Question about DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder
One fuzzy Tv one works fine
Ok i recently turn my garage into another room the satalite cables ran thru it so i pulled them out cut 2 ends the main one one to tv 2 ....i got the twist on ends put them on the main one and to the cable to tv 2 i screwed the main one into the splitter so tv 1 works fine but tv 2 does i re did it over and over i even tried a new cable from the spillter to tv 2 ...i also bought a new dish aproved spillter and still no luck the picture comes in its just fuzzy please help me !!!!!lol
  • 374 Answers
Okay, we work with what we have available to us but the screw on connectors are...... Try reversing the splitter so the single port faces away from the line that runs into the back of tv2 and connects to the the line from outside. Also check to ensure none of the wire braid has come into contact with the center conductor- copper wire, stinger. I do not know how you prepared the cable so I will say that the white dielictric should be cut squarely and terminate flush with bottom of the connector seat. The diagram is a cut away view and is very crude but I think you can garner the idea. If you need more assistance let me know.
Posted on Sep 23, 2008
I'm running two sets of speakers thru a gfs3 powered by a gfa 5300. the main speakers are on 1, the second room pair on 2. the speakers on 2 will only play when the main speakers are engaged. i recently...
Do you mean Adcom? That detail matters.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Adcom-GFA-5300-Car-Amplifiers-manual/id/582ci558/t/2/
That would mean you're trying to run two rooms with paired mono speakers and a different channel in each room. MMmm, okay.
It's a 2-channel power amp and it isn't really designed for the probable very low imedance you're providing with paired speakers on each terminal. And it has no ability to turn either channel on or off short of denying it a program input on either channel.
Perhaps if you ran one speaker from each channel into each room (impedance permitting), you would have two rooms with traditional 2-channel audio.
Mar 22, 2011 | Audio Players & Recorders
Cable picture is fuzzy
Call your cable company as there might be a problem with the drop line or aerial coming into your house. now another thing is if you have a signal splitter( ex: 2-way, 3-way, 4-way) before the cable box, that could be degrading the signal as each input may drop the signal significantly. remeber, don't use too many splitters as they will make the signal faded/fuzzy. also, make sure all the connectors are clean and are not badly bent or the ends frayed. If you can see wire insulation from the cable line then it's no good.
Apr 05, 2010 | Insignia 42" LCD Flat-Panel HDTV
Mitsubishi VCR model HS-U430. Cable channels 2-6 fuzzy.
Looks that way,the signal is not getting through the vcr,time for an upgrade
Sep 15, 2009 | Mitsubishi HS-U430 VHS VCR
We recently purchase 2 TB1 10MW9 DTV Digital Analog Converters to connect to 2 of our Ananlog TV's. Our TV reception is from Comcast Cable & we had then set-up our Main TV with their converter. Our...
U have paid cable, u don't need the converter box.Not even the analog tv require the coverter box, if u have paid cable or satalite tv or telicom signal.All ur tvs is hook up to the Comcast Cable correct?That all u need not, require the converter box.
Sep 03, 2009 | Televison & Video
No picture 2 days ago power went out thru out the neighborhood, once power came back TV worked great. today, go to power on TV, here it clicking, but no picture... cable box working, cable working in 2nd...
It sounds like there`s a sort on the secondaries of the power supply. Before the power went off, did you ever turn the tv off by unplugging it?? In other words, did you turn the power off completely to the set or leaving it in standby?? if you always left it in stby, it will be the capacitors in the power supply, they dry out if the power is always on, so they will need replacing. If you did turn off the power, then I think you`ll find that the power cut had nothing to do with the fault you`ve got now, it will be the Line Output Stage which has failed or gone short circuit. Ian
Aug 05, 2009 | Sony Televison & Video
My Vizio 32" Flat Screen suddenly turned blue and "no Signal"
Check the cable connector. If it is OK then the turner has gone bad. Replace main board will fix it.
Feb 06, 2009 | Vizio L32 32 in. LCD HDTV
Luke warm heat
YES, THEIR IS A HOT WATER CONTROL VALVE, ITCAN BE OPERATED BY VACUMN, OR CABLE, VAC, TYPE WILL HAVE AVACUMN HOSE TO IT, PLS CHECK IT FOR CONDITION, CRACKS, SWELLING, IF OK, THEN WITH ENGINE RUNNING, HEATER CONTROL IN HOT POS. PULL HOSE OFF VALVE, PUT FINGER OVER END, FEEL FOR VACUME. IF THERE IS, MOST COMONLEY RESULT IS THAT VALVE NEED TO BE REPLACED.
Oct 01, 2008 | 1999 Jeep Cherokee
Tv is fuzzy
TRY USING BOTH INPUT EG: TRY TUNER THEN TRY A/V INPUTS AND COMPARE THE SIGNAL IF BOTH ARE BAD YOU HAVE A VIDEO SWITCHING PROBLEM.
Jun 30, 2008 | Toshiba 32AF42 32" TV
HOW TO DISARM THE CARRIAGE
a vcr carriage has at least one or maybe two little plugs going to it from the main circuit board, unplug whatever lines that are going to it. don't cut any wires.
Apr 27, 2008 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
Static on cable tv/vcr comb
ok,normally the cable connection that in deployed in the home is only good for 2 tv.and if you add for one,it will become fuzzy. I could suggest that connect other one cable line
Nov 07, 2007 | Quasar VV-2002 20 in. TV/VCR Combo
DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder Logo
177 people viewed this question
Top DISH Network Televison & Video Experts
brian soufane
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
