Question about Apple iPod nano
Ipod corrupted when i connect my ipod to itunes, itunes says it is corrupted and to restore. i select restore and the same window pops up saying the same thing. Note: my pc see's the ipod as a removable drive, i've also tried resetting the ipod. help ?!??!
  • 8,596 Answers
Reset, Retry, Restart, Reinstall, Restore Remember these five basic suggestions if you have a problem with your iPod nano. If one of the following doesn’t help, read on for solutions to specific problems. â Reset your iPod nano. See “General Suggestions,” below. â Retry with a different USB port if you cannot see iPod nano in iTunes. â Restart your computer and make sure you have the latest software updates installed. â Reinstall iPod and iTunes software from the latest versions on the web. â Restore your iPod nano. See “Updating and Restoring iPod Software” on page 50.
Posted on Sep 19, 2008
My ipod is disabled and says connect to itunes but it also says itunes could not... so what do i do?
Step 1:
Apple's iPod Touch comes with a screen lock feature that allows you to set a four-digit security code to prevent others from using your iPod. Every time the iPod locks, you must enter this code to unlock the screen and access the user interface. Entering the wrong code too many times, or simply forgetting your security code, can cause you to be completely locked out. When this happens, you can quickly unlock your iPod Touch.
Connect your iPod Touch to the computer you usually sync it with. When you disconnect your iPod, it should now be unlocked. If Step 1 does not work, you have to restore your iPod Touch. Be advised that restoring your iPod Touch returns it to the original factory settings. This means that all your songs and files will be deleted and lost. You can resync your files to your iPod from iTunes once you have finished restoration. Connect your iPod to your computer and open iTunes. Make sure you have the latest version of iTunes before proceeding. In the left navigation panel in iTunes, select your iPod under the "Devices" section. Click the "Summary" tab and select "Restore." When iTunes prompts you about backing up your data, click "Back Up." In the following window, click "Restore." After the restore process completes, you will see the Apple logo on the screen of your iPod. Leave your iPod connected to your computer until it shows up again on the iTunes navigation panel. Your iPod touch is now unlocked. In iTunes you will be able to setup your iPod. Select the backup you made in the drop-down menu to restore your data files. Click "Continue" to finish the restoration. iTunes: Restoring iOS software
http://support.apple.com/kb/HT1414
Mar 01, 2013 | Apple iPod touch Original
Ipod touch 16gb will not restore. Every time i connect to itunes i get a message saying ''itunes has detected an ipod in recovery mode. You must restore this ipod before it can be used with itunes''. So i...
Sounds like it is trying to restore from a bad back up.
If I remeber correctly, you can select which back up to choose from, when the ipod is plugged into itunes and it pops up, right click on it and there should be a option to select which back up to pick from.
If not, google for the firmware (something like ipod touch <model) firmware. be a pretty big file, Under 200mb.
Once downloaded, plug your ipod in on your pc, then clcik restore while holding the 'shift' key, then select this fimrware file you downloaded.
It should be really easy as it is only one file, once done, youll have fresh new ipod. You will loose all your songs/ pics that are currently on there so be warned!
Feb 01, 2011 | Apple iPod touch
When i turn on the ipod it says to connect it to the computer and go to i tunes and restore
It is probably corrupted either itunes database or hdd clusters, so it's asking you to reset ipod to factory settings. Connect the device and click on it to select it in itunes.
you should get a screen like this. Select restore.
Mar 18, 2010 | Apple iPod MA446LL/A MP3 Player
The ipod will not turn on it says to connect it to the computer and go to itunes and restore
It is probably corrupted either itunes2_bing.gif database or hdd clusters, so it's asking you to reset ipod to factory settings. Connect the device and click on it to select it in itunes.
