Question about Hampton Bay HBLG5004 Air Conditioner
Water has accumulated in my air conditioner...
I have an HBLG5004 for a few years with no probs...until last night. It was making a sloshing noise (it does that sometimes when there is a bit of water accumulation). Well this time the fan was making a deep 'whirring' noise and was spitting little droplets of water out of the vent up top.
Should I just let this ****** dry out and start from there? Or is this a larger problem?
  • Hollywood_Da Sep 11, 2008
    Thanks! I definitely will try this out.
  • 58 Answers
You need to check to see if the unit is off-level, as it should be. From the outside, the unit should appear to be slightly tilted to allow for water run off. Also, check to make sure the water drain hole or holes are not clogged with debris. Remember, an air conditioner is also a good dehumidifer and the water that it removes from the air it is cooling must go somewhere.
Posted on Sep 11, 2008
I have a 2001 WJ Jeep Grand Cherokee Laredo. At times when cornering, there is the sound of water, or other liquid sloshing around in the dash in front of the passenger seat. Could this be accumulated ...
ac units are very well sealed and any water or liquid should normally be drained out of a tube located outside of firewall make sure that drain is cleared,heater core can also make this noise especially when engine coolant is low.
Aug 28, 2013 | 2001 Jeep Grand Cherokee
My new Fedders window air conditioner makes clicking noise all night long. HELP!
Has it done it since day one? Does it sound like the kind of noise you might get by flicking drops of water into a fan? If so that noise is normal for many newer air conditioners. Sorry.
Aug 09, 2012 | Heating & Cooling
My unit is making a loud noise and is spitting water out with the cool air
i have had units turned too cold and ice forms on coils. shut unit down and take it out of window. turn /tilt and when all water runs out, re install and turn back on to a Higher , less cold setting.
Jul 29, 2012 | Hampton Bay HBLG5004 Air Conditioner
Water is not draining out the back of the window unit and water is blowing out the front and fan is making a noise
Kathy, there are 2 reasons this happens.
1. the unit is not tilted down at least 1/4" on the outside of the window.
2. The drain hole in the condensation pan (under the unit) is clogged.
Resolving the above (either one or both) should solve the problem.
In the meantime turn the AC unit OFF.
Hope this helped you.
Jun 23, 2011 | Hampton Bay HBLG5004 Air Conditioner
Hello, I have a 5300 BTU, 4.8 amp window air conditioner from Daewoo. I just hooked it up and after 15 minutes it has water sloshing around inside it making loud sounds. I tried level, the 1/4 inch fall...
Hello, that sound Is normal usually when humidity is high. The evaporator coil sweats when the humidty is very high and the fan spashes the condensate on the condenser to evaporate it. Now if the unit has a knockout hole you can use it but you must use a hose attached to it so it drains properly. But the sloshing sound is normal during high humidity.
May 31, 2011 | Daewoo Heating & Cooling
It's two years old, and is now spitting out lots of water.
Should have a drain on the unit. Check for ports that have debris in them on the outside of the unit. Clean the debris out and the unit should drain normally.
May 30, 2010 | Haier ESA306 Air Conditioner
RUNS BUT DOES NOT COOL TOO WELL.
if the compressor runs for a short time only it could be overheating due to a lack of refrigerant i would suggest finding a contractor who specializes in hampton bay to take a look at it
Jul 29, 2009 | Hampton Bay HBLG5004 Air Conditioner
Got a leak in the front of my air conditioner
There is no valve. The water condensate from the cooling coil flows toward the back of the A/C where it is evaporated or drained. Tilt the A/C a little toward the back and see if that helps speed up the drainage.
Jun 08, 2008 | Hampton Bay HBLG5004 Air Conditioner
Heating & Cooling Logo
535 people viewed this question
Top Hampton Bay Heating & Cooling Experts
Tim Whalen
Pete Norton
Are you a Hampton Bay Heating and Cooling Expert? Answer questions, earn points and help others
