Question about RCA Televison & Video
TV turns off immediately after powering up
My tv turns itself off after I turn it on. I have checked power cord, unplugged it for 1 hour. The picture never appears, just the blue screen then it's gone.
  • 41 Answers
The problem is inside... maybe there is a loose solder connection on the board, or a deffective parts at powersupply...either the capacitor...or other possibility is there is a house lizard died inside...
Posted on Sep 11, 2008
TV turns off and immediately on again, by itself.
sounds like a defective str power regulator ic .......but my advice get a tech to resolder all the pins at the power suppy board area, there may be some open pins that triggers the on and off episodes
Jul 18, 2013 | Televison & Video
I have a Epson emp7900 and it comes on and works great "Picture and sound" for about five minutes then it turns itself off?
Tries tv unplug,replug it back like about an hour later for the tv resetting itself back to the factory setting.The tv now should be working again.If the tv still have the same problems,mean the tv power supply board it is the causes and the problems.That the board where the tv power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish the tv power supply board for the replacement.
Sep 21, 2011 | Televison & Video
Turned the tv off few hours ago and came back and now it wont turn on - checked all connections - still no power - can not turn on from remote or on side of tv.
Check the power outlet source?Yes,tries tv unplug,replug tv back like about an hour later,by letting the tv resetting itself back to the factory setting.The tv now should be working again.Not than the tv have power supply board problems and causes.That the board,where the power a/c cord plug into it.Try website like Ebay.com to buy a refurbish power supply board for the replacement.
Feb 05, 2011 | Vizio P50HDTV20A 50 in. Plasma HDTV
No picture on my philips 42PF7321D/37
Bad caps in the power supply must be replaced .
Jul 21, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Tv Turn sound on, No Picture, turns itself off within seconds
The TV is trying to go on protect mode because an internal fault had been detected. For that reson the protection circuit keeps turning off TV continuously.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
May 23, 2009 | Sony KLV-30HR3 30 in. LCD Television
Power turn off after 45 minutes to 1 hour used
Check the "Sleep Timer" settings. If set to 45 minutes then TV would automatically turn itself off 45 minutes from being turned on. The variance in the "on" times is due to the TV turning itself off after not getting a signal from the remote for fifteen minutes.
Good luck,
Techjoel
May 09, 2009 | Sony KDS-60A2000 60" HDTV
I loose my picture but i still get sound
Just try to reset so picture will come again, some LCD TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the LCD TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the LCD TV power button for five seconds.
4. Plug the LCD TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the LCD TV is responding again.
6. Turn off the LCD TV and reconnect the devices.
7. Turn on the LCD TV.
Hope it may help you;
Regards;
VOTIT
Apr 22, 2009 | LG 42LC2D 42 in. LCD HDTV
Phillips 51in tv rear projection power button blinking green
The TV is on protect mode.
If you want to repair at your own expenses, just locate any good qualified repairer.
Nov 14, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Televison & Video Logo
57 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
