Broken Washing Machine Agitator
I'm having a problem with my washing machine agitator. It's a "2 parter", with a bottom agitator that works fine, but the corkscrew shaft and top just hangs loose. It turns freely by hand, and acts like it's become disconnected from the base agitator or something.
It also has an automatic fabric softener dispenser in the top that somehow still recognizes the right cycle to release the fabric softener. After researching your site, I'm thinking I have a broken bolt where the upper and lower agitators should be connected; however, I can't see any way of getting the agitator top off to check it out. Otherwise, the machine works fine for an oldie but goodie.
Forgive me if I sound ditzy, but the husband won't touch it and I've never attempted anything quite like this before. Thanks for any help you can give me on this.
Benni.
  • 1 more comment
  • Benni Buxton
    Benni Buxton Sep 12, 2008
    Smack dead on target! Sorry the make and model wasn't added to the post; I was asked for the info after writing the post and added the info there. But as luck would have it, you already had it figured out.
    Following your instructions, I was able to remove the agitator and found that you were exactly right about the dogs. You even had the replacement part number correct!
    You are a much-appreciated lifesaver, as this machine gets little rest. Thanks so much for your help, and I'll be sure to pass the site along to others who are having problems. Have a wonderful day!
    Benni.
  • ted hall Nov 29, 2008
    I have the exact same situation it is a Whirlpool Ultimate Care heavy dutysuper capcity plus. We plan on moving in a few months so would like to repair it if possible.
  • davenport_jo Jan 12, 2009
    i have a whirlpool heavy duty top loader I dont know how to get the agitator off to fix the problem but I believe the solution above will fix it if you can tell me how to get it off .
    thanks,
    can you believe i am married to a maintenance man
    Genius:
  • 1,028 Answers
Probably just what is known as agitator dogs just worn ..with no brand or model i assume it's a whirpool or kenmore ..1st remove softner dispenser (without brand can't say how it would come off ..some twist off some just pull off ) if agitator has cap underneath pull it off in center of agitator should be a bolt 7/16 if kenmore/whirlpool..remove it pull up on top half ..whole thing may come out if so just pull up sharply on top part..center part of top half comes out dogs are on it( 4 )again i'm assuming kenmore/whirlpool whirpool part # 80040 replace them and reassemble ..if any other brand will probably have to replace entire agitator..good luck
Posted on Sep 11, 2008
The bolt head connecting the agitator is broken off. How do I get the bolt out so I can replace the dogs
Posted on Aug 06, 2011
I have a Kenmore washing machine, model no 110-92586400. The
agitator dogs are worn, they are flush to the center column. How do I remove and replace them?
Posted on Jan 30, 2009
Whcandy washing machine grand go f 662 stops mid cycle and the cold wash light flashes and the softener isnt usedat's your problem?
Hello.
Washing machines, like any other mechanical device, occasionally needs servicing. A common problem with an older washing machine is that the spinner, or agitator, drain,or stops rotating during wash cycles. Fortunately, most washing machine problems are easy to troubleshoot. Any do-it-your self offer can fix it; here's how.
TOOLS NEEDED TO SOLVE PROBLEM ARE BELOW.
Bucket and rags,Screwdriver,
New drive belt (if necessary),
New drive motor (if necessary).
1 Unplug the washing machine, and turn off the water supply to the machine. If necessary, remove the water hoses from the back of the washing machine because they may be in the way of the access panel.
2 Check that the agitator is seated correctly by opening the lid of the washing machine. If it's loose, pop off the top of the agitator--if there is one--and tighten the bolt that holds the agitator in place. Or, in some models, simply pull straight up and then reseat the agitator.
3 Remove the access panel located in the back of the washing machine by unscrewing the screws holding it in place. This allows access to the drive motor.
4 Press on the drive belt that works the agitator. If the belt moves more than 3/4 inch, tighten the belt to fix the spinner problem. If the belt is worn or cracked, replace the belt.
5 Replace the drive motor, if tightening or replacing the drive belt doesn't fix the agitator. Purchase a new drive motor at a wholesale retailer. Disconnect wiring, remove screws holding motor in place and insert new motor. Screw into place, and connect wiring.
6 Check for any black substance leaking under the washing machine. This might indicate a clutch problem, if the washing machine spinner is not working. Contact a professional repairman to replace the clutch.
Thanks.
Nov 08, 2011 | Washing Machines
Candy washing machine grand go f 662 stops mid cycle and the cold wash light flashes and the softener isnt used
Hello.
Washing machines, like any other mechanical device, occasionally needs servicing. A common problem with an older washing machine is that the spinner, or agitator, drain,or stops rotating during wash cycles. Fortunately, most washing machine problems are easy to troubleshoot. Any do-it-your selfer can fix it; here's how.
TOOLS NEEDE TO SOLVE PROBLEM ARE BELOW.
2 Check that the agitator is seated correctly by opening the lid of the washing machine. If it's loose, pop off the top of the agitator--if there is one--and tighten the bolt that holds the agitator in place. Or, in some models, simply pull straight up and then reset the agitator.
Thanks.
Bottom rotor is not working
Hello.
