Red color out of focus samsung 10801 - Televison & Video
  • lunatic7 Dec 26, 2008
    I have a Toshiba 57h93, the red color is out of focus.
  • 203 Answers
Do you have a model number? Sounds like you have a convergence problem if you have a CRT rear projection tv. If you provide a model # i will be able to assist you in solving this problem.
Posted on Sep 11, 2008
Samsung three colors on screen, out of focus #hcl4715w
It is a convergence problem. The IC's (integrated circuits) or STK chips or the "guns". You have a red,and blue, IC's that provide all the colors. When the colors are out of convergence, you get ghosting or what looks like 3D pictures. I haven't been able to locate the part numbers for the IC's or STK chips but have located a convergence board. No luck determining if IC's are included (a phone call first to verify) but if they are, would make life much easier for you to install. Part # is BP95-00415H
Typically, IC's cost around $10 or less. here is a link to a guy who provides pretty good instructions on replacing the IC's along with pictures.
Hope this answers your questions. Best of luck.
May 31, 2009 | Samsung HCL4715W 47" Rear Projection...
Blue gun out of focus
There is a manual focus adjustment above and between the red and green gun, located in the front of the TV behind the panel; It is a small black box about 3X3" . This has all three adjustments .
Apr 21, 2009 | Samsung HCM5525W 55" Rear Projection...
Will not show red color in picture, magic focus shows red though
You have a projection light element out. I had the green element go on mine. I had a service agreement so a repair tech changed it.
Feb 07, 2009 | Hitachi 43UWX10B 43" Rear Projection...
No blue just red and green tint
adjust the blue bias on the high voltage block .
it has focus and bias for all three colors
Dec 26, 2008 | Samsung PCL5415RB 54" Rear Projection...
Samsung Rear Projection Problem (not convergence)
The tv has 2 focus adjustments for each tube, mechanical and electrical.
1. Mechanical focus is set by looking at screen from back (through inspection plate on back of most samsungs) and rotating the lens assembly on CRT. loosen wing nut and turn lens assembly to go through focus and back to best position.
Put convergence pattern on screen and manually misadjust bottom red and green lines convergence so they can be seen through inspection hole.
With back cover of TV off you can usually reach your hand up beside the lens assembly to loosen the wing nut then rotate to adjust. Green is in the middle. The focus will be obvious when you rotate and look
When you are finished make sure the foam dust protector is not over any of the lens assemblies and the wing nut is tight.
2. Electrical focus - located at front of unit. the front grille/speaker cover is removed and maybe a cover over the front crt inspection hole.
In the inspection hole there is a black plastic "Focus/screen adjust Assembly" with 2 rows of 3 controls.
One row is focus and the other is screen. The middle controls are for green with R/B on either side. Usually the controls are labelled as "focus" and "screen". You want to adjust the focus controls, one for each color. Look for the focus or screen label imprinted in the plastic. Don't play with the screen settings.
With the same misadjusted convergence pattern you can see a red, blue and green line. Adjust green focus and watch green line for best focus. Do same for other 2.
Screen adjustments are very exact and delicate. The easiest way to deal with them is to turn color off in Customer adjust menu. Put any color tone adjustments in the middle (low, med, high, put at med).
You should have a b/w picture if there are no crt or other color related faults. If it is close to B/W leave screens alone.
If the pix is too green, then the green screen setting must be reduced a small amount. Do not play with these adjustments as most TV repairrers have a difficult time adjusting them.
If focus adjustments don't help then focus control or CRT may be defective. Needs expert to determine.
Jun 24, 2008 | Samsung HCM4216W 42" Rear Projection...
Samsung HCN4226W blue color outlines
Samsung parts for convergance problem
This convergence board works with the following Samsung television models: HCM4215W, HCN529WX, HCN559WX/XAA, PCN5425R, HCN4226WX, HCN529WX/XA
Mar 10, 2008 | Samsung HCN4226W 42" Rear Projection...
Blue color problem
same here, fuzzy blue when trying perfect focus, all other colors are sharp. I have the 2 STK392-040 package
Feb 24, 2008 | Samsung HCN4226W 42" Rear Projection...
Out of Focus
· Samsung parts for convergance problem
Nov 24, 2007 | Samsung HCN4226W 42" Rear Projection...
HCL4715W Rear projection CRT problem
your screen and focus controls need adjustment to acheive a good grey scale picture the adjustment are not on the crt neck boards.(focus block)
Aug 29, 2007 | Samsung HCL4715W 47" Rear Projection...
HCL4715W Rear projection "Red" color is dim
screen adjustment,remove front bottom cove and find the focus block the screens are also on the same block,if your not sure don't try.
Aug 28, 2007 | Samsung HCL4715W 47" Rear Projection...
Televison & Video Logo
66 people viewed this question
Top Televison & Video Experts
