Question about HP Photosmart R707 Digital Camera
HP R707 My HP R707 5.1 camera lens is stuckout and will not go back in or out when powered on. It only makes a beep sound and turns off automatically
  • jerry-g2947 Sep 21, 2008
    battery went dead with the lens open, new battery won't operate it to close. it was not jamed
    Problem Solver:
  • 13 Answers
Get the adapter plug it in,, in the camera that little hole next to the usb,,, just like u will charge the battery, then turn the camera on,, just your camera lens will be back to normal,, hope i helped ya out.
Posted on Sep 30, 2008
My Samsung TL205 digital camera will not turn on. The lens is out but when I press the power button, the green on button will light up then the camera will make one beep sound as the green light turns off....
I just fixed my camera. I pushed the lens inside completely. took the battery out and put it back in. turned it on and off a couple of times and ready to go!! good luck!
Feb 17, 2011 | Samsung DualView TL205 Digital Camera
Zoom Lens stuck out, won,t close. Says camera problem #E45
that error code indicates the the Lens of teh camera is already defective., In most cases if the lens is stuckout or stuckin camera will not stay On or It will not Turn On at all. For this case you need to call Tech support to send you camera for repair toll free 1 800 235 6325 extension 12
Nov 12, 2009 | Kodak EasyShare V530 Digital Camera
Lens does not go back in and won't turn on and beeps. I turn the power button on and the lens makes funny noise and won't go back in. Then the camera beepsa and it doesn't turn on
That sounds like the gears in the lens drive have broken or are out of alignment. Not cost effective to fix unfortunately so you should look for a replacement camera UNLESS you are under warranty.
Oct 24, 2009 | Olympus FE-20 Digital Camera
Lens stuc and makes beep sound
I had the same problem and my brother just wiggled the lens shut carefully while turning the power on at the same time , it took about 5 tries and finally had the lens was all the way back in place and it works great.It was just the lens was stuck open and would not start up like that I guess. better then junkin it.
Sep 01, 2009 | Samsung BL103 Digital Camera
Three beeps when i try to turn it on
i had the same problem a while back. I fooled around with my camera lens a bit and it turned out that one side of the lens was sticking out a bit. I pressed down on this and pushed the power button and it worked. The next time I turned it on the same thing happened but if you keep doing the same thing it should work.
Hope this helps!
Aug 21, 2009 | Samsung L100 Digital Camera
When trying to power up hear 3 beeps and camera turns off.
Make sure the batteries are good and in right. If it keeps doing it you might be having a problem with your lens opening up and staying open, I had a camera that did that to me, and the lens had been knock and wouldnt open properly, check that out. The lens was out of range from normal and would automatically shut down
May 09, 2009 | Cameras
Lens is stuckout and will not turn on
I hope this works for you; I had a similar problem with an HP camera. Please get back to me so I can alert the 50 other people with this problem if it does work :D
IF the camera isn't in warranty, then twist the large inner cylinder gently until it retracts while it is on.
If this fails, then unscrew four screws from the base of the camera and three screws from the side. Pry it apart and clean the circular metal bit which is underneath the selection dial with a soft cloth. Rescrew the camera casing together.
Apr 15, 2009 | Kodak EASYSHARE V1253 Digital Camera
R707 lens open, lcd shows hp, beeps, then turn OFF
Try to reset the camera - remove the battery and press the reset switch for about 5 seconds. Reinsert the battery. If it works while connected to the charger, your battery needs to be replaced.
Feb 22, 2009 | HP Photosmart R725 Digital Camera
HP R707 camera
Jun 20, 2008 | HP Photosmart R707 Digital Camera
HP Photosmart R707 Digital Camera Logo
113 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
