Question about Car Audio & Video
CD stuck in Sony CDX-A55
My kids have put a CD into the cassette which had a label on it and it is now stuck in the machine. Any suggestions about how to remove it will be gratefully received. Thanks, Fiona
  • 277 Answers
SOURCE: ERROR message - CD is dirty or not put in the magazine correctly
hi for starters look carefuly if you are putting the CD's in the right side inside the magazine and the magazine itself in its right position take a air spry can and clean the laser eye of the changer while ur at it clean the whole changer from dust and dirt good luck windman
Posted on Feb 14, 2006
  • 579 Answers
SOURCE: Left Deck Door Stuck Shut on Cassette Deck
The cassette mechanism has a large gear that rotates to different positions for the different modes. On time around is a play - stop cycle. It is stuck in one position and won't come around to the stop spot. Need to take the cover off and help it to turn to get the cassette out. Then figure out if something is wrong preventing it from turning or if the wheel driving it is the problem. They are all a little different so this is where your mechanical apptitude comes in.
By the way, you'll figure out right away they don't intend these things to be fixed.
Hope Ya Fix It.
Posted on Feb 10, 2008
Eagleeyes
  • 199 Answers
SOURCE: CDX A55 Error (Err-99)
Hi in most casses just unplugging it will reset the unit.
but this unit is very old and to be honest is probably ready for he knackers yard.
they did suffer a few problems....
Reagrds
Mark
www.blueice-electronics.co.uk
Posted on Jun 23, 2008
SOURCE: Sony CD interchanger CDX - T69 (how to reset?)
This would invalidate the warranty and you may break it but I have just had to do one:
1. Remove 4 black screws
2. Unclick the front panel - yes it is clicked on but may appear to be screwed
3. Take off black lid
4. Pop the cradled player from the 4 dampers and unhook from the 2 springs
5. Remove the ribbon connector - do this by slipping/clicking the brown holder very slightly and then the ribbon comes out easily
6. Now using a suitable tool push the stuck CD back into the magazine
7. Click the magazine out - there is a white piece of plastic what when moved does the eject.
8. Do the above in reverse.
The trick to get the grey horizontal/vertical discs back on is to set them passed horizontal one notch on and click them on at the end - turning one notch anti-clockwise to lock them.
Posted on Sep 06, 2008
  • 1894 Answers
SOURCE: How to connect headphones without a headphone socket
if there is differentiation between the sockets you will need the manual..
Posted on Mar 09, 2009
Hi, I can't get the magazine out and it reads CD ERROR on the stereo. i've tried to eject it using the button and can hear it making noises as though it is trying but it doesn't come out. i...
It seems so that the disc or the loading mechanism has jammed . Sometimes CD's which have labels or even warped ones( spurious types) can be stuck up as it will not move freely in loading thereby getting stuck in the mechanism.
Also sometimes the loading motor can slip on the pulley with a higher torque or the gear or belt can slip off-- since you can hear the noise when eject is pressed.
The best way is to remove power, open the covers and use a soft tool like a screw driver to push the struck up disc or manually rotate the gears to release the loading and thereby eject the tray out. Now inspect all the disc before you put then back inside as one of them is a suspect.
Aug 04, 2011 | Sony CDX-T69 6-Disc CD Changer
Can you hook the sony 10 disc changer cdx-636 to a car radio?
I have the cd changer box but I dont have the supporting cables to connect to tha sony cassette player can you help me to purchase this item with imege
Jun 24, 2010 | Sony CDX-636 CD Changer
Sony CDX-S2210 buttons are jammed
Hi Sameersach,
Have you found a solution for your problem? I have the same player and I got the same problem...please, let me know if you found a solution. Thanks!
Apr 17, 2010 | Sony CDX-S2210 CD Player
I have a sony xr-6559 Cassette radio with cd facillities but don't know which cd changer will work with it
There is a guy online selling this radio with the CD Changer, and he calls it the cdx-51. There is one on ebay for around $45, and you can see it here http://cgi.ebay.com/ebaymotors/Sony-CDX-51-CD-Changer_W0QQitemZ290351379165QQcmdZViewItem. Hopefully, with the code, you can find the changer you need.
Sep 25, 2009 | Car Audio & Video
Sony CDX-GT710 stuck ATT mode.
face is giving problem best solution change face
Jun 22, 2009 | Sony XPLOD CDX-GT200 CD Player
Sony CDX-S2200 CD Player Problem
Please press Reset switch in CDX-S2200. You can see it if you de-attache front panel.
If problem still exist, then you need to replace IC300 " 6-705-360-02 " IC TDA8588BJ/N2/R1
Oct 02, 2008 | Sony CDX-S2200 CD Player
Sony cdx-t69 CD Changer Unit
hi there that is sorta the problem i had and if you press eject nothing happens its still in there what i done was disconnect the battery for at least one minute and the cd changer lost its memory and was fine so i ejected the cd magazine and cleaned all the cds and blew out inside the machine has worked everytime its woth a try
Jul 01, 2008 | Sony CDX-T69 6-Disc CD Changer
Reagrds
Mark
Apr 09, 2008 | Sony XR-C5100 CD Changer
Car Audio & Video Logo
163 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