Corrupted iTouch
Update and restore error messages on iPhone and iPod touch Last Modified: April 21, 2009 Article: TS1275 Old Article: 307219 Symptoms When trying to update or restore your iPhone or iPod touch with iTunes, you may see an error message in iTunes that stops the update or restore process. You may also see the "Connect to iTunes" screen on your iPhone or iPod touch:
The error message in iTunes may also include one of the following numbers (but is not limited to): 2, 4, 5, 6, 9, 13, 19, -18, -48, -50, 1002, 1011, 1013, 1601, 1602, 1603, 1604, 1608, 1609, 1611, 1612, 2003, 2004, -9808
Products Affected iPhone, iTunes 7 for Mac, iTunes 7 for Windows, iPod touch, iPhone 3G, iTunes 8 for Windows, iTunes 8 for Mac, iPod touch (2nd generation) Resolution Many restore errors can be resolved using the troubleshooting steps found in this document.
Update to the latest version of iTunes
To see if you have the latest version of iTunes, open iTunes and:
Windows: Choose Help > Check for Updates Mac: Choose iTunes > Check for Updates
Restart your computer Simply restarting the computer can clear up certain issues that could prevent iPhone or iPod touch from being restored. After restarting, try restoring the device again in iTunes.
USB Troubleshooting Connect iPhone or iPod touch to a different USB port on your Mac or Windows PC. USB 2.0 ports that are built-in to the computer are preferred over a hub. If iPhone or iPod touch were connected to USB ports on the front of the computer, try connecting them to rear USB ports. After doing this, try to restore the device in iTunes.
If this fails, Restore on a different computer. If the issue is not resolved with the above steps, try to restore on a different computer. Ensure that the computer you are restoring on has USB 2.0 ports, the latest version of iTunes, and that you are connecting directly to the computer.
Advanced Steps
Make sure you have admin access
If your still having problems estore using a new user account Create a new user account on your computer and try to restore while logged in as the new user. iTunes will download a new version of the software restore file. After creating the new user, log in to that account and open iTunes and attempt to restore to see whether the issue persists in this new user.
Windows Vista and Windows XP
From the Start menu, choose Control Panel. Open User Accounts. Select Create a new account and follow the instructions to complete the account setup process. Once the new account is created, choose Log Off from the Start menu. Log in to the newly created user account.
When a restore issue is specific to a user, it is likely due to an unusable .ipsw file. The ".ipsw" files are what iTunes uses to restore your iPod or iPhone. If those files are unusable, then try deleting them so iTunes can download a new copy of them. Creating a new user will also cause new .ipsw restore files to be downloaded in the new user. You can find the ".ipsw" files in these locations:
Windows XP iPod touch: C:\Documents and Settings\[username]\Application Data\Apple Computer\iTunes\iPod Software Updates (If you don't see the Application Data folder, you may need to show hidden files by opening (My Computer) Click on Folder Options. in that window click on the view tab, and make sure that show hidden files is selected.
Windows Vista iPod touch: C:\Users\[username]\AppData\Roaming\Apple Computer\iTunes\iPod Software Updates (If you don't see the AppData folder, you may need to show hidden files)
1. Open Folder Options by clicking the Start button , clicking Control Panel, clicking Appearance and Personalization, and then clicking Folder Options. 2. Click the View tab. 3. Under Advanced settings, click Show hidden files and folders, and then click OK.
After removing and reinstalling the latest version of iTunes, try restoring iPhone or iPod touch again in the origonal user account.
As an added note, If running Microsoft Windows XP and the issue is resolved on another computer, but you continue to experience difficulties on your original computer, you may want to update or reinstall your Windows USB drivers and then try restoring iPhone or iPod touch again.
If none of these steps work you will need to contact either apple at
1-800-APL-CARE (1-800-275-2273)
Or another service provider of your choosing to get the ipod touch serviced or replaced.
I hope this article is very helpful for you and easy to follow. Good luck :)
Apr 26, 2009 | Apple iPod touch
120GB classic ipod is corrupt
You will want to attempt to force the iPod into disc mode then restore using iTunes. With the iPod in disc mode, iTunes should show the iPod. You will have to restore the iPod to resolve the issue of corruption though. Please let me know if this does not resolve your issue. :)
Putting ipod into disc mode http://support.apple.com/kb/HT1363 Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.) Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect" If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
How to restore iPod (ARTICLE NUMBER HT1339)
Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
After a few moments, your iPod will appear in the Source panel in iTunes.
Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software.
The 4 possible restore options are: Restore Option
1: Restore - Restores with same iPod Software version already on iPod. Restore Option
2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available. Restore Option
3: Use Newest Version - Restores with the latest iPod Software available. Restore Option
4: Restore and Update - Restores with the latest iPod Software available.
If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
A progress bar will appear on the computer screen indicating that the first stage of the restore process has started.
When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring.
Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models).
During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage.
Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Feb 17, 2009 | Apple iPod classic MP3 Player
Hellp please!!
Its most likely your firewall, turn your firewall off and try to restore again
Restore
  • Note: Because Restore erases all of the songs and files on iPod, make sure to back up any files you've saved on the iPod disk. All of your songs, videos, podcasts, audiobooks, and games can be loaded back to your iPod provided that you have them stored in your iTunes Library.
How to restore your iPod:
For Windows:
  • 1. Make sure you've reinstalled the latest version of iTunes.
  • 2. Open iTunes, and then connect your iPod to your computer.
  • 3. After a few moments, it will appear in the source list in iTunes.
  • 4. Select your iPod in the source list and you will see information about it appear in the Summary tab of the main iTunes windows.
  • 5. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download of the latest iPod Software. The 4 possible restore options are:
    • Restore Option 1: Restore - Restores with same iPod Software version already on iPod.
    • Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
    • Restore Option 3: Use Newest Version - Restores with the latest iPod Software on your computer.
    • Restore Option 4: Restore and Update - Restores with the latest iPod Software on your computer.
  • 6. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will instruct you to leave iPod connected to your computer to complete restore.
  • 7. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
  • 8. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
May 24, 2008 | Apple iPod nano 3rd Generation
Corrupted
To Restore follow these instructions :
I think you wont be able to do that.
For Windows:
3. After a few moments, it will appear in the source list in iTunes. If the iPod's display doesn't show "Connected" or "Do not disconnect" you may need to put the iPod into disk mode to proceed.
For Mac:
Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod, even though a newer version is available.
Restore Option 3: Use Newest Version - Restores with latest iPod Software version on your computer.
Restore Option 4: Restore and Update - Restores with latest iPod Software version on your computer.
6. A message will appear prompting you to enter an administrator's name and password.
7. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will instruct you to leave iPod connected to your computer to complete restore.
8. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage.
9. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Or
Try to reinstall
To update and reinstall your iPod software, first download the latest version of iTunes.
http://www.apple.com/itunes/download/
Next, open the new version of iTunes and connect your iPod to your computer.
Select your iPod in the source list and click "Check for Update" under the Summary tab. iTunes will check to see if your iPod needs to be updated and perform the update for you.
Good Luck.
Live, Love, Laugh.
Apr 25, 2008 | Apple iPod MA446LL/A MP3 Player
Apple Ipod Video 30gb wont update and restore and wont format using fat32
ok, well we need to perform the restore.
unplug the ipod. then plug it back in, make sure noting is useing your ipod, no windows into the ipod disk are open or any programs expt itunes is on. (close everything else you dont need expt itunes)
Then try to restore to a new version.
restore instructions
For Windows:
Apr 15, 2008 | Apple iPod MA446LL/A MP3 Player
Corrupt firmware ipod video 60 GB
How to restore iPod
  1. Ensure that you have an active Internet connection as new versions of iTunes and iPod Software may need to be downloaded to your computer.
  2. Download and install the latest version of iTunes if you do not already have it installed.
  3. Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
  4. After a few moments, your iPod will appear in the Source panel in iTunes.
  5. Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
  6. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software. The 4 possible restore options are:
    • Restore Option 3: Use Newest Version - Restores with the latest iPod Software available.
    • Restore Option 4: Restore and Update - Restores with the latest iPod Software available.
  7. If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
  8. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring.
    • Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
    • Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models).
  9. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
  10. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Jan 02, 2008 | Apple iPod MA446LL/A MP3 Player
Apple iPod nano Logo
200 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
