50 in philips plasma tv
I have plasma not turning on, it makes a fairly loud noise when the power is turned on, i think i am capable of fixing this with some help from an expert, hopfully it is a board. the model number is50pf7220a
  • 5 more comments
  • bigbird1966 Sep 11, 2008
    when i turn it on it starts with a low hum , the goes to a higher frequency noise , like when the cabel company runs one of their test on the tv
  • bigbird1966 Sep 12, 2008
    sounds like a bad board,but not sure,not sure what a screen does when it goes bad any ideas
  • bigbird1966 Sep 13, 2008
    took board out and cleaned and made sure gnd was ok, still not working
    tried to make sure gnd was ok , still not working
    hi tim, i unhooked the ribbons, still hummed,so i unhooked the power wires on the left board,still hummed,unhooked power to the right the humming went down alot, but still a little,i think the sound is coming from the power supply, does that sound right, look forward to hear from u
    i unhooked the x and y still makes a low humming noise , nothing near what it was, anything else i should check
    just a quick question, do you know what the voltages should on the board and i heard somthing about a convayance or convergeant board what do they do thanks
  • 2,071 Answers
Resetting the TV
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
Posted on Sep 13, 2008
    Novelist:
    Champion:
  • 203 Answers
Can you determine where the noise is coming from?
In the back of the plasma when it is laying down and you are sitting at the bottom of it there are 2 boards all the way on the left, one goes from the top half-way down and the other goes from half-way down to the bottom, these are the scan drivers and are hooked to the panel through ribbon cables. the board that they plug into is the Y-sus. On the right side of the tv you have the X-sus board and it should be attached to the panel through some ribbon cables. The first test you need to do is unplug both of the scan drivers from the y-sus one at a time.BE CAREFUL NOT TO DAMAGE THE RIBBON CABLES GOING TO THE PANEL. Unhook one and then turn the tv on and see if the noise goes away. if it does then that board is bad. if the noise is still there then unplug the other one. if the noise goes away then that board it bad, if the noise is still there then hook them both back up. Next find the big wire that goes from the y-sus to the power supply and unplug it, try to turn the tv on and see if the noise is still there. If the noise is still there plug that wire back in and unplug the big wire going to the x-sus, if the noise goes away now that board should be bad. If you do all this and the noise is still there, let me know and I will take you further.
Tim Nolan
  • 1 more comment
  • experttv
    experttv Sep 13, 2008
    Sounds like a bad power board to me. unhook the wires going to the x and the y and see if it still makes the noise? let me know.
  • experttv
    If it is still a noise that is not common to the tv with the x and y unhooked then I would say you have a bad power supply.
  • experttv
    Plasma tv's dont have a convergence board. Only crt projection have convergence.
    Genius:
  • 1,239 Answers
HI   IF IT IS NOT IN THE WARRENTY PERIOD . TRY TO DISSAMBLE IT.. AND REMOVE THE A& V BOARD.. PIN FIRSTLY REMOVE THE POWER CARD.. TRY TO CLEAN THE BOARD.. AND INSERT IT. IT IS APROBLEM DUE TO GROUNDING IN THE BOARD.. SO THAT IT GET NEGITIVE PASSES .. I HUMMES THE SOUND.. CLEAN AND INSERT.. IT WILL SOLVEIT.. IF ANY ASSIST I AM THERE TO SOLVE.. RATE IT,,   THANK U..
Posted on Sep 12, 2008
    Master:
  • 726 Answers
What kind of noise is it ,ok if the power is in and its not turning on it could be a fuse inside blown or even the conveyance board
Posted on Sep 11, 2008
50" Philips Plasma 50pfp5332D/37 won't turn on
I have a 42in vizio led with about the same problem i replaced a 75 cent chip # u33 on computer board problem fixed.
Sep 25, 2012 | Philips 50PFP5332 50" 1366 x 768 Plasma...
I have a hp5060n 50in plasma tv,the left speaker makes a loud noise.can i use the inside speaker from a 4260n plasma tv with it?
Good morning there from here
According to my information if the noise comes on and off in connetion with tv turned on and off, the noise is due to a change in ambient humitity or temerature. Then there is nothing wrong with the TV,just wait till the weather changes.
I wouldalsocheck the AUDIO settings on the TV .
hope all goes well
kolbrun.
Mar 04, 2012 | HP PL5060N 50 in. Plasma HDTV
My kids were watching our 50 in plasma tv when there was a loud popping noise and the image went out but there is still sound, I turned the cable and tv set off to see if it would help but it didn't work...
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
Mar 27, 2011 | Vizio P50HDTV20A 50 in. Plasma HDTV
Phillips plasma blinks 6 times
Feb 20, 2011 | Philips 50PF9631D 50 in. HD-Ready Plasma...
My Philips flat screen tv model 50pfp5332d/37 I turned my tv on the blue light is on but nothing is on the screen it's making a clicking sound
It could be a power supply problem. In this model at least 2 capacitors, go bad in the power supply I think they're 1000uf/10V. If you look at the power supply board you will notice a bad cap with a blister on the top. The whole power board is from $100 - $200. I fixed a lot of these sometime the Y or sustain board goes bad. Visual inspection then measuring voltages..
Best of luck
Nour Sabre
Nov 03, 2010 | Philips 50PFP5332D 50 in. Plasma...
50PFP5332D Plasma tv. My tv sounds like its trying to turn on but the blue light flashes and a clicking noise keeps repeating and no picture.
I have the same problem with my TV. I haven't verified this yet, but someone I know who's a electronics genius told me that its the buttons on the TV (power, channel, volume, etc.) He said at the factory many of the "button boards" were tightened too much and cracked. When you turn the TV on, the clicking noise is a loose connection. He said it's easy to replace yourself, and about 30 bucks on ebay. No promises though.
May 20, 2010 | Philips 50PFP5332D 50 in. Plasma...
Tv wont turn on
loud noise ? ! just indicate that the main power supply capacitors are bad, or sometimes is just the ceramic filters.
undo the back and check for any blow capacitor or burned components.
the new power board cost 139.99 on ebay
http://cgi.ebay.com/Power-Supply-LJ44-00117A-PS-425-PH-Philips-42PF9631D-37-/260597950481?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item3cacd92811#ht_500wt_928
if you dont want to fix your TV, let me know cuz i will buy for parts, write me to
fosg2000@gmail.com
May 18, 2010 | Philips 42PF9631D 42 in. Plasma Television
The power button is flashing red...
It ur power board,Tries buy it replaced it ur self it pretty easy.
Nov 18, 2009 | Philips 50PFP5332D 50 in. Plasma...
2003 philips 50" plasma tv with picture fading. How do I fix this?
Hi,my philips plasma 50FD9934 dont turn on just led flasing red and green contniusly.Please help!!!!This is a power suply problem?thanks
Nov 14, 2009 | Philips 50FD9934 50 in. Plasma Television
LG plasma tv made loud popping noise
The plasma gas tubes may be damaged or the gas couldve leak out. remember plasma have to remain upright at all times even when transporting them, if they are not you should just set it up straight for about 3-4 hours before turning it on.
Apr 23, 2009 | LG 50PX5D 50 in. Plasma HDTV
Televison & Video Logo
89 people viewed this question
Top Televison & Video Experts
Electro Med Services...
