Question about Panasonic Televison & Video
My Panasonic HDTV Projection Monitor/TV has lost it's brightness. It still has a picture but dark.
  • gary147 Sep 14, 2008
    can you direct me to a link that I could get inst.?
  • gary147 Sep 19, 2008
    Thanks for the advice....I am about to order the kit but I just want to confirm something. My picture is not faded or fuzzy, just dark...like when the brightness is turned way down..other than that the picture is fine..I can still read print if it is white...I am not questioning your expertise...just want to make sure it isn't something else causing the darkness other than the coolant?
  • Panasonic Master
  • 8,617 Answers
THe coolant in the CRTs most likely needs to be replaced. this is a very common problem in Phillips and magnavox rear projection TVs.
Posted on Sep 11, 2008
Dark picture
Please check your TV's Picture mode setting. Use the VIVID picture mode to achieve the brightness video.
Mar 11, 2014 | Panasonic PT-50LC14 50" Rear Projection...
I have a panasonic pt-61hx42 tv and the picture is dark and hard to see night sceens Is there another bulb besides the three colored bulbs
have you already check in the menu adjustment with the brightness,how about cleaning of the reflector inside doesn't work?
Sep 27, 2012 | Hitachi 46F510 46" Projection HDTV
Sony KDF-E50A10/4 dark picture
Dark picture is indication that tv needs new lamp.
Replace lamp in tv get bright picture, please buy Sony original lamp for good picture in tv.
Jun 17, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Even with a new panasonic bulb;the picture is not as bright as when it was new.prob?
We replaced the lamp on our pr61lcx65 rear projector panasonic tv. We still have colorful spots and now it is getting darker and have yellow on bright picture and red on dark picture running through it. Please help.
Feb 10, 2010 | Panasonic PT-61LCX65 61" Rear Projection...
Dark Picture no brightness
Sorry But your TV is Not DLP,it is projection it has 3 Tubes Red/Green/Blue Deflection Board for this
TV cost $508.35 {Encompass Parts Distrubtion} Has the Boards for this TV 1-800-638-3328
Jan 21, 2010 | Hitachi 51F59 51" HDTV Projection...
Chage bulb tv is still dark
The wrong or faulty lamp may cause darkness
Apr 21, 2009 | Panasonic PT-52LCX66 Projection Television
My picture is dark and have changed the brightness
Hello!
Well it seems that your lamp is about to go out, replacing the lamp might jus do it ! Also make sure you get a Philips lamps, they work like a charm.
And regarding the long plastic cover just be a little bity patient and you'll make it come off, just make sure you do remove all the screws.
Apr 18, 2009 | Panasonic PT-53WX53 53" Rear Projection...
This model is notorious for needing a new lamp about every 2 years. The lamp is accessed through the front by removing the long plastic cover under the screen (it just pulls off). Under that, to the left of center, is a square cover with one grey plastic screw. Loosen the screw and pull the lamp assembly out. It should just slide right out. Turn it around and look at the lamp. If the lamp face or reflector looks "cloudy" or "misty". Replace the lamp with Philips part number TY-LA1000. Just Google the number and you will find them available for around $100
Mar 18, 2009 | Panasonic PT-43LC14 43" Rear Projection...
Televison & Video Logo
147 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
