-   I've changed my batteries, I turned the button to auto, the green light is on for a second, then the red light then nothing... I've changed batteries many times but it won't start. I've had that camera for only 2 years.
Kodak C530-   sophiecoucou
Jun 22, 2008
-   Same problem, tried several new batteries in my Samsund Digimax 530. Nothing. Any suggestions?
Ken Perkins foroldtimes@juno.com
-   foroldtimes
Apr 19, 2008
-   Kodak EasyShare Z710 will not power on. I have tried two new sets of batteries including Kodak digital camera batteries. Is there any fix for this?-   LLoop
Apr 19, 2008
-   same problem just stop working recharged batteries, purchased new batteries, nothing just died - this really stinks-   camera e327
Apr 18, 2008
-   new batteries, no power. simply stopped. tried 3x new sets off the shelf batteries. do not have ac adaptor. contacts ok and door shut peoperly. is there some type of reset or???? help! thanks-   999nineninen
I have one with the same problem. My friend complained it had just stopped but a few week earlier the pop up flash wouldn't close. On stripping it down I found the mechanism (3 metal parts) all over the main board. What they had shorted out is anyone's guess but after checking to see if the parts were replaceable I saw the flimsy plastic mount for these parts and it looked as it it was designed to break.
BMW
Was this helpful?
Yes
No
Solution #2
posted on May 06, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I found a screw shorting the filter capacitor that was from the lens mount. However it had already caused damage.
Ive seen this proble before. Im afraid its dead. There is a problem that fuji will not address. The camera is all plastic and the front has a lens adapter made from aluminum. There are 3 screws that hold it on and they have no locktight on them. Eventualy they work loose and fall out, the front becomes loose like its broken but its not. The screw then bounces around inside the unit till it eventualy shorts and blows somthing out. Since there is no shematics for it its nosy to.
Ive called Fuji and told them ive seen this problem many times and they wont admit there is a fault.
Comments:
Apr 13, 2006
- One other thing you can check but i dont think it will help, is the memory door. Push on it as hard as you can when you try and power it up. If thats the problem its an easy fix if thats not it then its junk.
listen you all...if the battery contacts are ok and the battries fully charged then it is a dead power board. make the investment and send it to a repair place unless it is an old junk and not worth repairing
Won't operate on fully charged (1.2V terminal voltage under load) Energiser NiMH batteries. Works...
(More)
Won't operate on fully charged (1.2V terminal voltage under load) Energiser NiMH batteries. Works fine on Alkaline
my digital images for taking pics of jewels to sell on ebay do not show the true color of the...
(More)
my digital images for taking pics of jewels to sell on ebay do not show the true color of the stones. Tried reading the book but a little confusint
