Question about Archos Gmini XS200 MP3 Player
Freezing well my mp3 keeps freezing when i listen to music as it's charging.and the way i stop it from freezing is to undo the screws on the front and lift the top of then it goes off then i put the cover back on and it works perfectly but when i done that last night as i lifted the top off a strap came out and now i don't know how to put it back together and i tryed puting it back on but there was no picture
  • Anonymous Nov 20, 2007
    my archos Gmini XS 202 freezes and won't work until the next day
    President:
  • 3,130 Answers
Im not sure how to put back in the strap but if you gotta loosen the cover or tighten it to get it to play theres a crackin the flex or main PCB.
Posted on Apr 15, 2006
Disassemble Krups XP 7245
Pull the drip tray out
Whack the silver surround on the front (see photo) upwards with the heel of your palm, it clicks up and off.
Remove beans lid, it clicks up when open
Undo 1 or 2 screws holding beans container in
Flip open or remove front top panel
Undo I think 3 screws holding top cover, 2 out wide on the top front and one down a tube in middle back.
Lift front edge of top cover up and wrack it about a but to release the clips
Undo 2 screws at the back covered by the water tank, down tubes
Remove side waste bin and sliding drawer thing
Remove 2 screws from the front through to the the sides (2x total not 2 each side)
Sides and back assembly now slide backwards, that's it, you are inside now.
Oct 01, 2015 | Krups Compact Automatic Espresso XP 7245
Tip
How to replace the door seal on an Ariston or Creda washing machine
Hi.
The procedure is quite complicate, because the seal is secured to the front panel, and you will need to remove top panel, detergent drawer and access control assembly
  1. Disconnect appliance from power
  2. Remove the door, held by two screws located on the rear side of the lid.
  3. Lift the top panel, held by two screws at back.
  4. Undo the two screws joining the detergent dispenser to the inlet valve.
  5. Undo the two screws located at the front corners. So to release the fascia and dispenser.
  6. take out fascia and the dispenser alltogether and put it on one side. Take care to not disconnect wiring and do not drop parts.
  7. Release the retaining wire that keep the seal secured to the front panel. Look after it, you will need it again.
  8. Undo the two screws that hold the front pane. They are located on the front side.
  9. Remove the kick panel
  10. Behind the the kick panel you will find the two screws that will release the front panel, remove both of them.
  11. Disconnect the door switch conntector.
  12. Lift the front panel. You may need to help yourself using a putty knife.
  13. Remove the clip with two hooks inside, it is located about postion one o'clock. This will finally release the seal.
  14. Remove the seal and clean the area where you will fit the new seal.
  15. Start mounting the seal from the lower part on the right, at about four o clock. You will notice the seal matching.
  16. Put back the retaining wire usingf long-nose pliers to put the wire in tension.
  17. Reassemble the washer in reverse order.
Mark connector and keep screws ordered and separate while doing the procedure above. This replacement is suitable for an expert DIYer.
on Apr 08, 2010 | Ariston Technologies AWD120 13 lb. Washer...
Can you keep player plugged into usb charger while playing music files indefinatly or will it over charge and possibly cause damage? im shopping around and am not even shure it will play while pluged in to...
You can keep the Sansa plugged in without fear of overcharging. The Sansa will play while it is connected to a USB port that is supplying only power, such as a USB charger operating off a car cigarette lighter. It will not play while connected to a computer.
Mar 09, 2011 | SanDisk Sansa Clip MP3 Player
Solution for washing machine
  1. remove top cover.
  2. Remove soap dispenser draw.
  3. unscrew the screws securing the the soap dispenser to front console.
  4. Pull timer dial off, noting position of symbols.
  5. slide console panel to right, and lift up out of way of front panel.
  6. Undo 3 screws securing top of front panel.
  7. undo 2 screws securing door interlock to front of panel.
  8. Remove plastic clip securing door seal to front of panel.
  9. remove wire clamp band round front of door seal.
  10. Undo 3 screws at bottom of front panel securing it to cabinet .
  11. remove front panel.
  12. Unscrew thye top wire clamp band securing the seal to drum front.
  13. remove door seal.
  14. Fit new door seal, making sure the drainage holes are at the bottom dead center.
  15. reassemble in reverse order.
  16. Please rate my solution.
  17. Thanks.
Nov 06, 2009 | Washing Machines
Mp3 charging problems
it sounds like the battery/cell is faulty.
May 14, 2017 | iSonic SnapBox X25 (2 GB, 500 Songs)...
Sansa c150
Wait till it runs out of power then charge it. It should charge up normally.
Jul 07, 2009 | SanDisk Sansa c150 MP3 Player
My mp3 won't play music charge or anything
you can try this, on the back of the unit theres 4 very small phillips head screws, if you take them out you can remove the battery and then put it back in and see what happens, if the conditions still the same you can purchase a new one on Amazon for short money, it comes in a kit with new screws and a little screwdriver.
Mar 20, 2009 | SanDisk Sansa E280 MP3 Player
Inglis Citation dryer squeeks
Either you will have 2 screws at the very bottom of the front panel. If not pry the top up at the edges with a wide screw driver. From there undo your door switch wires and look inside the front panel toward the top, remove 2 more screws and front panel will lift out lay on it's back when you do this to keep drum aligned and prevent from falling out.
Mar 19, 2009 | Dryers
Keeps Freezing
http://serviceman.site88.net/index_files/MP3Players.htm
Jul 04, 2008 | Creative Labs Zen Touch MP3 Player
Archos Gmini XS200 MP3 Player Logo
82 people viewed this question
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
