Question about Microsoft Xbox 360 Console
3 rings!! What do I do? - Microsoft Xbox 360 Console
    Scholar:
  • 45 Answers
When someone say that his/her Xbox is having 3 rings problem, It means it needs to be repaired. If you are using Cooler than it is not a cure but a prevention. You could have used cooler before acutally having the problem just to prevent your Xbox. But now you will have to either get it repaired from Microsoft (in case your Xbox's warranty is not expired, but one thing to note is that you will have to wait for at least 3-4 weeks to get back your Xbox) or you can Fix your Xbox's 3 Flashing red lights problem yourself with the help of DIY Video guide available on Internet. You can fix yourself without any technical knowledge.
Posted on Feb 21, 2009
What is the sizes on new & worn rings on Bajaj RE205 Piston
the size of the ring will be determined by the bore size
so if it is a 3"(75mm) bore the ring will be that size if placed in the bore separate to the piston and pushed square and to the bottom of the bore the ring gap will denote if standard , worn or oversize to standard
new rings in new bores will have a ring gap of around .010"
worn rings will have a larger gap up to .040" and will have sharp edges where the ring lands wear the rings
over size rings in standard bore probably won't even fit in the bore to start with
ring sets are bought in standard size , .010" over size,.020" oversize,.030" oversize,.040" oversize with the oversize equalling the final hone of a machine bore
so if the machine shop bores the cylinder out to .020" oversize then you need .020" oversize rings to maintain the correct ring gap
from experience I have found that if I follow that rule , on measuring the ring gap at the bottom of the bore the ring gap is about .015" or half worn out
I counter this by getting the next size ring .030" and filing the ends of the rings at the gap to obtain the .010" gap This has produced better longer lasting repairs
Jul 27, 2015 | Bajaj Motorcycles
Jacuzzi tara o ring
What is the o-ring used for? Where is this o-ring located and what is the function of the o-ring?
US Parts Center
Mar 09, 2014 | Jacuzzi Tara, Whirlpool Bath -...
I need instructions to put Wilton's 3 tier party stand together
According to Wilton:
You should have 8" plate, 10" plate and 12" plate
Match the sizes with rings and legs on table.
Attach legs to serving rings,twist threaded end securely into housing on each serving ring. Tighten using wrench.
Attach 8 1/4 Serving ring to Center Footed Base Ring -Position serving ring with footed leg out. Line up the other 2 legs with the correct housing on the base ring, the width between housing should be same as that between legs.. Insert end of legs into housing.
Next attach 10 1/4 Serving ring to Base Ring, You will need to move clockwise around base ring to attach this ring. line up legs and insert legs and tighten.
Attach 12 1/4 serving ring to base ring. Insert legs into last pair of housing on the base ring.
Position plates so lip edge rests inside serving ring.
Apr 16, 2013 | Wilton WHITE 3-TIER CUPCAKE STAND...
What is the number one piston
number one is number one.
Mar 14, 2013 | Cars & Trucks
How do I undo the delayed ring on a toshiba dk2010sd phone?
just check your ring tone settings check whether u have selected vibrate then ring settings..if so change it to ring..try this....
Nov 22, 2011 | Lands Phones
BLOW BY 89 TOPAZ COMRESSION WITHIN SPECS PCV VALVE IOK
Hello, You can still have Ring issues with good compression. The pistons have different types of rings on them to do different jobs. The top rings are your power rings, the bottom rings are your oil rings.
The oil rings prevent the block pressure and oil slop from being drawn up into the cylinder. The piston creates a siphon action and the oil rings prevent the oil from climbing the cylinder walls. All it takes is for the rings to rotate around the piston and have the ring ends line up.
That is why you offset the rings on installation from 90 to 120 degrees. It staggers the gaps of the rings for a better seal. Now you can get oil vapor if the compression rings line up to allow compression into the crankcase through the gaps on the piston rings.
Sometimes the valve stem seals can leak and allow exhaust into the upper block if you have valves that are not seating correctly.
