restart it, a short period of time elapses while the Router boots up. During this time, the "router" icon blinks.
  • When the Router has completely booted up, the "router" icon becomes a solid light, indicating the Router is ready for use.
  • OFF Router is off
  • Blinking Blue Router is booting up
  • Solid Blue Router is on and ready
E. Modem Status
  • This icon lights in blue to indicate that your modem is connected properly to the Router.
  • It turns amber when problem is detected.
  • OFF Router is NOT connected to modem
  • Solid Blue Router is connected to modem and functioning properly
  • Blinking Amber Problem with modem
F. Internet Status
This unique icon shows you when the Router is connected to the
  • Internet. When the light is off, the Router is NOT connected to the Internet.
  • When the light is blinking amber, the Router is attempting to connect to the Internet.
  • When the light is solid blue, the Router is connected to the Internet.
When using the "Disconnect after x minutes" feature, this icon becomes extremely useful in monitoring
the status of your Router’s connection.
  • OFF Router is NOT connected to the Internet
  • Blinking Amber Router is attempting to connect to the Internet
  • Solid Blue Router is connected to the Internet
I hope this helps figure out your PS3 issue.
Thanks and don't forget to leave a rating.
Mark
Feb 01, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Belkin Router not allowing an Internet connection
It's not unheard of for a router to fail. When you connected the computer to the Modem, did you use the same cable that was connected to the router? Does your internet connection require a username and password? If so, is that configured in your modem, or the router? If not in the modem it must be the router.
Jan 05, 2009 | Belkin (F5D7230-4) Router (587009)
Lost internet connection?toasted router?
You will need to create your PPPOE internet connection on the router using your ISP username and password, access the router by opening internet explorer and type in the ip address of the router (example) > http://192.168.2.1 the router logon window will appear, use the username " leave blank" and the password "admin" -or- username "admin" with password 1234. Go into internet connections Select PPPOE connection enter your ISP username and password. restart the router and computer this should establish your internet connection. BPCS
Dec 28, 2007 | D-Link DI 514 Wireless Router (DI-514)
Computers & Internet Logo
David Payne
David Payne
