Question about Dell Inspiron 1501 Notebook
Had bluescreen a number of time, but laptop always booted up again. However i now have a black screen and nothing will boot up,even tried the dell recovery disc, but nothing. Any ideas?Thanks
    Problem Solver:
  • 11 Answers
Worth a try:
plug in an external monitor and see if it works. If it does, your screen might have become unplugged (happened to me) or may need to be replaced.
Posted on Apr 21, 2016
  • Dell Master
  • 998 Answers
Dell includes a series of tests for a system's hardware into the BIOS called the PSA+ Diagnostics. You can run these tests even if the system lacks any media (hard drive, CD drive, etc.). To launch the PSA+ Diagnostics on this system, perform one of the following actions:
  • Hold down the key while pressing the power button.
  • Turn on the system, press at the initial Dell™ logo screen, and select Diagnostics from the boot menu.
  • Disconnect the AC power and remove the battery. While holding down the power button, insert the AC connector into the back of the system. The system then starts and the message Diagnostic boot selected displays. The system then launches the PSA+ Diagnostics.
  • If all tests pass you will need to re-install the operating system software.
Posted on Sep 01, 2011
SOURCE:
My dell vostro 1710 laptop computer screen is black.
First, try reseating the memory modules in the laptop.
If still nothing, try removing the hard drive, CD/DVD Drive, and memory one at a time (in that order) see if anything makes it boot.
Replace the parts and try booting again.
The error flashing means a processor failure. If you are knowledgeable you can try re-seating the processor.
However, if your unit is in warranty I would call Dell and have them replace the main board and the memory modules as a set. Warning: They will make you go thru these same tests even if you already have.
May 04, 2010 | Dell Vostro 1710 Laptop
Dell inspiron 1000 never boots up, screen black
go into bios and fix boot menu
If you need further help, reach me via phone at https://www.6ya.com/expert/scott_541ceb86d69e7743
Dec 06, 2009 | Dell Inspiron 1000 Notebook
Dell Inspiron 1501 won't boot
The initial Dell Screen you see at the begining is your BIOS access. Push F12 repeatedly when you see this screen and it will take you into a system restore mode. It will let you boot from CD first (which your PC is not set up for). You should be able to start the CD fine from there.
Sep 21, 2009 | Dell InspironTM 1501 Notebook
Dell Inspiron 1000 Unmountable Boot Volume. CD drive faulty.
f2 should get you to bios ,move cd rom to first boot device save and exit,on restart f12 should give you a one time boot option pick cd rom ,and boot to windows disk,hitting f8 or f6 at just the right time during start up should get you to the advanced startup menu ,safe mode ,last known good configuration ,ect...hope this helps,otherwise pull the plug,and battery ,open it up and find the bios battery on the motherboard ,unplug it,or remove it,if its the watch battery type ,be carefull takeing it out ,the socket its in will break off the board,let it sit for a couple hrs,put it back and try agian
Sep 21, 2009 | Dell Latitude D600 Notebook
Inspiron 1420 is not booting to windows
Re-boot, Keep tapping F8 until you get to a black screen, last known good is there, choose this, leave it to run,
or try again re-boot, choosing safe mode this time, if/when it boots, then a system restore in safe mode, go back in time.
If still no good, Your O/S disc is now needed,
boot with disc, go for a repair of the install,
Let it run it's course,
re-boot.
Regards.
Apr 10, 2009 | Dell Inspiron Notebook
Dell latitude d600 screen goes black during boot
ok after you have booted in safe mode do a restore to a date just before the last day it worked properly and try that restore is found here
start/programs/accessories/system tools/system restore
hope this helps
Mar 15, 2009 | Dell Latitude D600 Notebook
Acer Aspire 5050 won't boot at all
Hi there
Try taking the battery out and power it on AC only, post back with the results.
Good luck
Feb 13, 2009 | Dell Latitude D600 Notebook
Inspiron2200, black screen says 'failure to boot, strike f1'.
ithinkthat there is nothing wrong with your hard drive. your problem is with your bios it keeps reseting so it with try to botto the default source at bootup.
may try a replacement battery fot the cmos. easy to get to it in the 2200.
Apr 14, 2008 | Dell Inspiron 2200 Notebook
Dell B130 Laptop Boot Problem
if battery is new and functioning properly(battery) please boot in safe mode by pressing F8 during os starup. and logon as an administrator.
if nothing works out try reinstalling operating system it will solve the problem else update me the ststus.
Feb 26, 2008 | Dell Inspiron B130 Notebook
Dell Inspiron 1501 Notebook Logo
70 people viewed this question
Clive
Clive
Alun Cox