Jul 16, 2011 | Mercury Topaz Cars & Trucks
Hello im having a problem repairing my pistons and rings on my motor bike. can you plz tell me if the piston rings are supose to spin all the way around or are they both ment to lock in the groves for them
howdy.if your bike is a two stroke the ring has a pin in the piston groove to stop the ring turning.on four strokes the ring gap should be off set to each other and generally placed between 20-25 past and 25-20 to [like a clock] but no where near the side of piston at little end pin.also use a little oil in grooves to lubricate while fitting rings.some rings have angled edges so check wether they go top or bottom directions in manual or packaging with new ring sets.most rings will be marked to guide you.have fun and good luck.cheers
Mar 21, 2011 | Yamaha DT 125 RE Motorcycles
94 caprice classic rear spider gears shot 12 or 16 possi what other rear ends are compatible for this 5.7 liter
. Axle Code >>>>>>>>>>>Standard
2YN Gear Ratio >>>>2.56<<<<< Ring Gear Diameter 8.5 Standard 2GA Gear Ratio 2.73 Ring Gear Diameter 7.6 Standard 2GB Gear Ratio 2.73 Ring Gear Diameter 7.6 Standard 2GH Gear Ratio 2.73 Ring Gear Diameter 8.5 Standard 2LW Gear Ratio 3.08 Ring Gear Diameter 8.5 Standard 2LR Gear Ratio 3.23 Ring Gear Diameter 8.5 Standard 2LY Gear Ratio 3.23 Ring Gear Diameter 8.5 Standard 2LT Gear Ratio 3.23 Ring Gear Diameter 8.5 Standard 6YF Gear Ratio 3.23 Ring Gear Diameter 8.5
Axle Code>>>>>>>>> Limited Slip
2LQ Gear Ratio >>>>>>>>2.93<<<<<<<<<<< Ring Gear Diameter 8.5 Limited Slip 2YG Gear Ratio 2.93 Ring Gear Diameter 8.5 Limited Slip 2LX Gear Ratio 3.08 Ring Gear Diameter 8.5 Limited Slip 2ND Gear Ratio 3.23 Ring Gear Diameter 8.5 Limited Slip 2LZ Gear Ratio 3.23 Ring Gear Diameter 8.5 Limited Slip 2LS Gear Ratio 3.23 Ring Gear Diameter 8.5
Nov 28, 2010 | 1994 Chevrolet Caprice Classic
How to set fax machine so it can accept after 2 rings?
Distinctive Ring basicsDistinctive Ring service is an optional service available from many telephone companies. The Distinctive Ring service permits you to assign more than one telephone number to the same telephone line. Distinctive Ring allows you to use a single phone line for both voice and fax calls. You can assign a unique phone number and ring pattern for incoming fax calls. When a fax comes in, each telephone number makes a distinctive ringing sound, such as a single ring, double ring, or triple ring.
NOTE: The Distinctive Ring Service is the name HP and others use to describe this feature. Distinctive Ring is also known as:
  • Call Sign
  • Custom Ring
  • Ident-a-Call
  • Ident-a-Ring
  • Ident-a-Ring
  • Multi Ring
  • Personalized Ringing
  • Ringmaster
  • Smart Ring
  • Teen-Ring
The Distinctive Ring Service allows the HP product to work similarly to a dedicated fax line. If you connect an HP fax product and a telephone to one telephone line, you can assign one telephone number for fax calls and another for voice calls.
NOTE: You cannot send or receive faxes when the phone line is in use. Even if the HP fax product has a separate telephone number, it is still sharing the same phone line. Set the Distinctive Ring Service Using the menus on the product control panel, follow these steps to set a distinctive ring pattern. Step one: Turn on Auto Answer Turn on Auto Answer by pressing the Auto Answer button on the control panel. The button light indicates when Auto Answer is on.If the button light is already on, you do not need to press the button. Step two: Set the distinctive ring patternFollow these steps to change the answer ring pattern.
  1. Press the Setup button (c01461502.gif ) on the product control panel.
  2. Press the Right Arrow button (c01185072.jpg ) to select Advanced Fax Setup , and then press the OK button.
  3. Press the Right Arrow button (c01185072.jpg ) to select Distinctive Ring , and then press the OK button.
  4. Press the Right Arrow button (c01185072.jpg ) to select one of the following options:
    • All Rings
    • Single Rings
    • Double Rings
    • Triple Rings
    • Double & Triple Rings
  5. Press the OK button to select the option.
  6. Press the Back button (c01490920.gif ) to return to the main menu.
Now if you have anymore problems copy the link from below and paste it in your address bar and it will help you further with a document. Follow all the settings in the document and your fax should be setup,keep in MIND THAT THE RINGS TO ANSWER SHOULD BE 2,SO YOU CAN RECEIVE FAXES AFTER TWO RINGS
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01647469&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=3795406
Feb 01, 2010 | HP Officejet 6500 Wireless All-in-One...
Need to change ring on fax to 3 rings. it is an hp office-jet 6110 all in one
  1. Press Menu .
  2. Press the right arrow (>) or the left arrow (<) until Advanced Fax Setup displays.
  3. Press Enter .
  4. Press the right arrow (>) or the left arrow (<) until Answer Ring Pattern displays.
  5. Press Enter
  6. Press the right arrow (>) or the left arrow (<) until the desired ring pattern displays.
    • Single rings – The fax machine answers after a single ring.
    • Double rings – The fax machine answers after a double ring.
    • Triple rings – The fax machine answers after a triple ring.
    • Double and triple – The fax machine answers after a double and triple ring.
    • All rings – The fax machine answers any ring. This is the default when not using Distinctive Ring.
  7. Press Enter .
May 09, 2008 | Office Equipment & Supplies
Microsoft Xbox 360 Console Logo
27 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