Washing machines, like any other mechanical device, occasionally needs servicing. A common problem with an older washing machine is that the spinner, or agitator, stops rotating during wash cycles. Fortunately, most washing machine problems are easy to troubleshoot. Any do-it-yourselfer can fix it; here's how.
Bucket and rags,Screwdriver,New drive belt (if necessary),New drive motor (if necessary)
Thanks.
Drain line clogged on Whirlpool model ET1CHMXKB09. How do I access the drain line?
Hello.
Washing machines, like any other mechanical device, occasionally needs servicing. A common problem with most old washing machine is that the spinner, or agitator, drain,or stops rotating during wash cycles. Fortunately, most washing machine problems are easy to troubleshoot. Any do-it-your self offer can fix it; here's how.
Thanks.
Oct 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
How do i replace the agitator in my old heavy duty whirlpool washing machone?
Hello.
The Whirlpool Ultimate Care II washing machine is atop-loading clothes washer. The washer has several cycles to choose from,including cycles for washing normal clothes, permanent press items, delicateand items marked "Hand Wash." To do its job, thewashing machine relies on an agitator, located in the center of the wash tub.The agitator rotates during the wash cycle, moving the clothes around the washtub so that they are cleaned equally. If the agitator is broken, it will notsufficiently agitate the clothes and must be replaced. ·1 Unplug the washing machine from the wall outlet or turn off the power supplyin your service panel. · 2 Open thewashing machine lid and remove any clothes remaining inside. · 3 Remove thefabric softener cup by squeezing the bottom lip of the cup and lifting itstraight off. · 4 Pry theagitator cap off of the top of the agitator with a flat-head screwdriver. · 5 Remove thebolt at the bottom of the agitator, using the socket wrench with extension, andthen remove the agitator from the washing machine. Tip the agitator to removethe bolt and washer. · 6 Install thenew agitator onto the drive shaft. · 7 Secure thenew agitator with the bolt that you originally removed. · 8 Press theagitator cap and fabric softener cup back into position on top of the newagitator. · 9 Restore powerto the washing machine to complete the repair.
Thanks.
Sep 07, 2011 | Whirlpool Washing Machines
My washing machine does not agitate, 2009 is when I purchased it.
Their is 1 of 2 things wrong causing it to not agitate..does it also not spin or just the upper portion of the agitator doesnt turn while the bottom does??
these tips i wrote will cover the 2 different things that are causing it not to agaitate depending on if it also spins or not
JUST BOTTOM OF AGITATOR TURNS BUT NOT THE UPPER BARREL.. http://www.fixya.com/support/r10294924-top_part_agatator_isnt_turning_top_load
DOES NOT AGITATE OR SPIN http://www.fixya.com/support/r10293994-whirlpool_made_washer_not_agatating
GENE
Aug 31, 2011 | Roper Washing Machines
My washing machine is not working??
  1. Fixing an Agitator One of the most common problems with a washing machine is due to a broken or malfunctioning agitator. The agitator is the piece of plastic that moves back and forth. In order to fix the agitator, you must first remove it. If the agitator is not broken, but moving slowly in one direction or not at all, this can be due to the clutch assembly that the agitator relies on. You can remove the agitator and check the clutch assembly. The clutch has dogs that depress and pop up with each turn, however if these dogs are worn, they will need to be replaced. You can usually contact your washing machine manufacturer and order replacement parts. Alternatively, you could get one from a home improvement store that stocks common washing machine items.
  2. Electrical Problems Sometimes a washing machine may have electrical problems that can include a blown fuse, a broken timer, switches that are not functioning, etc. Obviously, before you fix a problem with the electricity, make sure you unplug the washing machine. First, check your fuse box and your electrical outlet. Some types of washing machines require higher voltage to work and it might be a problem with your home’s electricity rather than the washing machine. In addition to checking the outlets and fuse box, check the cords and electrical system of the washer machine. Most washer machines will have fuses that are accessible from behind the unit. Check to make sure all are working properly. If you are having a problem with a specific switch such as a timer or thermostat, you might want to check the connection or replace the timer or thermostat completely. Usually this only requires a screwdriver and the new part.
  3. hope your problem will be solved
Jul 20, 2009 | Washing Machines
Top half of agitator turns free (does not agitate)
You will need a set of agitator dogs. Pull off your agitator cap and look under it, you will see 4(four)small tabs that catch and release the top 1/2 of the agitator.
Good Luck!
Feb 25, 2009 | Washing Machines
Whirlpool washing machine agitator removal
my whirlpool washing machine's agitator bottom is working but the top is not. How can I fix this myself?
Thank you,
Ann
Nov 24, 2008 | Estate TAWX700JQ Top Load Washer
Kenmore Top Load Washer Series 70
NO,your transmission is probably ok!! Inside your top end of agitator are these 4 plastic parts called "dogs" they need to be replaced.To be 100% sure ,do this first,Fill upthe machine on small load and while its washing look to see if the bottom end of agitator is moving back and forth ,if it is replace the dogs.In some machines you have to change the upper part of agitator.If the agitator is not turning at the bottom than,remove the top of agitator cover so you can get a extended half inch socket in to it and pull the agitator up and check the transmission splines.If they are smooth and cannot grab the agitator than your trans, is bad.
May 15, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
1,107 people viewed this question
Top Washing Machines Experts
