Question about Refrigerators
How to replace water dispenser handle Frigidaire
  • AMDB9 Dec 22, 2008
    The water dispenser inside the refrigerator is dripping. How do I remove the dispenser without damaging it or the refrigerator. I suspect a faulty gasket or seal in the dispenser valve may be the problem.
  • coach_lumpy Dec 23, 2008
    It looks to me like you get the dispenser out by removing the plastic cover and rubber seal...hopefully this exposes mounting screws...is this correct and are there any surprises when trying to access this, so I can remove the whole unit? My water dispenser handle snapped off...I know a new one is about $55 and looks like replacing it requires removal of the whole unit and replacing it on the workbench and then reinstalling the whole unit. Is this correct?
    John L
HOW AND WHERE CAN I GET A NEW WATER DISPENSER HANDLE FOR A KENMORE 5567 SIDE BY SIDE FRIDGE,THANKS JERRY HUMPHREY
Posted on Dec 10, 2008
catriver
  • 878 Answers
SOURCE: Handle replacement for water dispenser
Melissa, you don't get it from the inside. Remove the drip tray by pulling it out. You should see two screws holding the dispenser cover on each side of the bottom. Remove these screws and push up on the dispenser cover, there's 3 hooks on the top. Unplug the harness from the dispenser board and get the cover out of the way. Now is the hard part. You have to get at the module itself that holds the paddle. These can be a fight. If you go to Sears.com, go to appliance then parts and post your model number you should get a breakdown of the dispenser that will guide you. Catriver..post back
Posted on Dec 10, 2006
SOURCE: the plastic handles that dispense the water are broken
Where can I buy the spigets for a Sunbeam water cooler. I need one for hot and one for cold water. These handles are not strong enough plastic to last the lifetime of the unit. They should be made from metal. If the taps on our kitchen sink was made from plastic you can imagine how long they would last.
Posted on May 29, 2009
  • 82 Answers
SOURCE: Replaced water actuator on frig and now it doesn't dispense water
pull it back open and double check you're wire connections
Posted on Jun 19, 2009
woodchuck789
  • 4070 Answers
SOURCE: Side by side Frigidaire. The water dispenser
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the tube.. You can take the water line off the valve and watch to see if it drips.
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad.
Posted on Aug 30, 2009
  • 40 Answers
SOURCE: no water at the dispenser
the water reservoir located in the refrig. compartment behind the drawers may be frozen,if nt the water inlet valve may be at fault.it is a dual valve system one side for the icemaker the other for the dispensor
Posted on Jan 22, 2010
Frigidaire Side-By-Side not dispensing water and possibly ice
It is possible the water line inside the refer is frozen, you will be able to see a resevoire or loop behind the bottom drawers that is where it could be frozen
Mar 24, 2014 | Frigidaire FRS6HR35K Side by Side...
I need a replacement handle for water dispenser on FFUS2613LS
Sorry but this site has no parts resources of any kind. I suggest you contact Sears Direct, they service just about anything.
Jan 19, 2012 | Frigidaire FRS23R4A Side by Side...
No water from water dispenser
the valve or the outlet had been jammed. its an rare case. for this, wash out all the water from the dispenser and afterthat open it and fix the blockage.............
Jun 20, 2009 | Frigidaire FRS6R5EMB Side by Side...
Water dispenser and ice maker not working
Hi!! tony , yes you have a bad water valve its located on the bottom back of your frig..Replace your water valve..Good luck..
Jan 03, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
Mar 03, 2008 | Frigidaire PLHS267ZA Side by Side...
Dec 09, 2006 | Frigidaire FRS23R4A Side by Side...
Refrigerators Logo
552 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
