Question about Kenmore 74832 Gas Dryer
Dryer has no heat
I noticed that you replied to a person with almost the exact same question that I have. I'm hoping that you can help me. i have a Kenmore 110.74832400 clothes dryer, and it runs wonderfully except for the fact that theres no heat. My husband and father took it apart and cleaned the entire thing out. It lit once and was blowing cold air, turned it off and restarted it and it's blowing only cold air again. We were thinking there was a problem with the ignitor, but you commented to the last guy that its hardly ever the ignitor. What do you think the problem might be? With 5 kids, and work being slow for my husband this year (construction business) we really can't afford to have anyone come look at it.
  • Anonymous Dec 15, 2008
    runs but no heat ignitor not glowing
    mike
  • patrickmrobi Apr 02, 2009
    same model number, same problem, checked ignitor, checked thermal fuse, checked the coils....all fine. There isn't any electricity running to any of the things listed above. Could it be a timer problem?
We have the same problem as posted above (dryer not heating up) only we have a Kenmore gas dryer Model 76702693. What should we do? Please help. Thanks.
Posted on Nov 15, 2008
    Sniper:
  • 88 Answers
If the ignitor is glowing, but there is no heat, make sure the gas shut off didn't get bumped closed, otherwise I would replace the gas valve coils, part # 279834. They are mounted on the gas valve itself, and are very easy to replace.
Posted on Sep 14, 2008
I have a Frigidaire Dryer model number GLER341AS2. The dryer runs fine, but won't get hot. I pulled the dryer from the wall to see anything obvious. I noticed what I thought at first to be anim
Are you mechanically inclined? You may have several problems. 1st, heating element is most likely burnt out. Then I would check ball and socket assembly that back of drum fits into. Also check felt in front of machine that drum rides on. May need competent service person on this.
Sep 13, 2017 | Frigidaire Electric Dryer
Thank you for your fast reply. Do you have a picture of the wiring just left of the connection. This was purchased used and then we realized that there was a problem with the wiring; two wires (red and...
Do you have the exact model number of that unit. It can be found on a label inside of the dryer door.
As opposed to posting another question just click add a comment and reply with that model number
Oct 12, 2011 | Kenmore 98702 Stacked Washer/Dryer
Dryer runs but does not produce any heat. Got a memo on the panel saying clean lint filter, which I have done.
The element may have failed if no heat at any setting. It could also be the thermostat but the element is more likely if no heat at any setting
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 28, 2011 | Bosch Axxis WTA 3500 Dryer
Dryer stop heating
Try vacuuming out the intake and exhaust vents for the burner. Lint collected there can block the burner operation. Hope this helps!
Jun 28, 2010 | Whirlpool LGB6300 Gas Dryer
I have a Kenmore electric dryer 68721 that doesn't heat. It cycles and tumbles.
Most likely you have a bad heating element or a bad wire/connection. The only way to test is with the cabinet open and the dryer running. I would recommend that only a qualified person or tech perform this. I hope this helps. If I can t anything else to help please let me know.
Mar 21, 2010 | Kenmore 64742 Electric Dryer
Light underneath dryer, right side, front
What you`ve ``just started noticing...`` is likely the ignitor glowing or the burner burning and is quite normal for a ``gas`` dryer.
Hope that answer`s your question. If so please take a second to rate the reply I provided to you here at fixya.
Thank you.
macmarkus :)
Dec 13, 2009 | GE DBSR453GBWW Gas Dryer
Dryer won't start
There is a good chance it's the 'thermal fuse'
Aug 07, 2009 | Whirlpool LEQ9858P Electric Dryer
Dryer heats with smaller loads
1. unplug your machine and rach as far in the exhaust part of the dryer to see if there is an obstrucxtion
2.Take out the lint filter and make sure there are no gaping holes in the screen
3. Check the exhaust house leaving the machine or blockage, this hose should not run more than ten feet for optimal drying time.
4. its your heating element
Jan 19, 2009 | GE DBXR463EBWW Electric Dryer
I replaced the belt on dryer, still wont start
hiya
have you checked the small plastic ****** on the door? sometimes these bend due to the heat and dont press the microswitch to allow the dryer to start.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Aug 03, 2008 | Dryers
MAYTAG atlantis MDG6400AW, dryer not heating
no we can fix it its proab a heatyer coil or thermial limiter if you reply ill help mater of fact did you have it on auto dry ?
Apr 03, 2008 | Maytag Atlantis MDG6400AW Gas Dryer
Kenmore 74832 Gas Dryer Logo
363 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
