Question about Welding Tools
Miller axcess 40v wire feeder
I have a miller axcess 40 v wire feeder stock# 195182 axcess-s serial# lg025231 then i have a miller invision 456p dc- inverter arc welder stock#903505 serial# lf152585 im trying to conect my wire feeder to the base unit arc welder the feeder has a data cable millier electric p/n 202573 but the remote cable for the feeder does not fit the remot plug on the arc welder can i get an adepter or a wireing diagram to show me which wires do what from the feeder so that i can hard wire the feeder remot cable to the arc welder its easy to get to but im not sure which wires would need to go whare
  • 2 more comments
  • jasonangel29 Sep 13, 2008
    thanks alot i hope you can help
  • jasonangel29 Sep 15, 2008
    did you have any luck yet i hope their is some hope thank you for your time
  • jasonangel29 Sep 16, 2008
    thanks alot i hope something pans out
  • Anonymous Mar 13, 2014
    When I step on the pedal, there is no arc nor does the gas flow. When I switch from "Remote" to "On" there is an arc and gas flows. I've traced continuity from the pedal all the way to the main circuit board and it all checks out. Is it possible the problem isn't on the main circuit board?
Just checking to see if you got any ideas on this problem
Posted on Oct 27, 2008
    President:
  • 1,263 Answers
Give me a day or so and i will have the solution for you
Posted on Sep 13, 2008
  • Ronald Mueller
    Ronald Mueller Sep 16, 2008
    i'm still working on it . had a few leads not pan out yet.
I need a manual for a airco welder. Stock number1341-0266. Serial number hk220507. Thank you.
This was made by Miller. It is the same as a Miller Dialarc 250 ac/dc.. Go to www.millerwelds.com, then "service", then "owners manuals" then "search", and scroll down until you find the dialarc.
Apr 22, 2015 | Welding Tools
Miller S-54D 115V digital wire feeder that does not weld right.
Hi Kevin,
Causes of poor penetration: Travel speed too fast, welding current too low,
poor joint design / and or preparation, electrode diameter too large,
wrong type of electrode, excessively long arc length.
Solutions: Decrease travel speed, increase welding current, increase root
opening or decrease rootface, use smaller electrode, use electrode with deeper
penetration characteristics, reduce arc length.
Mar 24, 2010 | Miller Welding Tools
I have a Mastercraft AC-230 welder (58-8009-8) with helmits and accessories for sale. It is quite old and user has passed away. How much can I ask for this??
It is impossible to give a price without seeing the lot for sale, I will say that AC Oil cooled sets are a shop luxury and Manufactures of fertilizer would give you a good price, find a friend in the welding game, get his advice,
Jan 27, 2010 | Miller Electric Mfg Co 903505 Invision...
Changing from 480v 3 phase to 220v single phase need diagram on a Miller Dynasty DX tig welder Serial # KH577649 stock 903519-01-1
i have a old miller thunderbolt CC*AC/DC welder its wire single phase 480 can it be switched to 220 single phase
Dec 02, 2009 | Miller Welding Tools
I have an old mastercraft 110 volt ac stick welder model 110-104 have not used it for years have lost the instruction manual plate on the machine says primary voltage is 115 and primary amperage is 26.6...
35 amp should do nicely however make sure the mains cable is of the correct size, better still, get a qualified Electricion to install it.
Usualy 30amp could be used but using 35amp gives you some reserve
Oct 03, 2009 | Miller Electric Mfg Co 903505 Invision...
Need to know on the 14 pin connector what color wire goes to what pin on a miller s-22p12 remote
I would go to www.millerwelds.com and download the owners manual based on your serial number. It will insure you get the correct wiring diagram for your feeder.
Aug 21, 2009 | Miller Welding Tools
Im tryint to conect my wire feeder
ask weld tech at a welding supply store and ask if your components are compatible (since most wire feeders are 24 volts).
Dec 19, 2008 | Welding Tools
Mastercraft arc welder
i have a mastercraft welder wire feed , the power turns on the wire feed works and the fan in side turns on but it will not weld not even a spark! can anyone help?
Aug 30, 2008 | Miller Electric Mfg Co 903505 Invision...
Welding Tools Logo
385 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
