Question about Lexmark S305 IMPACT LEXS All-In-One InkJet Printer
When I go to print a document, it pulls the paper through, but does not print
  • Official Brand Answer
  • 3,344 Answers
Try to clean the printhead nozzles on your Lexmark Impact S305 printer. From the printer operator panel, press Setup button > Maintenance > Deep Clean Printhead. Your printer will then print a page forcing ink through the printhead nozzles and clean them.
If that doesn't help, please visit the Lexmark support page to determine if your printer is affected with the printhead issue. Also, make sure your printer is updated. The firmware update will help give you a highly reliable print system.
Click here to validate your serial number and/or update your firmware.
Posted on Sep 26, 2011
SOURCE:
At random times, when a user prints, a document, pdf, picture ect.., it's slanted. It also happens when a user scans to themselves. What can cause this to happen?
There mite be something in the path of the paper which the paper hits and so it is slanted have you tried scanning on the big glass instead of thru the document feeder does it happen then? Now the printing is something else are you talking about copying or printing. If print I would check the paper draws ensure the guide are snug up against the paper. Do you internal prints slant such as the meter count print out or the fax info reports. or the demo page? If the problem is coping then place the original on the big glass and see if the slant There are small mylar guides though out the document feeder if some one pulled the original document out in the wrong direction they mite have flipped on of them causing a corner of the paper to hit one slanting the original ALWAYS pull the original out in the same direction as the flow of the document. Try sticking a business card down thru the way the paper flows you mite be able to reset the offending mylar.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jul 22, 2014 | Konica Minolta bizhub C250 All-In-One...
I have a lexmark x6570 printer it will not print on both sides of the paper anymore it use to print on one side then pull the paper back in as use the other side
Please follow steps below on how to print 2-sided on your printer:
Printing on both sides of the paper (duplexing) automatically:
  1. Press printmastert_76.jpg.
  2. With a document open, click File > Print.
  3. Click Properties, Preferences, Options, or Setup.
  4. Click the Print Layout tab
  5. From the Duplexing area, select Use Printer Settings from the drop-down box.
  6. Make sure the printmastert_77.jpg light is on.
  7. Click OK to close any printer software dialogs that are open.
Printing on both sides of the paper (duplexing) manually:
  1. With a document open, click File > Print.
  2. Click Properties, Preferences, Options or Setup.
  3. Click the Print Layout tab.
  4. From the Duplexing area, select Manual from the drop-down box.
  5. Select the Print manual duplex instructions check box.
  6. Press Start.
  7. The printer prints the odd-numbered pages and the instruction sheet, which describes how to flip and reload the paper.
  8. Following the instruction sheet, flip and reload the paper with the printed side facing away from you.
  9. The printer then prints the even-numbered pages on the reverse sides of the odd-numbered pages, completing the two-sided sheets.
Note:
  • printmastert_78.jpg button is not functional with a Macintosh operating system. You can print two-sided documents with a Macintosh operating system by using the settings in the Two-Sided menu of the Print dialog.
  • Automatic two-sided printing (duplexing) works only with plain paper in letter and A4 sizes. If you want to print two-sided documents on another size or type of paper, use the manual duplexing method.
  • To return to single-sided printing, make sure the printmastert_79.jpg light is not on.
Aug 31, 2011 | Lexmark X6570 InkJet Printer
The printer is constantly sending a message- 'paper jam'
HP Officejet 7200, 7300, and 7400 Series - 'Paper Jam: Clear jam, and then press Enter' Message Displays on the Control Panel Display
Issue
During printing, the paper becomes stuck in the all-in-one and the error message 'Paper Jam: Clear jam, and then press Enter' displays on the control panel display.
Solution
Use the following instructions to clear a paper jam from the product:
Step one: Check for and remove any loose paper from the In tray
Do not try to remove jammed paper from the In tray. First remove any loose paper from the In tray to avoid worsening the jam.
CAUTION: Always try to remove jammed paper from the back of the printer first to avoid mechanical damage.
Step two: Clear the jam from the back of the printer
Follow these instructions to clear jammed paper from the back of the product. If the product is equipped with a two-sided printing accessory, skip to that section.
Remove the rear access door to clear the paper jam
1. Remove the rear access door by pressing the buttons on the side of the door and pulling it toward you.
Figure 1: Removing the rear access door
Rear access door
2. Gently pull the jammed paper out of the rollers.
WARNING: If the paper tears while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the product. If all the pieces of paper are not removed from the product, more paper jams might occur.
3. Replace the rear access door. Gently push the door into the all-in-one until it snaps firmly into place.
Remove the two-sided printing accessory to clear the paper jam
1. Remove the two-sided printing accessory by pressing in the buttons on the sides and then pulling the accessory toward you.
Figure 2: Removing the two-sided printing accessory
2. Gently remove any jammed paper.
WARNING: If the paper tears while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the accessory. If all the pieces of paper are not removed from the accessory, more paper jams might occur.
3. Press the button on top of the two-sided printing accessory to open the door.
Figure 3: Opening the two-sided printing accessory door
4. Gently pull the jammed paper out of the rollers.
5. Close the accessory door.
6. Reinstall the two-sided printing accessory.
Step three: Clear the jam from the automatic document feeder (ADF)
1. Remove the document feeder tray from the product by gently pulling it.
2. Lift the cover of the automatic document feeder by pulling it outward.
Figure 4: Lifting the cover of the automatic document feeder
Automatic document feeder (ADF) door
3. Gently pull the jammed paper out of the rollers.
WARNING: In the rare occurrence of a severe paper jam, you might need to remove the face plate from the front of the automatic document feeder and lift the pick assembly to remove torn pieces of paper from deep inside the automatic document feeder.
