Question about Vizio P2 42 in. HD-Ready Plasma Television
Dtv/tv the tv cabie input came out. how do i fix it
    Problem Solver:
  • 12 Answers
It cannot be done by ur self but if u have a electronics knowledge u can open the back cover after unplugging the cable cord and check for the power sock connection near the main switch of ur tv (please dont touch any other components of ur tv as it contins 28 kv of heavy power)
thats it
from prasadmalladi@ymail.com
Posted on Sep 24, 2008
The DTV input in my GV46L stays black. Why?
You don't say what you are trying to input but take note that your model does not have a digital tuner on the DTV input. If you use a digital OTA antenna, the signal must first go through a digital converter or tuner before it goes into the DTV input. The DTV/ANT input is only cable ready. There is no digital tuner in the TV to activate the DTV menu.
Nov 02, 2012 | Vizio GV46L 46 in. LCD Television
How do I connect my Sansui 6010B VCR with an analog TV and a DTV tuner?
two ways of connecting VCR with Analog TV with DTV tuner.
DTV tuner (RF) output to VCR (RF) input,VCR (RF) output to analog TV (RF) input.
turn DTV tuner on (VCR should have a TV\VCR switch that makes signal coming from tuner BYPASS VHS right into TV) note:: change channel FROM tuner.You should be able to record by placing a blank tape and pressing RECORD.
2ND. DTV tuner, VCR, should have a RCA in\out connections...Audio & video.You need a RF\RCA bypass switch. It has a INput with RCA connections to a RF signal out that goes to the RF Input of analog TV
Jun 21, 2011 | Sansui VHF6010 VHS VCR
How do i get 1080i, my tv shows im only in 480i. i think i might have it hooked up incorrect. my other tv of another brand is much newer so all i did was connect the hdmi cable from the tv to the cable box...
Hello
Your TV will display all High Definition signals as 1080i True HDTV™ and all standard definition signals will be displayed as 480p.
Component Inputs 1-2
YPbPr(480i/480p/1080i)
These inputs can be used for the connection of A/V equipment with component video outputs, such as a DVD player or external HDTV receiver. Please see Appendix B for signal compatibility.
Input DTV (480i/480p/1080i)
This input is used to connect an external DTV receiver, and can be configured for YPrPb and RGB plus H&V signal types.
As a special feature, you have the ability to adjust the red and blue light beams in reference to the fixed green light beam. This process is called convergence. There are two separate memories for convergence. One, for SD 480i/480p signals; the other for HD 1080i signals. SD convergence should be adjusted while watching an SD source and HD convergence should be adjusted while watching an HD source.
Wide Expand: Enlarges the picture, cropping some of the image on both sides. This Expand format is useful to remove or reduce black side bars on HD broadcasts of 4:3 images with black bars. Available for analog 1080i, digital SD 16:9 and digital HD signals.
InputDTV
This input is compatible with most standard DTV and satellite receivers with component video (YPbPr) outputs. Compatible DTV signals are SDTV 480i/480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Please check the DTV receiver specifications before connecting.
This input is compatible with some DTV receivers using RGB with "separate H and V sync". Compatible DTV signals are SDTV 480i, 480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Industry standards for DTV RGB signals (systems, synchronization, timing, and signal strengths) are not currently established. These inputs will not be compatible with all DTV receivers that offer RGB, HV outputs. RGB, HV signals with less than 5 cables are not compatible.
If your DTV receiver offers both DTV component video signals and DTV RGB, HV signals, we suggest you use the DTV component video signals. Check the DTV receiver specifications before connecting.
Ok.
Feb 05, 2011 | Mitsubishi WS-73909 73" Rear Projection...
Vizio VP50 HDTV: I connected an HD antenna for first time on the TV and when I switch to DTV the screen goes blank, remote inoperable. Only controls on side of TV work, but there is no way to do a scan...
I have the exact same problem. It may be the tuner board is bad. I did some research and it seems like this tv is junk. I saw a link that said call Vizio and they are aware of all it's problems and are willing to give a new tv free of charge. I called and they knew nothing about it, but did offer to fix it out of warranty for $285 all problems fixed out the door. Also, TV locks up on RGB input and can't switch inputs until I hooked a computer to the RGB input, then I was able to select a different input.
Please post if you found a solution to the DTV issue..
Jan 26, 2011 | Vizio P50HDTV10A 50 in. Plasma HDTV
Want to run my dtv receiver through new digital converter box.
You will not be able to record local station from a DTV converter connected thru a directv receiver unless there is a a/v input on the directv samsung receiver. Also check the user manual for this receiver if recording from an external source such as a DTV converter box is possible. The answer to seperating the DTV converter box from the directv samsung receiver is possible if your tv has multiple inputs. Try connecting the DTV box to the RF input and the directv samsung box to an a/v input then change inputs using the tv remote. you will need an av cable (yellow/ red/white) for the directv box and a rf jumper cable for the DTV box.
May 17, 2009 | Samsung SIR-S4040R DirecTV DTV Receiver /...
I cannot get my phillips dvd/vhs hooked up, i have direct tv can you help me? thanks Joe
Ok the DTV box must have connections that first run to the dvd /vhs ( out of outputs on DTV box into the inputs on the dvd/cd player then from the player out to the TV RED/WHITE/YELLOW inputs! make sure your tv and unit are on channel 3
This should fix ya right up! If you need more help come back and see us!
(Please use the ratimgs system! This keeps this site free)
Dec 14, 2008 | Televison & Video
Scanning dtv channels
go to menu setup and do the full system reset setup option... Then before you scan for channels make sure it is set to cable... This fixed the problem for me.
Dec 06, 2008 | Vizio L32 32 in. LCD HDTV
It wont show the movie
check the av cabIe and aIso the input of the tv. i simtom persist consuIt your near shop
Apr 10, 2008 | Televison & Video
Make TV go to 1080p
make sure that you have your HD source hooked up to the correct input on the tv. you are going to want DTV as the input.
Feb 13, 2008 | Mitsubishi VS-60805 60" Rear Projection...
Digital Television
Check the back of the tv if there are at least two coaxial inputs on the back. They are the type of inputs for a standard cable that screws into the back of the tv and would look like they have threads on them. If your tv only has one coaxial input it probably is not DTV ready. Alternativley, use a search engine site (google, ask, yahoo etc.) type in the make and model number of the tv. Some websites go into detail as to how many inputs a tv has as well as what resolutions they support, dtv compatible, hd compatible etc.
Jan 13, 2008 | Televison & Video
Vizio P2 42 in. HD-Ready Plasma Television Logo
41 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
