Question about Cell Phones
I HAVE PROBLEM IN THE SCREEN OF MY CELL PHONE.
Not playing videos and tunes sent by bluetooth
Posted on Oct 04, 2008
Screen blank on x836 turns on screen blacksout help thanks
Black Screen, Working Phone [Solved] - Phones - Cell Phone General ...
www.tomsguide.com/forum/id.../black-screen-working-phone.html
Dec 14, 2015 - 12 posts - ‎10 authors
I turn my phone off and then turn it back on, same result, black screen. I then tookout the battery and put it back in, same result. I took the battery ...
Why is my screen black but everything else works ... - iFixit
https://www.ifixit.com/.../Why+is+my+screen+black+but+everythin...
iFixitThe Samsung Galaxy S3 is a multi-touch, slate-format smartphone with ... I have a problem with my phone i dropped it and it works but all i see is a black screen ! ... was fine but then a couple of mins. later the screen started turning pink and when I .... i dropped my gs3, the screen cracked & the screen stays black, everythimg ...
Phone stuck on a black screen during or after a call? Here's ...
www.smartmobilephonesolutions.com/.../cell-phone-shows-a-black-scree...
Is your phone showing a black screen after finishing a conversation and not allowing ... causes and better yet some solutions to fix this issue on your cell phone. ... phone up to your ear, so that the phone will lock (turns on the black screen), ...
Jan 04, 2016 | Cell Phones
How to remove lcd screen on kyrocera hydro
  • Remove the battery cover from the back side of the cell phone. Remove the battery from its compartment and set it aside.
  • Use the screwdriver to remove the Phillips-head screws from the back panel of the cell phone. You may also need to remove the antenna from its retaining slot and remove it from the cell phone if you can
  • Separate the back panel of the cell phone from the rest of the cell phone's body. Place the cell phone face up and then remove the cell phone's faceplate from the rest of the cell phone. This should leave the LCD screen, keypad and circuit board completely exposed.
  • Tilt the LCD screen downward and then disconnect the LCD screen's ribbon cable from the LCD screen and set the screen aside.
  • Repeat this procedure in reverse to replace the LCD screen and reassemble the cell phone.
Mar 17, 2014 | Boost Mobile Kyocera Hydro Smartphone
I dropped my cell phone on a wood floor and the screen went black. I can put in my pass code but the cell phone will not show my screen. The cell phone works except the fact I can't cant see anything.
First, I would take the phone back to the store, and see if its covered by the manufactures warranty. If that doesn't work you will need to replace your screen, the cheapest way I know of is Ebay, but assembling is required. I hope this helps .
Mar 27, 2013 | Cell Phones
White screen only with trying to open it..but there is a sound when your pressing the keypads.
Hi,when a cell phone has a white screen display, it's occurs when the screen of the cell phone damaged..
Symptoms are that the cell phone screen will be white and you will able to recieve incoming calls, do some operations on your phone, but you will unable to view anything your doing on your cell phone.
You will need to replace the screen of the cell phone...
Also there are two models of 6600..
The 6600 slide and
the 6600 fold.
If it's the slide of the 6600 cell phone, that means you will need to replace the flex of the cell phone..
There is a common fault for all Nokia slide cell phones.There is a thread like object inside the phone called a flex that controls the functions on the keys on a cell phone when it's gets damaged, it makes the keys to malfunction. You will need to replace the thread like object which is the flex inside the phone for the keys to function again.
The flex of the phone is located inside the phone, it controls the functions of the screen an also the keypads of the phone.
The flex is a thread like object that is located inside the phone. To see the flex, you will need to disassemble the phone to get to the flex of the phone.
After replacing the phone flex, your done.
Also it might be the screen of the phone. But in other to know if it's the screen, you will need to test a new flex.
You can get a replacement flex from any of the phone repair stores around you.
You can use the below links for disassembling cell phone..
http://www.formymobile.co.uk/6600slidedisassembly.php
and
http://www.formymobile.co.uk/6600folddisassembly.php
Hope it helps.
Thanks for using fixya...
May 30, 2011 | Nokia 6600
It has lost display
Hi, display lost is classified in different areas:
When a phone has VIRUS in it, it might make the screen go white, through downloads from the internet or from another cell phone through data cable transfer or blue tooth.
Solution: Needs to be flashed.
Also when there is screen damage.it can make the screen go white. You will know if it is the screen when you switch on the cell phone and you can still operate the phone with out seeing anything.
Solution: you will need to replace the screen.
You can use the link below to replace the screen .
formymobile.co.uk/6700disassembly.php
And also when a phone drops on the phone, and the screen shifts from it's position,that can also cause white display on cell phone.
You can use the above link to use and check for screen shift...
Hope it helps.
Take care...
Mar 11, 2011 | Nokia 6700 Classic Cell Phone
My phone was working perfectly normal in till like 2:15 the screen went all white.
Hi,most phone slide phones have are, they all have the same problem which is the flex of the cell phone that makes the screen of the phone to go white..
The flex of the cell phone has a thread like object that makes the cell phone screen displays.When the flex of the phone gets damaged, it makes the screen go white.
You will need to replace the flex for the cell phone and the phone will be ok again.
The cell phone isvery ok, it's just the flexthat isdamaged that's all you need to replaced.
would advice you take it to an expert in phone repairs to help you out.
Hope that helped.
Feb 08, 2011 | Motorola Mobility Rival A455 Cell Phone
Have a white screen
Hi, white screen on motorola flip cell phones are usually from the flex of the phone.
The flex of the phone is a thread like object inside the cell phone that allows the screen of the phone to display.And when it gets damaged, it will make the phone go white..
All you will need to do is to replace the flex of the phone..When you replace the screen of the phone, the phone will work properly again..
I would advice that you take the phone to an expert in phone repairs to assist you in replacing the flex of the phone to prevent further damage to the cell phone..
Hope it helped.
And please don't forget to RATE me..
thanks for using fixya...
Feb 03, 2011 | Motorola Mobility Rival A455 Cell Phone
My htc cell phone touch screen does not work
my htc cell phone touch screen does not work all a sudden
Aug 03, 2010 | HTC Touch Cell Phone (Unlocked) - Soft...
I need the steps to replace the lcd screen.
Many cell phone users wrongly sell, or give away their cell phones when the LCD screen cracks, breaks or goes bad. Removing and replacing the LCD screen yourself is much cheaper than buying a new phone. Most cell phone parts or components can be purchased online at cell phone repair website such as CellularDr.com or Cellphonesshop.net. Replacing the LCD screen yourself, however, may void your warranty agreement.
Switch off phone,
Get a screw driver and unscrew the top where the screen is located,
(screw is located when flip is open).
Carefully remove screen from hook(when it is Pinned too),
Fix the replacement screen and screw back necessary screws on the phone.
And your Dawn.
Good luck.
Jul 15, 2010 | LG TRAX Cellular Phone
My cell w550i shows white screen no boot screen
Dec 08, 2008 | Sony Ericsson W550i Cellular Phone
Cell Phones Logo
91 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