4. Close the cover of the automatic document feeder, and then reattach the document feeder tray.
Step four: Verify that the print carriage can move freely
Follow these steps to try to move the print carriage.
CAUTION: Do not force the print carriage to move if it is out of plain view or feels stuck. Forcing it may damage the printer.
1. With the product turned on, open the print cartridge access door. The print carriage might try to move into the access area. If so, allow it to move to that position.
2. Without turning off the product, unplug the power cord from the back of the product. Unplug the power cord from the power source. The power cord must be unplugged to allow the parts to be moved by hand and to reset the paper feed mechanism, without the risk of an electrical shock.
3. Looking in through either the print cartridge access door or the output paper tray, make sure the print cartridges are locked into the carriage and have not come loose. Also, make sure that there are no obstructions under or around the carriage to block it from moving.
4. Make sure the print carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right. Clear any obstructions found.
You may have to reach through the output paper tray to access the print carriage.
5. Close the print cartridge access door and plug the power cord back to the back of the product. Plug the power cord into the power source.
6. Press the On button to turn on the product.
Step five: Reload and test the printer
After you have removed the jammed paper, make sure the product is still functioning properly.
1. Reload the product with plain paper.
2. Peform a self-test by pressing and holding the RESUME button on the control panel until the product begins printing. A test page prints.
Step six: Service the printer
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Dec 30, 2009 | HP DeskJet 3745 Printer
Lexmark 5400 series printer won't grab paper for printing
Whenever the printer doesn't pulls the paper please pull the pack of papers, browse through the papers with your finger and put them back gently.If it doesn't work it means the wheels that pull the paper are worn and you need to replace them.
For the second problem, this is not a printer problem but a software problem, please specify which software do you use so we can help you, as each software has individual options to print multiple pages. It will also be more logical to post the problem in the specific software area.
Good luck,
GetAFix99
Nov 17, 2009 | Office Equipment & Supplies
How can I stop my hp deskjet 960c from printing unwanted pages once it has started printing?
Turn the printer off and unplug the printer cable from both ends (printer and computer ) and cancel the documents from the printer list.
Sep 25, 2009 | HP DeskJet 960c InkJet Printer
Pulls in multiple sheets of paper
you must not use thin paper. you should use thick paper so that it will only pull one paper at a time...
Apr 18, 2009 | HP DeskJet 940c InkJet Printer
Paper light won't turn off
Tryloading paper in tray 1 / bypass assembly. Pull down the black tab under the HP logo
Feb 20, 2009 | HP LaserJet 1320 Printer
How to change paper size on axerox phaser 8500
From a Windows Operating System:
  1. From the computer, open the document to be printed within an application program.
  2. Click on [File] on the toolbar, and then click [Print]. The Print window will be displayed.
  3. Click on the [Properties] button, or the [Printing Preferences] button. The Properties or Printing Preferences window will be displayed.
  4. Click on the [Paper / Quality] tab.
    NOTE: Most applications will automatically provide the page size information to the driver. If not, steps 8 - 10 describe how to create a custom page size.
  5. Select the required paper size from the Document Size pull down menu, if available.
  6. If the required custom paper size is not available click on the [My Customer Sizes…] button.
  7. To create a new custom paper size setting click on the [New] button.
  8. In the Name field enter the name to be given to the custom paper size. For example 127 mm x 394 mm (5 in. x 10 in.)
  9. In the Width field enter the width of the custom paper size.
    NOTE: The width should always be the short edge of the paper. For example, if the custom size is 127 mm by 394 mm (5 inches by 10 inches), the width must be set to 127 mm (5 inches) regardless of the orientation of the document or the feed method on the printer.
  10. In the Height field enter the height of the custom paper size.
    NOTE: The height should always be the long edge of the paper. For example, if the custom size is 127 mm by 394 mm (5 inches by 10 inches), the height must be set to 394 mm (10 inches) regardless of the orientation of the document or the feed method on the printer.
  11. Click on [Save]
  12. Click on [Close].
  13. Select the required paper size from the Document Size pull down menu.
  14. Click on [OK] twice to print
From a Mac OSx:
  1. Click on [File] on the application toolbar, and then click on [Page Setup]. The Page Setup window will be displayed.
  2. From the Printer Description pull-down menu, select the correct PPD file for your printer.
  3. Select the custom paper size for your document from the Paper Size pull-down menu.
  4. If the required custom paper size is not available click on the [Manage Custom Sizes…]. The Custom Page Sizes window will be displayed
  5. To create a new custom paper size setting click on the [+] button.
  6. Double click on [Untitled] and enter the name to be given to the custom paper size.
  7. At the Page Size field enter the width and height of the custom paper size.
  8. Click on [OK] twice.
Apr 22, 2008 | Office Equipment & Supplies
Print Output
Try cleaning the feed rollers. these are the rubber wheels that actually contact the paper and pull it through. If they get dirty, their grip on the paper will be less than adequate. Just use some clean water, or perhaps some rubbing alcohol, and a clean rag to wipe them thoroughly.
Feb 11, 2008 | Lexmark X85 All-In-One InkJet Printer
Document feeder works for printing but not for scanning
Hi, When you had the doucment feed jam were you able to clean or remove any paper that might be blocking the paper to be scanned? It sounds like there is paper still in the document feeder , I would open the DF and check very closely to make sure no paper is in the way!Good Luck!
Dec 02, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Lexmark S305 IMPACT  LEXS All-In-One InkJet Printer Logo
254 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
